2" boka head + 4" column
Klein
Post by Klein »
any reason why a 2" boka head on a 4" column would not work? planning on running it at full power (5500w) the coil is ~10" long double wound 1/4" od with good flow.
i also (assuming this all should work) plan on having a 3/8" od takeoff and a 1/2" npt stainless steel needle valve. not sure if the 1/2" would be too big or not
bluefish_dist
Re: 2" boka head + 4" column
Post by bluefish_dist »
I run a 2" vm head on a 4" column. Just realize that the vapor speed will be faster between the plates. An external return might be need to limit smearing.
Formerly
Dsp-CO-20051
Klien are you talking a out a 4" packed column or a 4" plated column ?
Klein
Post by Klein »
4" packed
Just keep slowly increasing the power until either of two things happen ... Vapour will start coming out the top vent if you have exceeded the RC condensers ability to hold full reflux ...or liquid will start spurting out the vent if its flooding . I think the former is more likely to occur first ..... then back it off a bit .... this is as good as it will run :thumbup: go with it :D .... take off some product . :ebiggrin:
Klein
Post by Klein »
If it can't handle full power I might just build a 4" boka :)
Any thoughts on the 1/2"npt needle valve? The 1/2 thread works well for me. Any down side to going that big?
Re: 2
Klein wrote:...Any thoughts on the 1/2"npt needle valve? The 1/2 thread works well for me. Any down side to going that big?
If it ain't broke....don't "fix" it.....
Klein
Post by Klein »
I can get the 1/2 for the same price as the 3/8. But with the 1/2 I have the parts. I'd have to get fittings for the 3/8.
As I don't have any 1/2" needle valve I am not sure if i would loose too much control or not.
bluefish_dist
I have a 1/4 and 1/2 needle valve. The 1/4 adjusts nicely, while the 1/2 is too course for my tastes. This is on a still running 8000w. I don't run it as a pot still so I don't know if either one will flow enough for that application.
Formerly
Dsp-CO-20051
Klein
Post by Klein »
Thanks for the advice guys, I'll take a look at the 3/8 and stay away from the 1/2
