FermPro 900
8Ball
FermPro 900
Post by 8Ball »
Picked up some FermPro 900. From the manufacturer’s website:
Product Description
(Optimum temperature 80-95°F)
This high performance distillers yeast is a popular strain at numerous distilleries. The origin is a whiskey strain well suited for Bourbon or rye whiskeys, offering excellent yields and a robust flavorful congener profile. It is well suited for normal or cooler fermentations, allowing for extended fermentation times. Works well up in the mid 20 Brix range.
Suggested usage: 1 gram of yeast per gallon of mash
So I made an all grain Irish style mash yesterday. 16 pounds in 7.5 gallons water. The usual adjuncts and conversion was optimal. I aerated the mash overnight to add O2 and to facilitate cooling.
Made a yeast starter yesterday when I started the overnight cool down to pitch temperature: 16 grams of FP900, 24 oz water, 4 oz wort, pinch of Fermax, hydrated at 85F.
Good foamy cap in about 15 minutes.
This morning (18 hours later), I pitched the yeast starter.
Temp: 75.7F (a little cool), ph 4.86, SG 1.071.
4 hours later, no yeast activity at all. Flat, no bubbles, dead. So I measured out another 18 grams of FP900, and sprinkled it directly on top of the wort. One hour later and I have a good foamy grain cap going and the temperature is rising due to an active ferment.
So, FWIW, I’ll be pitching the FP900 yeast starter soon after I hydrate the yeast from now on. Apparently this stuff likes to get right to work upon being hydrated.
Texas Jim
Re: FermPro 900
Post by Texas Jim »
Why did you pitch so much yeast? The FermPro directions are 1 gram per gallon. You did about 2.5.
Do you get better results overpitching?
8Ball
Re: FermPro 900
Post by 8Ball »
Texas Jim wrote: Mon Apr 06, 2020 12:46 pm Why did you pitch so much yeast? The FermPro directions are 1 gram per gallon. You did about 2.5.
I actually under pitched by a half with this yeast because of the manufacturer’s dose recommendation of 1g/G.
My OG was 1.071, I use 0.05 grams per point/gallon.
(71*7.5*0.05)=26.625 grams
26.625*1.5= 39.9375 grams is what I would pitch if I was using bakers yeast.
I do a very long, natural, open fermenter, cool down to pitch temperature with my all grains, usually 18 hours or more. This maximizes the conversion since I throw a little gluco enzyme in for insurance. Since I don’t like my wort to get infected, I throw a lot of yeast at it to discourage bacteria growth.
So far, so good. I have good, clean, on the grain ferments that finish dry in about a week or so.
StillerBoy
Re: FermPro 900
Post by StillerBoy »
8Ball wrote: Mon Apr 06, 2020 4:16 pm I actually under pitched by a half with this yeast because of the manufacturer’s dose recommendation of 1g/G.
What formula do you use for calculating the amount of yeast to use.. what you have stated make no sense.. and your fermenting temp is off big time, 75*F is cold for that yeast..
The company states " 1 g per gallon and fermentation range is 80 - 95*F
So that mean in my book, 7.5 -8 gr of yeast for a 7.5 gal batch, and I would ferment at 85*F, which is mid range, and usually the best range..
Mars
– Albert Einstein
8Ball
Re: FermPro 900
Post by 8Ball »
I use 0.05 grams of yeast per point gallon. The formula is in my earlier post. The FP900 is rated for cooler temps, so yea a little cool to start, but I was fermenting outside in ambient cool weather. It worked fine, so not too cold like you assume. Lend me your book, I’m running short on TP.
Texas Jim
Re: FermPro 900
Post by Texas Jim »
I was going by their dosage recommendations on their data sheet of 1 gram per gallon of mash. I've seen your formula at brewsites, but I just go by the pitching rate they state on the package.
As long as it works.
8Ball
Re: FermPro 900
Post by 8Ball »
I think a lot has to do with the specific gravity. Somewhere between 2 to 4 grams per gallon.
