All done. The Harris website recommended bicarb solution to neutalis the acid. It's drying off now. Looks awesome. Thanks for all your help guys
Don't forget to do a leak test. i.e. apply about 3PSI and use a soap solution to check for leaks. Much easier to check now than when making your first run. Small leaks are easy to find now, but are a pain to find and correct later. Been there, done that.
Yay for me. And my pressure test shows no leaks... that thing is stuck on good and proper... might even support my reflux column! I sense some cleaning runs coming on...
To solder a piece of copper onto a stainless lid is the beginning of a nice story always.
In this way, imperialism brings catastrophe as a mode of existence back from the periphery of capitalist development to its point of departure.- Rosa Luxemburg
You're not wrong Der Wo! And if I can do it on this 4l bowl... then I can do it on the lid of a 50l stock pot... If only I had the room!
Tested this method on a sheet of stainless steel first. It seemed like the solder was not turning into a a good concave form but rather formed as a ball. Im using zinc chloride based liquid flux. Solder is 97%tin 3% silver.
chilimies wrote: ↑Thu Nov 05, 2020 9:25 am
Sounds like you are using right flux and solder . Balling is usually too much heat applied . It causes the stainless to oxidise and go black , then the solder won’t adhere .
Clean it all back to shiney again and use a very gentle heat . If its a MAPP torch , it will need to bi so low that the flame wants to keep going out . An electric paint stripping Gun ( like a hair dryer on steroids) is about enough heat to work stainless .
Think less heat is better with stainless .
Get a hog hair paint brush . Use it to paint the flux on . Keep painting flux on .
Thanks Yummy. I'm actually trying to carefully use the oxy acetylene torch at my workplace to do the job. I know it gets way too hot and it is not suggested for this kind of soldering. The steel didn't turn black but rather light brownish. We also have an industrial heat gun so maybe I will try that next. And maybe let the flux sit for a bit longer before starting to solder.
