I am a retired Chemical Engineer whose work for 40 years in the industry involved the design, startup and optimization of various commercial operations. A major part of this work was to develop a computer simulation model of the chemical process and use it to guide the work.
These last 10 Covid months of I have been going back and redoing some of this work, and then in July, I stumbled on batch distillation and became interested in ethyl alcohol (moonshine) distilling calculations. I first modeled the pot still operation and got good agreement with the calculations of this forum and with Hugelwilli of hobbybrennan.ch.
Then I became hooked
I will discuss the model details and run data examined in future posts for those interested. It is based on basic chemical engineering theory for mass transfer, heat transfer and VLE. It predicts the pot and thumper gallons output, instantaneous %ABV and cumulative %ABV, pot and thumper liquid contents,volume and temperature, pot KW and more during the course of the run. Input data is only starting pot and thumper gallons and % ABV, and the run length (time).
The data and model covers this range:
Pot: 4 to 13 gallons and 0% to 40% ABV
Thumper: 0.5 to 12 gallons and 0% to 40% ABV
Yes, the pot can be used as a steam stripper. Need some run data on this though. Many combinations of the above have worked. No prediction of the cuts is made, but from the current %ABV made one could foresee when the tails might start. The model agreed with %ABV data +/- 2% of the value and agreed with gallons out within 5% (ie, 3 gal +/- 0.15gal) on average.
The model can be used to plan runs, estimate gallons out and %ABV out vs run time, see if thumper pukes, see the effects of changes in starting gallons and %ABV, see what KW is required, etc.
I will provide nice graphs of the results in the next post. It is neat to see how fast or slow the %ABV decreases during the run depending on the starting conditions. Only the pot, thumper and worm/condenser are included, no columns.
Of course, experience is the best teacher and most of you distillers have that and use it. But there are many novices whom this model might help, and the experienced users can test new ideas.
So, I hope to hear from the forum if there is interest in pursing this model forward. More run data is very helpful, please supply starting conditions as above and some data on gal and %ABV condensed along the way. Other information on pot and thumper volume (gal) at end is good also.
The model will be updated/improved. People need to test it and approve it, etc. Ultimately, if all goes well we could include it in the Calculations section of the forum.
For now, I would be glad to run and test the model for anyone that requests it and get results back to them.
Thanks,
haggy
I better give some results.
Input data: Pot 6 gal at 11%ABV mash Thumper 3gal at 11%ABV mash
See the figures. Do not have labels on the graphs - See the top heading and figure out the symbols. Hope the graphs show.
