Variable voltage regulator
Ok fellers.
I want to get electric
But what i am looking for is a simple,
"dial up" more power
"dial down" less power
Would this be ok for my use
I run strictly by touch.no therometers etc.
Been stilling for 4-5years but would like the convenience of electric
Any input is appreciated
Thnx
Duke
Thnx
Duke
- 6 Row Joe
Re: Variable voltage regulator
How big of a pot and how large of a element are you planning?
Got a 16 gallon keg
Was planning on 5500 watt output
Got a 16 gallon thumper also
But don't use it much
Got a bunch of 7 gallon kegs
As far as the element
As big as possible
As big as possible
hello,
I am a novoice/new to distillation but unlikely by profession)) i am engineer so in my opinion this thing will surly work to step down the heating power. But what i recommend, you install two heaters of 3000watt heater rather then a big single 5600watt. This way in the initial rum switch on both heaters and after some time switch off one and control the boiler with voltage regulator mounted on one 3000 watt heater. this way you have much flexibility and control over heating. I hope it make sense.
cheers
cheers
In search of Dream whiskey.................
Thnx ravi
I like your idea
I found a thread in the electrics section on this subject.
But your point wasn't mentioned
What i want is manual control but in electric
I like your idea
In the distilling community we refer to what you seek as power controllers. You can buy parts and build your own, you can buy a kit and build your own and you can even buy off the shelf power controllers. Check the capabilities of your wiring at home before deciding on size and number of elements.
Modular 2" Pot Still
That will work
And a small fan will make it last longer
I the system i told, you will going to have manual control with electric. like: two heater 3000watt one is hooked with variable voltage controller(the one you find on amazon) and other is with simple on off switch. During the initial startup of boiler when we need much heat out put at that time you switch on both heater at full then after some time switch off one heater by on/off switch and other which is hooked with variable voltage controller with that you can control the heating manual by knob provided on it in front.
I think point need to taken care is:
1) chose the right voltage regulator it must be well equal or little bit above the rating of your heater(3000watt)
2)check your household circuit rating. it mush capable of handling 6000 watt load.
3) wire sizing.
4) earthing
hope it will help.
cheers
3) wire sizing.
4) earthing
hope it will help.
cheers
This controller kit is the best value I've ever come across. Good quality and I've built multiple controllers using these parts. I used my own enclosures and added some bells & whistles like a fan, switches, 110V outlet with switch and stuff like that.
Agreed,but in canadian dolllars,i can source it cheaper up hereNineInchNails wrote: ↑Fri May 15, 2020 11:45 am This controller kit is the best value I've ever come across. Good quality and I've built multiple controllers using these parts. I used my own enclosures and added some bells & whistles like a fan, switches, 110V outlet with switch and stuff like that.
Duke.. why not build one from parts, and customize it to your needs.. this thread is about the best on building one..
viewtopic.php?f=85&t=51796
Mars
Mars
– Albert Einstein
– Albert Einstein
Agreed marsStillerBoy wrote: ↑Fri May 15, 2020 2:26 pm Duke.. why not build one from parts, and customize it to your needs.. this thread is about the best on building one..
Mars
But now sourceing is shit
So either i wait
Or pay us shipping etc
You understand
Damn covid
