Cuts by colour
jedneck
Re: Cuts by colour
Post by jedneck »
StillerBoy wrote: Sat May 30, 2020 2:32 pm
Afshin_sam89 wrote: Sat May 30, 2020 1:19 pm I want to know this jars are tails or this jars is head, you know,I want to know how can I understand that our heads is finish and then hearts is start.
Before this can be answered, this has to be answered..
What style or column design do you have to work with..
Mars
Type of still has zip zilch nadda to do with makin cuts. Gotta use senses to tell what is keep n what is shyte
big help
Dunder
StillerBoy
Re: Cuts by colour
Post by StillerBoy »
jedneck wrote: Sun May 31, 2020 7:27 am Type of still has zip zilch nadda to do with cuts.
I will disagree on that one for sure..
Pot still cuts are much different than on a reflux column..
Mars
– Albert Einstein
jedneck
Re: Cuts by colour
Post by jedneck »
But still need to use senses to make them.
big help
Dunder
StillerBoy
Re: Cuts by colour
jedneck wrote: Sun May 31, 2020 7:49 am But still need to use senses to make them.
In agreement there.. smell and taste are still require to blend the finish product..
I should of clarified my statement on cut.. cuts are still a requirement to be done.. it's the amount collected per jar that is different ..
For a pot still collection, one is pretty well limited to collecting the same amount per jar, unless one has some means of identifying where the run is at.. whereas with a reflux column, since a reflux column allows one to compress, amount collect per jar will different, again providing on has some means of identifying where the run is at..
Mars
– Albert Einstein
StillerBoy
Re: Cuts by colour
Afshin_sam89 wrote: Sat May 30, 2020 1:19 pm I want to follow any mathematical method as I wrote for amount spirit run.
It's what has been outlined in my previous post.. and you have a pot still setup..
So determine the potental amount of alcohol extractable from the run (boiler load), then select the amount per jar you want to collect in each.. then once the run is done, let it air for a day or so.. then start in the middle and work back one jar at a time.. reduce a small sample, smell taste.. then do a blend of the ones you think are good based on your taste..
Research making cuts, as there are many thread on the subject..
Mars
– Albert Einstein
Re: Cuts by colour
Heres what it looks like in reality . viewtopic.php?f=15&t=68702#p7500094
StillerBoy
Re: Cuts by colour
Thanks Yummyrum..
Had those thread listed in my files, but a few months back, lose the data on my hd as it died on me.. in the process of rebuilding the data, but lots still missing and a pain to rebuild..
Mars
– Albert Einstein
Afshin_sam89
Re: Cuts by colour
Post by Afshin_sam89 »
StillerBoy wrote: Sun May 31, 2020 8:50 am
Mars
Hi dear Mars
Thank you Thank you so much.
Afshin_sam89
Re: Cuts by colour
Yummyrum wrote: Sun May 31, 2020 1:16 pm Heres what it looks like in reality . viewtopic.php?f=15&t=68702#p7500094
Hi dear Yummyrum
thank you for information
