Would this thing work? 240v 2000w
If it plugs in, post it here.
Cagey Ey
Post by Cagey Ey »
Hi all, I'm seeking the opinion and expertise of the learned members of this board to take a look at this part and tell me if it might work to control a 240v 2000w element.
https://www.lazada.com.my/-i500566447-s ... =true&mp=3
All the parts are visible though its a little hard to see whats written on the part connected to the heatsink. Long story short, I don't want to burn the house down. Any assistance is much appreciated and thank you in advance.
~Cagey
Re: Would this thing work? 240v 2000w
I haven't used that exact one, but it is probably ok. My preference is to use a controller that is more than capable of handling the Watts I use, so if they have a 4000W model, I suggest you get that.
Cagey Ey
Post by Cagey Ey »
Good point. May as well ere on the side of overkill. Just might go with one rated for 10kw :D
Thanks for the tip!
~Cagey
StillerBoy
Post by StillerBoy »
cagey.. what country are you located in.. as there are better unit that one..
Mars
Ok I found the answer.. SEA like Chris said, get a bigger unit if you can..
– Albert Einstein
Cagey Ey
Post by Cagey Ey »
Sure, I'm leaning more towards this one now, as it leaves me with plenty of leeway for upgrades. 240v 10kw though I guess a 4kw would do for now...
Not sure if inserted that picture right...
~Cagey
