Rasin bran
Rasin bran
Started a sacrificial batch today, needed for trying out new still. Plan was to make up a batch of sugar water and ferment, however reading on here i realized i need more then sugar. Planned to add cornmeal but was all out. Used a box of raisin bran instead. 8 gallon batch with 12 lbs of sugar, lemon juice, 1 box raisin bran, little bit of molasses. Started smelling pretty good reason i added the molasses. Smells really good right now. May have to try this again when not sacrificial batch. Has anyone tried something similar and if so how did it turn out?
Re: Rasin bran
Well, sorta. I made up something similar (a sacrificial batch, full disclosure in case the corn picker chimes in later). Worked out nice.
viewtopic.php?f=58&t=76913
The struggle is real and this rabbit hole just got interesting.
- Just 4 Fun
Re: Rasin bran
Actually I do raisin bran quite often,I find it ferments quickly and easily while tasting a lot like “makers mark “ wheat whiskey.
Unlike cornflakes where I sometimes have stalled ferment and have to add DAP raisin bran works off every time without a hiccup.
I run it first through the big still then run the “low wines” through my small still with a thumper cutting it off when it hit 50% to avoid fusel oils coming over.
Just because it's called a liver doesn't mean it lives forever.
Re: Rasin bran
Ran it off. It does have a different flavor. I used wine yeasts and it came out as tasting like milk that i added grape flavor to it with a strong brandy smell. Will run again to clean it up and see if it improves. It fermented slow due to cold temps in my area.
Re: Rasin bran
I hope your not drinking your sacrificial run.Jr-dist wrote: ↑Sat Feb 15, 2020 2:55 pmRan it off. It does have a different flavor. I used wine yeasts and it came out as tasting like milk that i added grape flavor to it with a strong brandy smell. Will run again to clean it up and see if it improves. It fermented slow due to cold temps in my area.
Re: Rasin bran
No bought some cheap vodka for that. This was suppose to be the sacrifice but wanted practice. So i ran vinigar, then water, then vodka. Vodka came out like it came in so then ran the raisin bran rum.
Re: Rasin bran
Had it on oak. Gave it a nice color and has a brandy like flavor.
