Well water
Tworude
Well water
Post by Tworude »
I'm 80 miles from the nearest road and about to get started distilling. My well water has about 3.3 ppm iron which is just high enough to turn a rusty color after it sits a while. It tastes like iron. For drinking we run it through a berkey carbon filter system and it's great after that. I assumed that I'd have to go through that time consuming process to have water for spirits but I'm thinking that there is a possibility that the minerals in the water will distill out and never reach the top of my column. I mean, you make distilled water that way, right? What do you guys think? Thanks
tjsc5f
Re: Well water
Post by tjsc5f »
The iron will definitely get left behind in the boiler, it won't make it up the column and into the distillate. I'm not sure if it will effect the yeast during the ferment or not though.
hawkwing
Re: Well water
Post by hawkwing »
Try a test run and see what happens. The minerals won’t pass through the still unless it pukes.
Is iron your only concern or do you have sulfur compounds? You might want to boil the water to sterilize it if you won’t be during the mash.
Re: Well water
tjsc5f wrote: Mon Aug 01, 2022 11:58 am The iron will definitely get left behind in the boiler, it won't make it up the column and into the distillate. I'm not sure if it will effect the yeast during the ferment or not though.
But, the iron is not good for yeast. It will make fermentation slow, if not impossible, depending on the other “hardness” you have besides the iron.
I would definitely filter it out with a good whole house filter. It doesn’t have to be an R.O. filter (which would be destroyed by the iron anyway). Just use a good 10 micron fiber filter. But, chances are you’ll need to replace it if you filter a lot of water, although your iron content isn’t as bad as some wells produce.
As a side note, I recently had to replace my irrigation (down hole) pump because it became iron-fouled after 10 years of service. Dang thing looked like a rusty chunk of metal and it was a stainless steel housing. Expensive replacement too.
bunny
Re: Well water
Post by bunny »
Tworude wrote: Mon Aug 01, 2022 11:26 am What do you guys think? Thanks
Start collecting rain water.
Salt Must Flow
Re: Well water
Post by Salt Must Flow »
You could use a Reverse Osmosis unit to filter the water. I install a mini float valve in a 55 gal poly drum along with a 1-1/2" ball valve as a bottom drain. I run the RO unit the night before I know I'm doing to do a wash/mash.
Re: Well water
bunny wrote: Mon Aug 01, 2022 12:49 pm
What he said :thumbup: also IMO , the best stuff for cutting down proof
Archee72
Re: Well water
Post by Archee72 »
As long as he has a reasonable average rainfall where he lives?
bunny
Re: Well water
Post by bunny »
It's difficult to help without more info of your part of AK.
Did you happen to be there when your well was sunk?
Do you know if you past any water at a lesser depth?
It might be possible to sink a shallow well by hand and find a reasonable supply of water unless you are on bed rock.
Any small creeks or streams in your neighborhood?
A lot of possibilities there.
Good Luck
cob
Re: Well water
Post by cob »
Salt Must Flow wrote: Mon Aug 01, 2022 1:17 pm You could use a Reverse Osmosis unit to filter the water. I install a mini float valve in a 55 gal poly drum along with a 1-1/2" ball valve as a bottom drain. I run the RO unit the night before I know I'm doing to do a wash/mash.
80 miles from the end of the road makes RO unlikely. But living on a lake why not ditch the well water,
and use filtered lake water? The real question is how the hell you gitting on the internet??? :clap: :clap:
Re: Well water
Tworude wrote: Mon Aug 01, 2022 11:26 am I'm 80 miles from the nearest road and about to get started distilling. My well water has about 3.3 ppm iron which is just high enough to turn a rusty color after it sits a while. It tastes like iron. For drinking we run it through a berkey carbon filter system and it's great after that. I assumed that I'd have to go through that time consuming process to have water for spirits but I'm thinking that there is a possibility that the minerals in the water will distill out and never reach the top of my column. I mean, you make distilled water that way, right? What do you guys think? Thanks
My thoughts.
You might want another source of water for diluting to drinking strength.
Distilleries brag about their iron free limestone water being the best.
But I think your well water will work good enough.
https://books.google.com/books?id=n0kjE ... pm&f=false
https://core.ac.uk/download/pdf/29824677.pdf
Tworude
Re: Well water
Post by Tworude »
cob wrote: Mon Aug 01, 2022 8:10 pm
There is a cell tower on Shell Hill so I have Verizon. RO isn't going to happen. We did lake water for a long time but the ice gets so deep at times it's inaccessible.
Tworude
Re: Well water
Post by Tworude »
I'll be attempting a fermentation later this week. If it goes, I'll not worry about the iron. Thanks
Tworude
Re: Well water
Post by Tworude »
Thanks for the input gentlemen. I'll filter the water for wine and not worry about the slightly high iron, as long as the yeast agrees. Appreciate the input.
