Sight Glass fun!!
choppinlow
Re: Sight Glass fun!!
Post by choppinlow »
rgreen2002 wrote: Because of the big gap between the glass and the housing I had to use the silicone gasket... :( .
You just needed to adjust the nuts/bolts to reduce the height.
WIski
Post by WIski »
TP Wrote
Mine are PTFE. You can get them at brew shops or other sources.
TP Can you specify where you get these. This would be so much easier than wrapping in PTFE Tape.
Snackson
Post by Snackson »
The gap is horizontally between the glass and the stainless. The silicone is thick there and keeps it centered. I think cutting the silicone so it only went around the outside (where it doesn't touch the vapor) would work fine. I myself went the wrapping route for my 4" one. I used a high quality thick PTFE tape and made multiple wraps.
T-Pee
Post by T-Pee »
I think it was McMaster/Carr or Grainger.
CRS sucks. :problem:
tp
rgreen2002
Post by rgreen2002 »
Correct... the gap is between the stainless and the glass. The picture didn't do it justice.
See the circular space between the glass and housing
The taped gasket in place
There is just a very small surface of the taped PTFE that sits between the gasket and glass after tightening the bolts down that is exposed to the product.
Ive so far been unsuccessful in sourcing PTFE gaskets that will fit into here...
The gasket sort of looks like this (without the PTFE ball...)
Like a cup gasket?
Like a cup gasket?
PTFE glass gasket.jpg (11.28 KiB) Viewed 2097 times
..but I have no idea what the shape would be called. Any ideas?
HD Glossary - Open this
WIski
Post by WIski »
TP says he got them at Grainger or McMaster Carr. I have looked and have been so far unsuccessful in finding them there. :? I will fully disclose source if I find them as I am also actively searching other sources.
Euphoria
Post by Euphoria »
I've sourced some PTFE gaskets from these outfits. They are good quality.
http://www.jmesales.com/product/bradfor ... 735,17.htm" onclick="window.open(this.href);return false;" rel="nofollow
http://www.glaciertanks.com/TriClamp_Ga ... skets.html" onclick="window.open(this.href);return false;" rel="nofollow
rgreen2002
WIski wrote:TP says he got them at Grainger or McMaster Carr. I have looked and have been so far unsuccessful in finding them there. :? I will fully disclose source if I find them as I am also actively searching other sources.
Yeah..I checked all over Grainger or McMaster Carr...I found nothing either unfortunately. Thanks WIski.
Euphoria wrote:I've sourced some PTFE gaskets from these outfits. They are good quality.
The first place I looked was glacier...they're great. Unfortunately they don't have any either. The links above are for triclamp/ferrule gaskets and this gasket is not that. That being said, I plan to take the glass apart again soon and I will try to see how one of my extra 2" PTFE triclamp gaskets fits. Will keep everyone in the loop on results of this and my continuing search for this damn gasket.
Still don't know what to call the thing... that would probably make it easier.
T-Pee
Post by T-Pee »
Hunh. Danged if I can remember where I got them then. Ebay?
tp
joeymac
Post by joeymac »
Mcmaster sells some foamed PTFE sheeting. if cut a few rings out that that could work.
That's what I use for my large 2" union fittings on my column
"Woe to those who are heroes at drinking wine and champions at mixing drinks" - God (Isaiah 5:22)
So evidently, God wants us to drink our whiskeys single barrel and our Bourbons neat.
rgreen2002
joeymac wrote:Mcmaster sells some foamed PTFE sheeting. if cut a few rings out that that could work.
Is it anything like this : https://www.zatkoff.com/catalog/master- ... /quadralon" onclick="window.open(this.href);return false;" rel="nofollow
joeymac
Post by joeymac »
Looks like this:
http://www.mcmaster.com/#ptfe-foam-gask ... s/=10qr5g6" onclick="window.open(this.href);return false;" rel="nofollow
WIski
Post by WIski »
WOW.....That shites pricey!!!! :shock:
This might be a cheaper option to try :?:
http://www.mcmaster.com/#standard-plast ... s/=10qry85" onclick="window.open(this.href);return false;" rel="nofollow
joeymac
Post by joeymac »
Keep in mind you can probably cut about 5 seals per small sheet. The value sheet are like $35/ea
Well, that.... and I could get excess ptfe foam sheeting from my old job for free.
