Well my criticism is it is too popular and we cant get the Wheat Bran from Woolies!!!!
No problem, we grow rice, and I'm using rice bran from the mill down the village...
I did use oat bran a couple of times, was all I could get. Worked okNZChris wrote: ↑Sun Mar 14, 2021 10:48 pm I suspect any bran will do. I don't particularly like the flavor of wheat in fermented products, distilled or not, so my experiment with wheat bran only used a fraction of the bran that Teddy used. It fermented well and distilled well, but I see there is still plenty of it in the cellar, so that's a good indication that I make other products that I prefer to use.
From what I have read, a second reflux may improve your product and it may remove some of the flavours if that is what you want.
This method is more of a wheat vodka than a neutral, so if you don't like the wheat, it might not be a good choice for you. I do a version with an eighth of the bran and it still has some wheat flavor after the reflux run.
Thanks NZChris, the reason that I asked this question is because I compared it with other commercial wheat vodka's I do not know why they call them "wheat vodka" since there is actually not any flavor left from it, so I wondered whether I should run it twice in reflux, but that will further take away the wheat flavor, I like wheat but not too strong maybe next time I will keep the amount lower to see if that will make a difference.
Hi,NZChris wrote: ↑Wed Apr 07, 2021 10:45 pm If you need to run any wash through a pot still and then twice through a reflux still to make it usable, you have a problem with the wash or the still, or are being greedy with your cuts.
If it's only the intensity of the wheat flavor that you don't like, blend it with your finest neutral.
Only you and your drinking buddies can answer that question. If the level in the bottle in your drinks cabinet is still high after a year, re-distill it. If you have refilled it several times, don't fiddle with it.
This may answer your question, I have a Gilbey's Vodka bottle in front of me, and it says three times distilled... I followed that Ted's Fast Fermenting Vodka great recipe, but using rice bran from the mill down the village instead of wheat bran, my still is a Ø 3" VM, the final product is really neutral, it's also a matter of cuts. I made three 69-litre batches (69=3x23, basic recipe), stripping run for each batch, then one spirit run in my VM reflux still.
I'm not really a Vodka fan either, but I wanted a reliable recipe to get a basic neutral for my Gin and my Pastis...
Well All producers claim many things but in reality that could differ I have a crystal head vodka which claims 7 times distilled, this could be a marketing stunt, or they use many plates and count each plate 1 distillationGarouda wrote: ↑Thu Apr 08, 2021 7:28 pmThis may answer your question, I have a Gilbey's Vodka bottle in front of me, and it says three times distilled... vodka.png
Thanks Teddysad,Teddysad wrote: ↑Fri Apr 09, 2021 12:27 am My standard routine is to strip, then run through a flute with 4 bubble plates and a packed section. I guess this means 6 times distilled. However I do not carbon filter and this produces the best result still giving a wheaten character/flavour for which this recipe was designed
Hi Teddy,Teddysad wrote: ↑Fri Apr 09, 2021 12:39 am I use filtered tap water for the mash and proofing down , however your local water composition may affect this. Mine is pretty good with no chlorine. If the wheat flavour is too strong for you cut back the wheat bran. However it is the inherent character it adds which makes it so much better that say a bland TPW
Though it is possible to invert sugar with just heat, adding citric acid speeds up the process and ensures a more complete conversion from sucrose to glucose and fructose. I used more citric acid than the receipy called for in order to ensure a complete conversion of the sugars. The 2 simple sugars are easier for the yeat to consume, thus theoretically the yeast will be less stressed and produce a cleaner flavour. There has been much debate on this topic. In my case I have actually always inverted and have not tried table sugar as is at all. I don't find the process of inverting all that difficult and decided in the beginning after a lot of reading to just go ahead and invert all my sugars.howie wrote: ↑Sat Apr 10, 2021 6:54 pm jakeb
is the citric necessary for sugar inversion? (never done inversion)
i think that 1 tbsp of citric acid would lower the PH quite a lot, then you are adding more chemicals to raise the PH.
seems counter productive to me.
i put 2 x 25l FFV on yesterday and i tested the PH before pitching yeast as usual.
both were PH of 7, so just 1/2 tsp of citric acid dropped the PH to 6.
my way of thinking is to test the PH and only adjust if necessary, not blindly add it because it's in the recipe.
TBH i've had to put 1/4-1/2 tsp in all the 25L FFVs i've done.