Re: Well water
Yeast is "bull frog tough" :lol:
It's not too worried about 3.3 ppm iron.
What it's looking for, is all the other minerals the well water has.
Re: Well water
bunny wrote: Mon Aug 01, 2022 12:49 pm Start collecting rain water.
Yummyrum wrote: Mon Aug 01, 2022 1:31 pm What he said :thumbup: also IMO , the best stuff for cutting down proof
Seeing as how tworude lives in the Skwentna Alaska area Id say theres a pretty good chance that water tanks would freeze solid for a good part of the year. '
Photos I googled up of the place dont show much that looks warm to me.......might be a nice place for a holiday , but think I'll stay right here in subtropical AU.
Re: Well water
Saltbush Bill wrote: Tue Aug 02, 2022 12:15 am
still_stirrin wrote: Mon Aug 01, 2022 12:17 pm But, the iron is not good for yeast. It will make fermentation slow, if not impossible, depending on the other “hardness” you have besides the iron.
Thats the beer brewer coming out SS. :lol:
shadylane wrote: Mon Aug 01, 2022 11:29 pm Yeast is "bull frog tough" :lol:
The Moonshiners angle on the same thing.... :lol:
I say put together a couple of ferments , see what happens.
Do keep them warm though........warm yeast..or yeast thats at least in its happy temp zone can deal with a lot of other shit that it doesnt desire.
Re: Well water
Post by The Baker »
Use a yeast that likes cool conditions!
Maybe one used for ale (not beer).
Salt Must Flow
Re: Well water
I assumed that if he has "well water" that he has a steady source of water on tap like most people who have "well water". I have well water and I use a RO unit for everything distilling related other than my condensers. I just don't know exactly what the OP's water situation is other than the fact that he has "well water".
Lake water is typically much dirtier than well water. LOTS of organic matter, high in bacteria and who knows how much pesticides/herbicides from runoff. Well water is filtered through the soil which typically makes it cleaner, but can be higher in minerals. RO units remove nearly everything and comes out 0-2 ppm. Distilled water is 0 ppm.
cob
Re: Well water
Post by cob »
I would wager that if Tworude even has electricity it is very precious (intermittent solar or fuel) 80 miles is a long walk.
captainshooch
Re: Well water
Post by captainshooch »
I use my deep well water and filter with a KDF85 filter and it does really well with iron concentration.
Tworude
Re: Well water
Post by Tworude »
Great fishing, no snakes, downwind from nothing worse than a moose fart. You think I'd let my water freeze? No!
Tworude
Re: Well water
Post by Tworude »
cob wrote: Tue Aug 02, 2022 10:38 am I would wager that if Tworude even has electricity it is very precious (intermittent solar or fuel) 80 miles is a long walk.
Abundant solar in the summer, not good November - January, I run a generator every few days those months.
Tworude
Re: Well water
Post by Tworude »
captainshooch wrote: Tue Aug 02, 2022 3:36 pm I use my deep well water and filter with a KDF85 filter and it does really well with iron concentration.
I use a Kdf filter as well but I'm not satisfied. Drinking water goes through a carbon filter and it's perfect.
Tworude
Re: Well water
Post by Tworude »
Salt Must Flow wrote: Tue Aug 02, 2022 8:12 am
No herbicide or pesticides, my wife and I are the only ones on the lake. The owners of the other 6 cabins are seldom here. Fish and duck shit though.
Re: Well water
Tworude wrote: Tue Aug 02, 2022 11:43 pm
Sounds like good water for making shine.
Maybe not so much for brewing beer. :lol:
Are you going to use wood to fire the boiler?
Ben
Re: Well water
Post by Ben »
shadylane wrote: Wed Aug 03, 2022 12:10 am
Perfect for brewing beer, if it tastes good the boil and ferment will kill anything that could hurt you. Brewing was used as a way to process undrinkable water for thousands of years before water treatment plants became a thing. Still is in places that have less.
hawkwing
Re: Well water
Post by hawkwing »
You can always distill water for beer and wine.
Re: Well water
This is exactly what I do, I am on a well that we filter to soften and rid the water of extra iron. Before adding a filter system you could see it on the dishes that went through the dishwasher. My filtered water works great on my fermentation.
captainshooch
Re: Well water
I should have been more specific. The KDF filter I use is the KDF85-GAC, it has activated carbon as well.
"Our FI-KDF85 filter cartridges have superior taste and odor reduction capabilities. There are two types of media in these types of filters: the KDF media in this cartridge specializes in the reduction of iron and hydrogen sulfide and the activated carbon is effective against chlorine, odor and taste"
From ebay for +/- $30.00.
