Looking for: ethanol resistant oxygen permeable membrane
Single Malt Yinzer
Post by Single Malt Yinzer »
So part of aging is slowly oxidizing the distillate. With small barrels the distillate can get over oaked faster than the oxidation process can adequately enhance the product. The oaking process can be done other ways with oak fingers/cubes/chips. With that part of the barrel equation removed it allows for isolation of oxidation process. In pursuit of that I've been looking for an ethanol resistant oxygen permeable membrane. But I can't figure out which one is best for this. I've searched for it but haven't found anything that would be easy to get to test.
Here's a good beer thread with some charts: https://www.beeradvocate.com/community/ ... on.248425/" onclick="window.open(this.href);return false;" rel="nofollow
Goals:
- Oxygen permeability similar to wood (we can test later higher or lower)
- Resistance to high ethanol content (60+%)
- Lowish cost
- Reuseablity (especially if it's costly)
I would ultimately like something I could use to cover a larger jar (a gallon or more) so that I could oak at the same time. I would like it to be a film or thin paper like substance so that it is easy to work with. (Hey if you're going to ask for something might as well ask for all the bells and whistles).
So who can find this magic thing I'm looking for??? Any suggestions for something else? Any ideas for other goals?
cob
Re: Looking for: ethanol resistant oxygen permeable membrane
Post by cob »
Gore-Tex is claimed to be eptfe, but I have never seen it as a stand alone fabric,
always bonded to another fabric for strength.
I would like to see hard proof that Gore-Tex is actually a pure form of
ptfe in an expanded form before I could recommend it for your purposes.
HDNB
Post by HDNB »
i don't want to sound sarcastic (ok, maybe a little) but after reading your goals...wood came to mind. :roll:
now i drink for evil.
Single Malt Yinzer
HDNB - ha, yeah I know. But I want to separate the two processes out as the do different thing for creating a flavor profile. I want to be able to choose how much oak flavor I want then remove the oaking sticks. But I still want to let the product oxidize slowly to smooth it out.
Something like this but the lids would let in just the right amount of oxygen:
Don't put so much oak in that you have to remove it.
Leave enough head space in the jar for the O2.
cranky
Post by cranky »
Get a well used barrel. I want the same thing with my brandy and that's what I I did, found a twice used 5 gallon Balcones barrel and over oaking isn't a problem.
heartcut
Post by heartcut »
Onlinemetals.com sells thin sheet teflon. The 0.031" should do what you want and last a long time if treated gently
heartcut
W. H. Auden
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
Start looking at wood lids for jars like Corene makes. Benefit of the breath ability of the wood, but not in contact with the spirit.
I use those ptfe disk with the band of the mason jar (no jar lid, just disk and band). I leave it half way screwed on, and put it in the attic. In the summer I press down on the disk and it gives me an indication of the pressure release it has, and I can make an adjustment if I want. Expand happens, and it expels. Vacuum happens and it pulls air in. When I proof it down after aging, a good week or so in a decanter really drives the last nail, and I get a great whiskey.
Nothing replaces a well timed barrel, though. Nothing.
Last edited by ShineonCrazyDiamond on Thu Aug 17, 2017 4:14 am, edited 1 time in total.
Shine on you crazy diamond."
chickenfeed
Post by chickenfeed »
Ihave done well with 1/8 white oak it seems to let it breathe well enough and since it's the lid direct contact with your liquor is not necessary
Single Malt Yinzer
I want to use a barrel but I only make a .5 to 1 gallon a month or so. It would take way too long to fill and age a 5 gallon barrel. I know I don't need to fill it completely.
Chickenfeed- 1/8" oak sound like a good simple solution. I'll have to try it out.
Heartcut - If so that would be a good solution too. I'll get some and experiment.
Thanks everyone!
cranky
Post by cranky »
Single Malt Yinzer wrote:I want to use a barrel but I only make a .5 to 1 gallon a month or so. It would take way too long to fill and age a 5 gallon barrel. I know I don't need to fill it completely.
.5 gallons a month is 6 gallons a year, just saying :problem: 2 years of apples and my barrel still isn't full. If you want to age it, make enough to age and be patient. Alternatively my old way of doing it was to put it in a 1/2 gallon jar with a used stick, probably smaller than most use, leave the lid loose and put it on top of a heater vent in a seldom used room (spare bathroom) over the winter or until I thought it was done. There are lots of ways to make sure the alcohol can breath and ways to oak without over oaking.
Single Malt Yinzer
cranky wrote: and be patient.
Actually it's not patients, it's curiosity. I can't stop taking "samples". Stuff doesn't last long that way. If I scaled up it would work better but that's not going to happen anytime soon.
cranky
Post by cranky »
So turn a little barrel into a well used barrel :ewink: Fill it with a sacrificial product and let that get over oaked, then another until it works like you want.
