Table 1 calculator ++
http://opendistillery.xyz" onclick="window.open(this.href);return false;" rel="nofollow
I'm building this website mainly to teach myself web development. I figured some people here might find it useful. Most of the calculators are available elsewhere, but I'm not aware of any other online table 1 calculator.
Let me know what you think!
Re: Table 1 calculator ++
Well, you certainly are persistent! The calculators look very good. But could you add a flashing cursor, or something to indicate that the boxes are alive?
M
M
Interesting. The boxes should highlight and have a flashing cursor when active. Which browser are you using?
- ga flatwoods
I tried an example and it didn't give an answer.
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
flatwoods, can you tell me which browser you're using and whether or not you're on mobile. This is my first ever attempt at a website, so I'm expecting some bugs, but so far it works on everything I have tried (mostly different versions of firefox and chrome).
- gflower1
I tried the proof calculator on Safari mobile. Worked fantastically.
Didn't run any other calculators but tested all fields and they show active with blinking cursor.
I'm using Chrome. Calculators work but no cursor.
M
M
- GrassHopper
I run firefox and it works fine. No problem with cursor.
I do get a cursor after I select a box, but when first presented the display looks dead. Maybe one of the boxes should be in the selected state when the calculator opens.
M
M
Ah, that makes sense. I'll add some code to select the first box on load. Thanks for the suggestion!
- dieselduo
I use opera. No problem here
- rgreen2002
Love the idea and have bookmarked to watch it for the future. Tried the "mingle" calc and it may need a little more explanation or work (not sure since maybe I don't understand it myself). Its telling me "input is not a number" for the mingle category. This is one I would love to see work out as I am often mixing two different proofs to look for a new proof and would love to know the volumes to use. Good luck and I hope to see more here.
PS: Using Chrome btw.
HD Glossary - Open this
I'll edit that description asap. For now, the mingle calculator works like this:
The top calculate button takes your 3 proof inputs and spits out a Spirit A / Spirit B ratio below in the form of 1 / x. You can then edit either value and recalculate the ratio with the smaller calc buttons. You can also skip the initial "calculate" and just enter your known value and calc. All 3 of the proof values will need to be filled in for the calcs to work.
Hopefully that makes sense. Glad to see some interest!
It worked fine for me on Chrome on my Note 4.
Cranky's Spoon Feeding
- rgreen2002
JStans12
Have you added anything new to the calc?
