Good news, everyone
During my experiments I found out that it would be very useful to easily find/calculate Volume of product in Cans, Jars, whatever can contain liquid.
If Jar is full or have some kind of metering lables it helps, but in case precise numbers are needed I always had to use laboratory glasses.
So I came to idea of using scales to get weight of product, then calculate its volume.
Math is not complex, but not obvious. Before I used excel tables for that, but now...
Now I'm proud to present all of you my fresh Gross2Volume Calculator.
Available on iOs,iPadOs(Apple M1 also works). Free of charge, Free of advertising, no user data collecting.
https://apps.apple.com/ru/app/gross2volume/id1610250378
Using is as easy as weighing stuff.
1. Weigh your empty tare( Tank, Cup, Can, Jar, whatever)
2. Put some product inside
3. Weigh tare with product.
4. Measure strength of product.
5. Enter values to calc
6. Get your answer.
Weights can be entered as Kilograms or LBS
Volume is always Litres
Calculations done assuming temperature is normal (20 degree centigrade)
Hope you will find it as useful as I did.
Volume Calculator by Gross Weight
- Ben
Re: Volume Calculator by Gross Weight
This is the standard method the pro's use for taxation. Good job!