Hi artooks, thanks for the insight. I switched from baker's yeast to champaign yeast based on advise from someone working in a brewers supply store. In addition to increasing time, I will admit it also increased the cost, to the benefit of the brewers supply shop I might add. I did birdwatchers several times as well as Shadey's sugar shine as per the recepoes exactly as posted and found I get a yeasty taste (not so much smell) that I was just not happy with. I explained the issue to the fellow at the brewers supply and he suggested EC-1118. When I tried that, the result was much cleaner in both cases, so I have switched to champaign yeast any time baker's yeast is called for recently. As far as inverting sugars, like I said I have not tried regular table sugar at all. I have a couple project batches on the go but will eventually try 2 batches side by side identical except sugars to see for myself how much difference there really is. I have been interested in distilling all my adult life, and reading about it since before there was an internet, but I am brand new at actually running a still. I purchased the dreaded T500 a little less than a year ago. Despite what I read about it on this site, it is convenient for me with some space limitations and a good way (in my opinion) to get started. I find that it produces pretty good results in reflux as it is intended when you disregard most of the instructions that come with it and run a good clean wash making cuts by cooling output temp and offtake speed (also separating, airing and checking cuts before blending). I have not even tried any turbos or carbon polishing based on what I have read. In reflux I find I get consistent results after the first 500ml or so of heads (100ml very slow of foreshots, then 300 - 400 ml until the acetone and fire of heads fades all the way out), I get 93% ABV pretty much all the same then it switches to tails pretty abruptly. I also use it as a pot still by removing packing and using offtake speed not cooling output temp to gage my adjustments. I have so far only done stripping runs then spirit runs when using it in pot still mode to make whiskey. In reflux mode (for neutral spirits) I have been getting 93% ABV through the run, a little higher as the heads come off, it dips lower just after I get to tails. I'm not sure I am that much of a believer in stripping runs when running reflux since you can always adjust your reflux ratio to obtain additional distillations. I will eventually try that in side by side same bathes to test that for myself though. I suspect the main difference will be in efficiency. For all of my reflux runs so far, the result has been very clean as far as heads or firey bite goes, but with baker's yeast, there has been some yeasty flavor left that I am not fond of.artooks wrote: ↑Sat Apr 10, 2021 8:47 pm Dear JakeB,
I have been using Baker's Yeast with great success, if you are not getting the results that you are looking for, maybe it could be that you are changing the recipe in some ways to what you think it is. correct, please try the recipe as it is and see if you like it, using wine yeast will increase the duration which for me is unnecessary, I did this recipe and it went dry in 3 days, I did not experience any yeast smell at all, the only thing for me is that the wheat flavor was very intense to my liking, I also did inverting sugar in the past, and now I find it an unnecessary and time consuming step the reason I say this is because there was not much difference in the end result, what type of still you have ? do you make a stripping run with a pot still then do reflux ? if so what ABV are you getting out of it, I find that if you could get near azeo than. there should not be any yeasty taste, so in my belief Baker's Yeast is a really good fast fermenting yeast for distillation.
Dear JakoB I sent you a PM, since these topics are out of the scope of this thread.JakeB wrote: ↑Sat Apr 10, 2021 9:54 pmHi artooks, thanks for the insight. I switched from baker's yeast to champaign yeast based on advise from someone working in a brewers supply store. In addition to increasing time, I will admit it also increased the cost, to the benefit of the brewers supply shop I might add. I did birdwatchers several times as well as Shadey's sugar shine as per the recepoes exactly as posted and found I get a yeasty taste (not so much smell) that I was just not happy with. I explained the issue to the fellow at the brewers supply and he suggested EC-1118. When I tried that, the result was much cleaner in both cases, so I have switched to champaign yeast any time baker's yeast is called for recently. As far as inverting sugars, like I said I have not tried regular table sugar at all. I have a couple project batches on the go but will eventually try 2 batches side by side identical except sugars to see for myself how much difference there really is. I have been interested in distilling all my adult life, and reading about it since before there was an internet, but I am brand new at actually running a still. I purchased the dreaded T500 a little less than a year ago. Despite what I read about it on this site, it is convenient for me with some space limitations and a good way (in my opinion) to get started. I find that it produces pretty good results in reflux as it is intended when you disregard most of the instructions that come with it and run a good clean wash making cuts by cooling output temp and offtake speed (also separating, airing and checking cuts before blending). I have not even tried any turbos or carbon polishing based on what I have read. In reflux I find I get consistent results after the first 500ml or so of heads (100ml very slow of foreshots, then 300 - 400 ml until the acetone and fire of heads fades all the way out), I get 93% ABV pretty much all the same then it switches to tails pretty abruptly. I also use it as a pot still by removing packing and using offtake speed not cooling output temp to gage my adjustments. I have so far only done stripping runs then spirit runs when using it in pot still mode to make whiskey. In reflux mode (for neutral spirits) I have been getting 93% ABV through the run, a little higher as the heads come off, it dips lower just after I get to tails. I'm not sure I am that much of a believer in stripping runs when running reflux since you can always adjust your reflux ratio to obtain additional distillations. I will eventually try that in side by side same bathes to test that for myself though. I suspect the main difference will be in efficiency. For all of my reflux runs so far, the result has been very clean as far as heads or firey bite goes, but with baker's yeast, there has been some yeasty flavor left that I am not fond of.artooks wrote: ↑Sat Apr 10, 2021 8:47 pm Dear JakeB,
You mentioned the wheat flavour being too strong, I think that at least the way I have been doing things so far, I will get a fair bit of wheat coming through, hopefully I like it, if not, I guess I could try blending with a Shadey's run to reduce it, or adjust the amount of wheat bran to my taste. The problem I found with Shadey's (after swapping yeast) was a lack of character. For bw I find the tp adds something that is similar to the yeast taste I don't like even when I swap out the yeast. When I searched the mash bill of commercial vodkas, I found a lot of the better ones use grain, many of them wheat. That is what led me to try this recipe, hopefully it works out. Thank you for your comments, the sharing of knowledge is what makes this site great.
fair enough.JakeB wrote: ↑Sat Apr 10, 2021 8:23 pmThough it is possible to invert sugar with just heat, adding citric acid speeds up the process and ensures a more complete conversion from sucrose to glucose and fructose. I used more citric acid than the receipy called for in order to ensure a complete conversion of the sugars. The 2 simple sugars are easier for the yeat to consume, thus theoretically the yeast will be less stressed and produce a cleaner flavour. There has been much debate on this topic. In my case I have actually always inverted and have not tried table sugar as is at all. I don't find the process of inverting all that difficult and decided in the beginning after a lot of reading to just go ahead and invert all my sugars.howie wrote: ↑Sat Apr 10, 2021 6:54 pm jakeb
