magnetic ss
swoss72
magnetic ss
Post by swoss72 »
Can I use magnetic as on my pot
bearriver
Re: magnetic ss
Post by bearriver »
Not enough iron, nickle, or cobalt in to make it stick...
Wouldn't have been easier just to try it?
DAD300
Re: magnetic ss
Post by DAD300 »
I read this as you have a SS pot that a magnet sticks to.
I have even heard of some SS kegs that a magnet will stick to.
I have old Stainless Steel milk jugs, that a magnet sticks to, but the don't rust. I believe it to be fine.
DSP-AR-20005
swoss72
Re: magnetic ss
Post by swoss72 »
I have a stainless keg but I had a piece welded to it that a magnet sticks too
RandyMarshCT
Re: magnetic ss
Post by RandyMarshCT »
If you put enough cold work into stainless steel, it can become magnetic. There are also some grades of stainless that are inherently magnetic (400 series). Many kegs that a magnet will stick to are cold formed.
Life member, representative, and proud supporter of the Hobby Distiller's Association.
http://www.hobbydistillersassociation.org
swoss72
Re: magnetic ss
Post by swoss72 »
So it is safe then. Here is a pic of he piece
A ss sink drain upside down
swoss72
Re: magnetic ss
Post by swoss72 »
The package said stainless steel
corene1
HD Distilling Goddess
Re: magnetic ss
Post by corene1 »
The keg looks like stainless but the piece that is welded on looks darker , more like a standard steel. If you have a file , take and file a shiny clean spot on the piece in doubt and mix up some salt in some water . Then soak a rag in the salt water and let it sit on the piece over night. If it is stainless it should not rust if it is ferrous you will see rust starting to form.
swoss72
Re: magnetic ss
Post by swoss72 »
OK I will absolutely do that today and thank you for the info I didn't know how to test the piece you learn something new everyday
swoss72
Re: magnetic ss
Post by swoss72 »
And btw now is one of those times when I know I am truly a rookie at this and lesson learned figure out the right way first before assuming.... DUH!!! LOL
swoss72
Re: magnetic ss
Post by swoss72 »
I guess I should have cleaned it before I posted a pic
After I cleaned it
After I cleaned it
