Removing some off the ID of copper
Big_Daddy
Post by Big_Daddy »
I am building a modular style CCVM/ pot still and I am doing so with 2" copper. I bought multiple ferrules that a going to be used at all of the attachment points. The ferrules are supposed to slip inside of the 2" copper and then be sodered on. My problem I'm having is that the ferrules wont fit inside of the 2" copper, and I figure the easiest way to fix this problem is to remove some of the material from the ID of the copper. I don't need to remove a whole lot, the ferrule is almost able to fit. I probable need to remove .010 from the ID. Anyone have a good way to go about doing this? I would appreciate any feedback. I am mimicking the still design that Still It uses.
Swedish Pride
Re: Removing some off the ID of copper
Post by Swedish Pride »
Put the ferrule in the freezer
Don't be a dick
StillerBoy
Post by StillerBoy »
Anneal the copper pipe, then press in the ferrule by slowly driving it in with a rubber hammer, with the other end of the pipe against a piece of wood..
Once anneal, clean the end very good of both pieces, add paste/flux, then press it in, ready to be soldered..
Mars
– Albert Einstein
Big_Daddy
Post by Big_Daddy »
Thank yall for the responses.
cob
Post by cob »
if your pipe was cut with a plumbers pipe cutter remove the lip inside your pipe and champher
the inside slightly and proceed as stillerboy suggest's, you may not even need to anneal.
using a pipe cutter compresses the copper at the cut.
Samyguy
Post by Samyguy »
did you get heavy wall copper pipe?
See if you find waste/drain/vent copper pipe,
should be of the thin wall
Big_Daddy
Post by Big_Daddy »
I believe it might be the heavy wall, I had it given to me from a plumber.
Post by The Baker »
At least one supplier has an Expanded ferrule (whatever) so the pipe fits in.
As to WHICH pipe, I dunno; I know there are differing wall thicknesses ...
HDNB
Post by HDNB »
heat the pipe and freeze the ferrule is good simple advise.
boring hone stones are a good option too, if you know someone with tools. you can micky mouse a boring hone with some emery cloth or sand paper on a dowel, reduced to fit a drill. a cylindrical metal burr will work quickly too... even in a drill motor. Of course the faster you can spin it (dremel or air tool) the faster it would work.
now i drink for evil.
Mr Sippy
Post by Mr Sippy »
I used a muffler tail pipe expander from harbor freight. Think it was $7. It worked well for me on 2in M type.
Be Kind, Tell the Truth, Sip Good Whiskey
Samyguy
Post by Samyguy »
tail pipe expander may work
or go to Menrads / Lowes try different plumbing fitings for size
I turned mine on my metal lathe/ bored I.D. to size
Longhairedcountryboy
Post by Longhairedcountryboy »
DWV slips easily on the ferrule. For thicker walled copper, I use a dremmel with an 80 grit sanding drum bit on the inside of the pipe.
Big_Daddy
Post by Big_Daddy »
It is type L. the tail pipe expander trick didn't work on the heavy wall like I was hoping it would. I wish I had a lathe, but I don't have access to one currently. I believe I am going to try and go the route of the cylindrical grinder.
Big_Daddy wrote:It is type L. the tail pipe expander trick didn't work on the heavy wall like I was hoping it would. I wish I had a lathe, but I don't have access to one currently. I believe I am going to try and go the route of the cylindrical grinder.
Anneal the end of the copper and try using tail pipe expander again
Personally I'd anneal the copper, stick the 2" over the 1-7/8" ball hitch on the back of my old truck
Then peck around the tubing with a little hammer until the ID was big enough.
Copper doesn't take too high of a temp to anneal, a gas cook stove, gas barbeque or even a small campfire will do the trick.
StillerBoy
Anneal the copper end of the pipe.. grind the end of the ferrule at a 45 degree, just a small facing grind and tap it in with a rubber mallet, with the other of the pipe on a piece of 2 x 4.. clean both pieces, flux, then press.. done
Mars
– Albert Einstein
Ya can't do it that way, because it sounds too logical :lol:
Big_Daddy wrote:It is type L...
You bought the wrong stuff. And, it's more expensive too. And you don't need anything thicker than DWV for a still.
All copper rigid pipe is the same OD. But the wall thickness varies ... from DWV (the thinnest wall), then type M, type L, and finally type K (the thickest wall).
Sometimes the "best deal" isn't actually the "best".
cob
Post by cob »
Big_Daddy wrote:I believe it might be the heavy wall, I had it given to me from a plumber.
StillerBoy
shadylane wrote:Ya can't do it that way, because it sounds too logical
You got it shady.. It is beyond me as to why the difficult in installing a ferrule.. all the best of advise has been provide.. I guess the OP take joy in give himself a hard time..
Mars
– Albert Einstein
30xs
Post by 30xs »
I know it’s a little late but, a 2” flap disk in a die grinder, or even a drill on high speed, works very well for honing out the I.D. You can find them in most auto parts stores, or welding supply stores.
Twisted Brick
Post by Twisted Brick »
StillerBoy wrote:Anneal the copper end of the pipe.. grind the end of the ferrule at a 45 degree, just a small facing grind and tap it in with a rubber mallet, with the other of the pipe on a piece of 2 x 4.. clean both pieces, flux, then press.. done
Mars
This question comes up every so often maybe someone could make a sticky along with some other soldering SOP's...
I was gifted 3" Type L copper and the freeze/anneal trick didn't work (too thick). So I took a shot (hadn't heard of Mars' solution) and did the 45* thing on the bench grinder. Worked a treat, although the ferrule got hotter than a pistol. The trick is to get the ferrule to line up square before you hit your 2x4 with a BFH.
You can see how much the ferrule caused the copper to deform. It was so tight it brought back memories of my youth, er I thought I could get away without solder until I was dutifully warned here not to do that. So I hammered the ferrule out, and it soldered up nice.
hpby98
Post by hpby98 »
Just confirming you want Type M *not* the thicker Type L copper Pipe for copper ferrules
The outside diameter will be identical, but the inner pipe thickness will eat up the space
StillerBoy
Twisted Brick wrote:So I took a shot (hadn't heard of Mars' solution) and did the 45* thing on the bench grinder.
Glad to here it worked for you..
Works every time, and it's easy.. learned the method while rebuilding two-cycle racing engines (too many years ago), and it can be applied in many circumstances..
Mars
– Albert Einstein
Windy City
Post by Windy City »
hpby98 wrote:Just confirming you want Type L *not* the thicker Type M copper Pipe for copper ferrules
Type L is thicker than Type M
From thinnest to thickest
Type DWV, Type M, Type L and finally Type K
hpby98
Post by hpby98 »
Windy City wrote:
hpby98 wrote:Just confirming you want Type M *not* the thicker Type L copper Pipe for copper ferrules
Nothing to see here :shock: move along...
emptyglass
Post by emptyglass »
make sure there are no burrs.
form a chamfer on both parts.
clean and add flux.
use some wood as a buffer and hammer it in
Solder as required.
You can get small flap wheels that will fit in a drill chuck that match the size of your tube. under $5. you can use these to enlarge the hole but you can force the parts to fit pretty easy.
once you get the parts together the trick is to solder them properly
