Mixing Rum
- 8Ball
Mixing Rum
Mixing Rum
1.75G TSC EVH Molasses (Evolved Habitats or any basic feed store blackstrap)
4# Turbinado sugar
1# dark brown sugar
1.5G cold dunder
Juice 2 limes, 1 orange
1/2 citric acid
2 teaspoons gypsum
2 tablespoons Fermax - optional
1 multi vitamin, 1 B-complex, 1 teaspoon epsom salts
60 ml coconut extract
15 g bakers yeast made into a starter.
Oyster shells, couple handfuls
1 tablespoon spoon calcium carbonate
Heat molly, sugars, and citrus juice up to 185F.
Add cold dunder.
Cool down to 120F.
Dump into fermenter.
Top off to 7.5G at 85F.
Add nutes and aerate with aquarium pump 10 minutes.
Pitch yeast starter.
Total 8G @ 4.7 pH & 85F
When it is done fermenting, Reserve 1G wash and strip the rest out as low wines. Mix the low wines & reserve (aka1.5 spirit) and do a slow spirit. I make a generous fores/heads cut and collect hearts down to 60-55% in the parrot. I age on used white & french oak.
4# Turbinado sugar
1# dark brown sugar
1.5G cold dunder
1/2 citric acid
2 teaspoons gypsum
Add cold dunder.
Cool down to 120F.
Re: Mixing Rum
Just to be clear, this is the molasses you are talking about, right?
https://www.tractorsupply.com/tsc/produ ... l-evo21396
Thanks!
Thanks!
- 8Ball
Re: Mixing Rum
Yep, that is the right stuff.max99 wrote: ↑Wed Jul 12, 2023 10:40 pm Just to be clear, this is the molasses you are talking about, right?
Thanks!
Re: Mixing Rum
Not to be negative Nancy but I looked at this stuff on my last run for cracked corn and it looks like they’re adding sulfuric acid in addition to propionic acid now? Would we still consider this safe to use?
- Oldvine Zin
Re: Mixing Rum
For my rum I just pay double and get the food grade
Stay safe
OVZ
Stay safe
OVZ
- 8Ball
Re: Mixing Rum
Used as preservatives and sanitizing solutions. I’m not worried.
https://www.echemi.com/cms/603804.html# ... a%20growth.
- Oldvine Zin
Re: Mixing Rum
Yea and from that abstract it is used as a preservative, so the yeasties might not like that8Ball wrote: ↑Wed Aug 02, 2023 5:27 pmUsed as preservatives and sanitizing solutions. I’m not worried.
Stay safe
OVZ
- 8Ball
Re: Mixing Rum
My ‘yeasties’ love it. Over a dozen washes, probably more, finished nice & dry with it. No issues with this feed store blackstrap.Oldvine Zin wrote: ↑Thu Aug 03, 2023 6:58 pm Yea and from that abstract it is used as a preservative, so the yeasties might not like that
Stay safe
OVZ
- Oldvine Zin
Re: Mixing Rum
Good to know and glad you are having good results with it. This is one thing I read - "Food grade sulfuric acid is a food additive that the FDA and USDA approved. It helps preserve food and inhibit the growth of bacteria, yeast, molds, or other microorganisms in food."
I'll still use food grade
Stay safe
OVZ
Re: Mixing Rum
Oddly, I just replied to a thread on backset in regards to pH.
As far as I see it, all the acid additions to the molasses would be doing is preventing micro growth by keeping a low pH environment.
Buffered back to yeast friendly levels, no problem.
- NZChris
Re: Mixing Rum
I've been using sulfuric acid in rum for a bit over thirty years, sometimes in the wash, sometimes in the Low Wines, now I use it when liberating esters from Lime Salts.
If I'd had Phosphoric acid, I would have tried it in the ferments, but I've never found any.
A low pH environment might not be helpful if you want to encourage bacteria to create esters for your rum. For flavor development, I often let mine rest for a few days after they go dead.
Re: Mixing Rum
Id be interested to know what the difference between Sulfuric Acid and Food Grade Sulfuric Acid is.Oldvine Zin wrote: ↑Thu Aug 03, 2023 9:31 pm "Food grade sulfuric acid is a food additive that the FDA and USDA approved.
Can someone please enlighten me ?
Re: Mixing Rum
Rite that is funny... I would never think food grade when talking about Sulfuric acid. I used to buy 98*/* reagent grade Sulfuric acid back in the 90's . That's some mean stuff. Never heard of it being referred to as food grade though. But I'm no chemist....
