That won't work. The goal is to be efficient in time and energy, 190 proof out the top, and 212 Temps in the boiler. This implies very low alcohol out the bottom.Corerftech wrote: ↑Tue Jun 07, 2022 5:20 pm So the water levels are poorly drawn but suffice to say they will be arranged so that the order of flow and level is appropriate. Also the interconnect between the boiler and passive radiator (seemed like an appropriate name for it) would be intimately short to ensure lowest heat loss. Basically conjoined at a specific angle and part of a “structure” for the whole system. The third waste vessel might be best used for the preheat coils which could be pretty huge in surface area. If heat is good for the second column, then retention is mandatory. Preheat wouldn’t start until the passive rad vessel was overflowing with nearly full boiling water.
I am not an artist! If it was a schematic it would be vastly better.
PID will control boiler, I like using PID for everything. Lead pots, my heat treat kiln for casing gun parts, everything that gets hot!
I’d like to employ two added thermocouples at top of columns to be able to chart temps. May help return to a quiescent point faster of visualize a lack somewhere. I’d add more later too, never can have too much data.
What you have is a so so stripper and a pot reflux column on the right. The right side pot will require 3 times the energy.
Instead you could have a pump that lifts the liquid at the bottom of the right column to the top of the left column. And have your vapor from the left colum go to the bottom of the right column.
