how much water?
nickbbb
how much water?
Post by nickbbb »
I have a clawhammer supply 5 gal still. How much water would I need on hand for the condensing? Is there a formula or just trial and error to figure it out? I have always just hooked it up to a faucet for this but I am wanting to try to reuse water rather than just letting it run down the drain. Thanks!
Kegg_jam
Re: how much water?
Post by Kegg_jam »
A lot of variables there.
You could do a run hooked up to the faucet and start filling up buckets with the waste water.
Then you'd know for sure.
nickbbb
Re: how much water?
Post by nickbbb »
Ah!! :oops: Keep it simple! Now I'm embarrassed I did not think of that. Thanks!!
Bagasso
Re: how much water?
Post by Bagasso »
nickbbb wrote:I have a clawhammer supply 5 gal still. How much water would I need on hand for the condensing? Is there a formula or just trial and error to figure it out? I have always just hooked it up to a faucet for this but I am wanting to try to reuse water rather than just letting it run down the drain. Thanks!
Thats a potstill, right? I remember the rule of thumb being 2 times the boiler size.
ranger_ric
Re: how much water?
Post by ranger_ric »
i run a 5 gallon pot still with a 33" Liebig condenser and have 10 gallons in a cooler being pumped by a little pond pump. I generally go through about 15 gallons of cooling water. It is possible that I could allow the water to get a lot warmer but with safety in mind I never let the cooling water get above 95°. I have it set up to where I can siphon into a 5 gallon bucket, and then when the bucket is full i use a garden hose to add about 5 gallons to the cooler. This all runs through a little pond pump that will do 5 feet of lift ($20 at Lowes). Seems to work well, water is definitely pushing 95°+ by the time I finish my low wines.
Be safe..
If you are not willing to learn
No One Can Help You...
If you are Determined to Learn
No One can STOP you!!
We want you to be safe and succeed so start here
mason jar
Re: how much water?
Post by mason jar »
I used to run my old 10 gallon pot still and 30" liebig condenser using about 27 gallons of water. I ran it pretty
fast so by the end of the run the water was pretty hot to the touch. I didn't measure the temperature so I'm
not sure exactly how hot it was. So like ranger_ric, I used a bit more than the rule of thumb. Maybe that's
technically a little too much water, but I was trying to keep my product fairly cool, though that is probably
not strictly necessary.
Just a thought, but if you don't want to mess with water, you might think about trying an air-cooled condenser:
Shameless plug: http://homedistiller.org/forum/viewtopi ... 87&t=54596 :D
You could make one a bit smaller than mine if you're going to stay with a 5 gallon still.
