Buyin oak
- ga flatwoods
Re: Buyin oak
Spring is here so go to Lowes or Home Depot and buy a half JD barrel they sell for flower pots. Beat the rings off and you have more than enough to last a long time.
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
Re: Buyin oak
Aren t they charred on the inside ?
- S-Cackalacky
Re: Buyin oak
Well yes, it's a whiskey barrel. You'll still probably need to char it yourself after you cut it up. I think the rule of thumb for oak aging sticks is 3/4" X 3/4" X 5".
You can also order white oak online and do it from scratch. You need to start with well seasoned wood. You can also use something like Jack Daniel's BBQ chips or buy oak blocks used for smoking. There are some good tutorials here on the forums for prepping and using the wood.
Re: Buyin oak
Sounds good . I wasn't going to char the sticks for my brandy , is that
a problem?
a problem?
Re: Buyin oak
Can someone post a link to a toasting tutorial. I can't find one
- ga flatwoods
Re: Buyin oak
Forum google search toasting oak then hit go
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
- T-Pee
Re: Buyin oak
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
- S-Cackalacky
Re: Buyin oak
+1 on T-Pee's blatant self-promotion.
- bearriver
Re: Buyin oak
My local hardware store has whole and intact oak barrels for $125 by the front door. They look practically new and smell like bourbon. Yard art deco. Thats enough oak adjunct to keep you stocked for many years, or you can filler up with whiskey if you got the stones to put it down.
This reminds me. I'm overdue to send some dominos to a member here. I made them from a hardware store bourbon barrel. Works a treat in a glass aging vessel. Gonna do that tomorrow...
Re: Buyin oak
Thanks fellers. But do I need to char my oak? I would think for brandy just toasting it would be bettee
Re: Buyin oak
Can I age in a mason jar with the regular lid?bearriver wrote:My local hardware store has whole and intact oak barrels for $125 by the front door. They look practically new and smell like bourbon. Yard art deco. Thats enough oak adjunct to keep you stocked for many years, or you can filler up with whiskey if you got the stones to put it down.
Re: Buyin oak
Personally I use a medium char on the oak sticks I use for my apple brandy. You could try one jar just toasted and one toasted and charred and see which way you like it.Diesel410 wrote:Thanks fellers. But do I need to char my oak? I would think for brandy just toasting it would be bettee
Braz
- bearriver
Re: Buyin oak
Mason Jars are commonly used as is. However, there is evidence the lids are not tolerant to high proof alcohol. Some cleaver people here have come up with viable alternatives.
New oak gets a toast and char. Oak from a barrel should have the old char scraped off then recharred. I like rubbing the sticks together after to remove loose char. Then I soak them in water for a few days, and finally rinse them off in the sink before use.
Re: Buyin oak
I found these in the grocery store with the charcoal.They also had cherry, apple, pecan, mesquite,hickory and sugar maple.
Yahoo Mountain Dew ! It'll Tickle You're Innards !
