I diluted it with wash to try and retain as much flavor as possible.Mr.Spooky wrote:did you dilute it to get to 30%, or is that just what it ended up being? if you did dilute,,, what did you use???
thanks
spooky
![Wink :wink:](./images/smilies/icon_wink.gif)
thanks
spooky
Well if we're going to get extra technical I guess your right, 30L of real tails with 10L of wash (fake tails), just to really precise and exactMr.Spooky wrote:so its not a true tails run? i think your run will turn out GREAT!!!!!! cant wait to hear your results!
spooky
You have got to be happy with that AustinAustin Nichols wrote:
Just checked output temp @ 29.5 degrees C, not sure what the true corrected reading is but will check later.
I agree od.. I tried a bubble cap, and I prefer the perforated also..olddog wrote:I have made all three types of plate, seive plates, valve plates using rivits, and bubble caps. My personal preference is for perforated seive plates, which when fitted closely or soldered into the column work well and are the easiest to fabricate. I could not notice any difference in performance with either seive plates or valve, as the are both self draining, but I found that bubble caps do not cut to a dribble when the hearts are all taken, and the only way you can see your getting into tails, is when you notice the temp rising, as bubble caps will still bubble when there is only waterey wash left on the plate as they are not self draining. This is only my personal opinion, each will build to their own liking.
OD
Why is that? Can you explain?I agree od.. I tried a bubble cap, and I prefer the perforated also.. KS
This is exactly the reason I had KS build mine with Bubble plates, I havent run either, but I am after a great rum. Its my hope that the bubble caps work as thumpers giving flavor. But no matter what we all have, we will enjoy it. Its all in how you run it. Im sure some guys could get the same resluts no matter what they run.olddog wrote:I currently have two plated columns, the original Magic Flute, and a new column I have just completed with bubble caps. The Magic Flute with perforated plates seems to give a cleaner crisper spirit than the new column with bubble plates, which will always retain half an inch of liquid on the plate regardless of whether its alcohol or water. Towards the end of a run I found that there is no distinct cut off between hearts and tails like you get with a perforated plate, making a smeared transition between hearts and tails. I put this down to perforated plates shutting down when the alcohol is taken reducing the output to just drips, returning the watery tails back to the boiler. The tests were made using exactly the same wash and exactly the same amount of feints on each run.
This is my opinion, others may differ.
OD
Well Well Mike it just shows us that your mind never bloody stopsolddog wrote:I made the idiot mistake the other day, and I ended up with a surging parrot on my new column, yes I had forgot to vent the input tube. I had been thinking about making a surge proof parrot, so having a few fittings in the box this is what I came up with.Its just another reducer cup attached to the top of the receiving cup, sleeved together with vent holes drilled into the new reducer, the stop has been filed out so that the input tube extends down inside the fitting and terminates just above the receiving cup. This is now a fully vented parrot which should NEVER surge.![]()
OD
I think your gonna love your Hillbilly Flute man. I hope you have a wash ready to give her a run.kenfyoozed wrote:OD great parrot. Love the design!
OD
Ill post more when it get it up and running, Non the less i am excited!
Kentucky shinner wrote:I think your gonna love your Hillbilly Flute man. I hope you have a wash ready to give her a run.kenfyoozed wrote:OD great parrot. Love the design!
OD
Well done you are doing a great job ...prdbrissy wrote:G'day guys
I have finally made some progress. I have really struggled with silver soldering, I just can't get enough heat. Soft soldering really does require gentle hand with the torch.
prdbrissy Looks very good and its along the same lines as I am working towards. That is the 4" to 2" to 3".prdbrissy wrote:G'day guys
This is where I am up to. There is nothing pretty yet, but it is progress.
The bits together
Regards
It really only amounts to soldering joints together one at a time, look at it that way and it aint hard.exon wrote:These hillbilly flute designs are intricate to construct for any craftsman.
