Portable fermenting cart
Since my son moved back home and lives downstairs I lost my downstairs bathroom where I did my fermenting. Just finished insulating this large cart with a removable insulated front. Holds my heater and four six or eight gallon fermenting buckets.
Re: Portable fermenting cart
perrrrrfect
is that a repurposed tool chest??
No it's a really large AV cart used in education that I purchased from surplus supplies.
that looks pretty sweet Bushman! its a bitch to move them around without wheels sometimes.
I used to ferment in a downstairs small bathroom with a heater and aquarium temperature controller while doing fermentation but as mentioned I moved it into the outbuilding on this portable cart and retired the aquarium controller to a drop light. Not only did I regain the bathroom the light works great and uses much less electricity.
Below is a link to my aquarium controller, wiring is the same just switched the heater for a drop light.
http://homedistiller.org/forum/viewtopi ... 85&t=25475
PS: what I didn't mention is I put L bracket son the bottom to hold the front and use ratchet straps to pull it in. Makes it easy to remove and get to the different fermenting buckets.
- BoisBlancBoy
Looks great! You should have went bigger hahaha!
- dieselduo
wish I had something with wheels. getting old makes it brutal schlepping buckets around
Actually I can hold 4 eight gallon fermenters at a time, I have 6 gallon fermenters keeps me busy enough.BoisBlancBoy wrote:Looks great! You should have went bigger hahaha!
- BoisBlancBoy
Probably smells great when it's full and fermenting away when you walk by.
- bearriver
That's great Bushman! Everything in a garage should be so lucky to sit on Castor wheels.
Looks big enough to keep you busy all winter.
BoisBlancBoy wrote:Probably smells great when it's full and fermenting away when you walk by.
- Stonecutter
Bushman seriously Bad Ass! Being a tool guy, I definitely nerd out on carts.
A fine example of K.I.S.S.
-Thomas Paine
-Thomas Paine
That's good enough to put on 20" castors with rap music over it.
― Charles Ives
― Charles Ives
