Woke up to a sticky mess all over the floor of the carport.
This brute is about 3 years old, so...
I guess it's time to replace it.
Maybe a little flex seal?
Lol
The lid doesn't fit tightly enough to build pressure.Birrofilo wrote: ↑Wed Apr 22, 2020 5:52 am Did you have an escape for CO2?
It might be that the bubbler clogged and the pressure broke the vessel.
You should use a very large bubbler for that amount of mash. That will cost you $10 but will save you money in the long run
Or maybe you could set a blow-off for the first couple days of fermentation, and then put the bubbler on.
I bet the SOH is very happy with you today, right?Hillbilly Popstar wrote: ↑Wed Apr 22, 2020 5:29 am...Woke up to a sticky mess all over the floor of the carport...
Yep...that stuff will keep a canoe afloat after it has been cut in half with a chainsaw!Hillbilly Popstar wrote: ↑Wed Apr 22, 2020 5:29 am...This brute is about 3 years old, so...I guess it's time to replace it....Maybe a little flex seal?
Yeah, thank God it was outdoorsstill_stirrin wrote: ↑Wed Apr 22, 2020 6:35 amI bet the SOH is very happy with you today, right?Hillbilly Popstar wrote: ↑Wed Apr 22, 2020 5:29 am...Woke up to a sticky mess all over the floor of the carport...
Oh...wait...you said, “car port” and I read, “carpet”. Big difference!
I understand it's a mash, but if you leave it overnight in the open it might cool down, ferment and create inside pressure. Plenty of sugars inside there. That's the way humanity discovered beer, by leaving grains soaked in water and finding they bubble and become pleasantHillbilly Popstar wrote: ↑Wed Apr 22, 2020 6:30 am
At any rate, this wash just a mash, not a ferment.
Ain't no fermentation happening at 185*.
That sucks! Makes me worried for my brutes.Hillbilly Popstar wrote: ↑Wed Apr 22, 2020 5:29 am Put this baby to bed last night all snuggled in a comforter at 185*f.
Maybe a little flex seal?![]()
No doubt some.higher quality vessels are in my future.still_stirrin wrote: ↑Wed Apr 22, 2020 9:16 am Perhaps you need to invest in one (or 4) of these: https://www.uline.com/Product/Detail/S- ... lsrc=aw.ds
Or, if you want to shop for used barrels, try this one: https://www.usedstainlesssteelbarrels.c ... l-barrels/
Never kept them out in the sun. Dont recall any change in the finish or texture of the can.SaltyStaves wrote: ↑Wed Apr 22, 2020 12:42 pm Looks like UV damage. Was it high gloss when it was new?
Not that I know ofstillanoob wrote: ↑Wed Apr 22, 2020 6:21 am Being new to this, is putting 185 degree mash into a Brute trash can common?
There are plenty of members in here that mash in Brute cans.shadylane wrote: ↑Wed Apr 22, 2020 7:13 pmNot that I know ofstillanoob wrote: ↑Wed Apr 22, 2020 6:21 am Being new to this, is putting 185 degree mash into a Brute trash can common?
Sorry for your loss.Hillbilly Popstar wrote: ↑Wed Apr 22, 2020 9:25 am
But considering the Brute lasted 3 years, I think I can justify purchasing another one.
This time I will upgrade to a 30 gallon.
Oh dear.seamusm53 wrote: ↑Wed Apr 22, 2020 9:49 am Nothing to due with pressure. No plastic lasts forever. Add in heat and then alcohol leaching out the plasticisers and this was probably predictable. PTL this was in a carport and 'easily' cleaned or hosed down. On the bright side, it lasted 3 years and many? ferments and wasn't/isn't expensive.
My thoughts too. I've only mashed in plastic once in thirty years. A small experiment a week ago that still hasn't been stripped, (and that was only because there were no SS vessels available at the time and I was impatient).
Well, that's worrying.
