I halfway promised it'd be done this month, one year from when I joined HD! Very close. Here's some progress shots. This is the first time it's actually been together, and this is using the new 3" column I fabricated... the 2" column is set aside. The hope is, with 3" packed w/SPP and a wide-open vapor path, it'll have throughput. I have 5500 watts in a 13 gallon milk can boiler.
Overall view on the boiler. Total height not bad at all, the sight glass is at my eye level, I'm a 6' guy
The business area. On top the 3" column. For those who've read through this whole thing, it's a complex rig. Immediately above the 3" column end is the stainless slide valve, that is primarily VM, but it also can shut down flow to the reflux condenser, with all vapor flowing strongly to the arm and into the product condenser... pure pot still. Anywhere in between, the valve perfectly routes whatever percentage vapor I want to either the product arm, or the reflux condenser.
Optionally above the valve is this small Bok "2 cups" LM head. It can be used to compress fores with the valve closed at 100%. Once the fores/heads/nasties are bled, the slide valve is slowly opened for VM operation. If desired, the LM head can be removed. Love tri-clamps.
You can see the transition from 3" to 2" - tried to keep it compact and neat. The rivets aren't for show, they add immense strength.
One of the harder components was this long-sweep 2" ell. I didn't want a huge standard solder job there, so I cut the ell down and added ez-flanges, using SQUARE copper for the rim, for those who remember the thread on that. The product condenser is a 7 tube shotgun, with a surge suppressor end.
The adjustment for the valve is an old handle from a coffee mill! I like it.
With the parts together, I am laying out the hard copper cooling and routing temp probe cables. More to come.
Edit: These parts were individually bagged in little garbage bags, in a box. They were as shiny when they came out, as when I stored them. Conclusion - if you like to keep copper shiny, put a garbage bag over it and cinch in tight with string. Keeps oxygen out.
