plastic carboys
Odinson88
plastic carboys
Post by Odinson88 »
I have (and use) glass carboys, however I also have a couple 5gal water jugs (for water cooler things). However, normal bungs are too small for these. anyone have ideas/experience in making an airlock system for these, and willing to share?
Expat
Re: plastic carboys
Post by Expat »
Odinson88 wrote: Sun Apr 26, 2020 7:07 pm I have (and use) glass carboys, however I also have a couple 5gal water jugs (for water cooler things). However, normal bungs are too small for these. anyone have ideas/experience in making an airlock system for these, and willing to share?
Just loose fit a cloth over the opening. Airlock not required.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
Odinson88
Re: plastic carboys
Post by Odinson88 »
Expat wrote: Sun Apr 26, 2020 7:11 pm
I thought the yeast would die young or it would make vinegar without airlock
Re: plastic carboys
Post by The Baker »
Carbon dioxide sits on top and forms a barrier.
Truckinbutch
Re: plastic carboys
Post by Truckinbutch »
What they said . TB
Odinson88
Re: plastic carboys
Post by Odinson88 »
pantyhose or cheese cloth enough, or more like tea towel weight?
Re: plastic carboys
Thicker is better, but if you are intending to distil as soon as it's ready, it doesn't make much difference.
If not, it should be airlocked.
Canuckwoods
Re: plastic carboys
Post by Canuckwoods »
More brew stores have the larger bungs if you really want one.
StillsNMash
Re: plastic carboys
Post by StillsNMash »
I use thr lids, dril a little hole and use the 1 way air valves for aquariums. If the ferment is just right, it whistles! Hahha!
BlackStrap
Re: plastic carboys
Post by BlackStrap »
https://www.amazon.com/10-1-Rubber-Stop ... 50&sr=8-19
10.5 airlock stopper will fit a 5 gallon plastic carboy
The one who cuts the firewood gets twice the warmth
Durhommer
Re: plastic carboys
Post by Durhommer »
A rubber band and coffee filter work
BoomTown
Re: plastic carboys
Post by BoomTown »
This is how I stopped my carboy wash:
Re: plastic carboys
Boom you need to fix your attachment!
BoomTown
Re: plastic carboys
Post by BoomTown »
Bushman wrote: Mon May 18, 2020 8:27 am Boom you need to fix your attachment!
Yeah, being brain challenged and working from an iPad makes the seemingly simple surprisingly complex. I give up, till I can master this cute little iPad iOS and it’s wrinkles...
Re: plastic carboys
BoomTown wrote: Mon May 18, 2020 9:45 am
Go to the pencil icon on the post, this will allow you to edit it. Then at the bottom of the post choose attachments. Choose add file, then choose photo library. From here select the photo and it will probably already place on your post otherwise choose Place inline.
This should work.
StillsNMash
Re: plastic carboys
Heres my aquarium valve stopper. It feeds a line into a water jar to check progress. Yes, not as easy as the other bungs, but this was free. More $$ for goodies, even if $2.99. Lol.[IMG]https://uploads.tapatalk-cdn.com/202005 ... b0b100.jpg[/IMG]
