Today and in the past week or so, I have finally pulled my finger out and done a couple of stripping runs on a neutral sugarhead, so bodgied together a reflux 'controller' to play with.
I have:
- Arduino
- PT100 sensor measuring temp above the four plates, but below the packed section - not ideal, but it is what I have
- pressure sensor measuring atmospheric pressure (for ABV calculation compensation)
- motor controller wired to two way motorised ball valve
Through the computer, I am able to set a target ABV. The temp and pressure readings are then used to calculated the ABV%. The Arduino has a PID program in it which varies the flow of coolant water through the RC in order to achieve the target ABV. I am able to manually change the P,I and D settings and visualise their effect on response.
Vids below
Two way motorized ball valve rc control
- wiifm
Re: Two way motorized ball valve rc control
I love experiments
Correct me if I'm wrong
Wouldn't a smooth and steady cooling flow to the RC, work better than radical changes
Shady , I think it was Swede and defnitely Old dog and wiifm have used pulsed flow though the RC using solenoid controlled valves that click on and off ....the thermal mass of the RC averages the fluctuation in flow .shadylane wrote: Wouldn't a smooth and steady cooling flow to the RC, work better than radical changes
- wiifm
As yummy said above, I have used solenoid valves with good success in the past. It is just the incessant clicking that gets to be a pita.shadylane wrote:I love experimentsCorrect me if I'm wrong
There were times when I had it tuned in so the flow was varied in only very small amounts and was able to maintain a steady abv. Just didnt have the camera out for those moments.
For me this experiment was to test if i can get the fine control with the cheap chinese ball valves and it was a success in that regard.
More work to be done on the PID settings now
- Kegg_jam
Do you have a link to these valves?
I use an Arduino as part of my rig as well. Mostly just for monitoring temps. It would be really cool if It could adjust the coolant flow to my condensers based on a target temp.
- wiifm
Search for CR5 motorized ball valves. These ones are two directional as opposed to others which have a spring return. The one I chose requires 12v and has limit switches which you can use as an interrupt on the Arduino. You will need a motor controller shield and 12v power supply also.Kegg_jam wrote:Do you have a link to these valves?
