Frosted Flakes
HDNB
Re: Frosted Flakes
Post by HDNB »
planethax wrote:Pitched 100g of active dry yeast wash was 100*f
Sugar water flakes was on heat for 60 minutes
15 minutes at light boil
if you pitched, then boiled as stated, i'm with C1, you probably killed most/all yeast and then by some miracle they got a colony going in the anaerobic water and then your ferment actually started...kind of a delayed reaction.
if it's fizzing now, it's working... so i would just give it the time it needs, the temps you are working at now should finish soon. don't forget to rack it off for a day or two so it clears, otherwise the solids may burn in the boiler.
now i drink for evil.
planethax
Re: Frosted Flakes
Post by planethax »
Sorry I was unclear there
Was merely stating that I had it on heat for an hour and boiling for 15 minutes.
I pitched at 100*f and did not reheat after that.
HDNB
Re: Frosted Flakes
Post by HDNB »
planethax wrote:T
I realize my issues with temp at first affected the ferment but it has been stable last five days and expected closer than 1.0320
That's why I thought it was my lack of aerating causing it.
It is still going
Picture a glass of cola
Seems to be about as much as this is fizzing.
if it's fizzing like soda, that's great! from 1.03...i'm betting 4 more days, then a day to clear and then rack it let it clear for another day or two...looks like next Saturday is your day *keep it warm
RandyMarshCT
Re: Frosted Flakes
Post by RandyMarshCT »
How did the ferment finish up for you? As you seemingly determined, a stable and controlled ferment temperature is very important. I'm curious how it came out (flavor, in your opinion) and what your final gravity was.
Life member, representative, and proud supporter of the Hobby Distiller's Association.
http://www.hobbydistillersassociation.org
planethax
Re: Frosted Flakes
Post by planethax »
It finally finished Last Friday, 0.992
Ya, for sure I need a stable environment.
I now have a heater, thermometer and proper SG meter.
And since it won't be my First wash anymore I should have more will power to "Stay the F%$# Out of IT!!!!" lol
As for taste and flavour? Well I like it but have no experience to go on as it is the first time every drinking non commercial.
I have 3 liters away aging (1 on a bourbon stick, 1 on JD chips and another on JD chips and a chunk of cinnamon stick)
Left 1 liter just plain, diluted to 45-50%(my eyes are getting bad lol) that I drank with some Sprite last night.
I really enjoyed it.
Did I enjoy it because it was good, or because of the satisfaction of my first batch?
I hope its a little of both but probably more the latter.
I am thinking on doubling up the Frosted flakes this time, and I have 7 gallons of back set I am considering using in ferment.
But I may just dump that and do it again for the third run.
Overall I am quite pleased with this, I hope some one else tries it!!!
It I imagine will be almost identical to Odin's Corn Flake Whiskey.
HDNB
Re: Frosted Flakes
Post by HDNB »
great job getting 3L of something useful. specially on your first run :thumbup:
did some of he corn flavour come thru?
WooTeck
Re: Frosted Flakes
Post by WooTeck »
I like this thread. just hoping that I can learn from this before my first batch.
eck
planethax
Re: Frosted Flakes
Post by planethax »
Made another batch last night but changed it up a bit.
100l water
5kg Frosted Flakes
.5kg rye flakes
17.5kg sugar
100g boiled yeast
Cooked on slow boil for 30mins
Pitched 100g yeast at 30*c
Sg was a bit high 1.071 no room in fermenter to add more water.
Next batch ill go with 17kg sugar.
HDNB
Re: Frosted Flakes
Post by HDNB »
i'm jealous that you have the capacity of 100L ferment! :thumbup: :thumbup: :thumbup:
planethax
Re: Frosted Flakes
Post by planethax »
I use a 121 liter Rubbermaid pp trash can for $20.
Allows me to make enough for two runs.
Prob will get a second two have 2 going at a time.
HDNB
Re: Frosted Flakes
Post by HDNB »
my shop is 175 big paces from water. probably have a stroke carrying that much water! guess i could get a 300' water hose for summer... :idea:
