Is this corn usable from my local store?
Re: Is this corn usable from my local store?
Moonshine31 wrote: Sat Dec 02, 2023 7:35 pm
I'll have to clear a spot on top through all the gunk to check the sg but I will do that tomorrow and reply. I'm kind of afraid to taste it lol
Sounds like it still actively fermenting if there's a cap.
If it's setting on the floor, raise it up a couple feet so warm air can get under the fermenter.
Moonshine31
Post by Moonshine31 »
Is it off of the floor a out a foot, I just checked the sg and it's above 1.0 still, I hear it bubbling but very very slowly. I can see mold on top of the cap, is that normal? I know im going to boil it but still wondering. Here are some pics
Moonshine31
Pictures.
Moonshine31
Also just a FYI the pic with the hydrometer still had barley under it so it wasn't pure liquid.
Sporacle
Post by Sporacle »
Why has the cap not sunk? Did you do a starting gravity?
My thoughts may be there was no conversion to start maybe. :think:
Judging by the stains on the side, looks like the cap has already fallen.
I'd punch the remaining cap down, to keep more mold from forming.
While I was at it, remove a sample and get a good SG reading.
On a side note, don't make the mistake of trying to stir with the hydrometer.
Doing so didn't end well for me. :oops:
A sunk cap to me means it's on the bottom of the fermenter......not the top.
Punching it down again might tell one way or the other.
Moonshine31
The cap has fallen a few inches, I'll push it all down right now and take a good reading of the sg. I didn't test the starting gravity at first.
Moonshine31
So I pushed it down and took a good reading of it. It would suck if this was all for nothing. Can I still cook it or do I need to wait for the sg to go down.
subbrew
Post by subbrew »
If I read that correctly it is sitting at 1.012. I would seal it back up let the yeast continue to work. What is the temp, it you can get it up to 80F it will finish off more quickly.
Also think about getting a wine thief so you can get samples with less disruption of the CO2 layer. If you can sample every other day to see if the gravity is still falling you will know if the ferment has finished or stalled.
Moonshine31
You think I should seal it up? Like put my airlock lid on top? Doesn't the yeast need to breath? My wife is complaining about the smell so I really hope it keeps fermenting and finished soon so I can get it out of the basement and cook it. I'll put a heater around it to warm t
It up a bit.
Moonshine31 wrote: Mon Dec 04, 2023 7:26 am You think I should seal it up? Like put my airlock lid on top? Doesn't the yeast need to breath? My wife is complaining about the smell, so I really hope it keeps fermenting and finished soon so I can get it out of the basement and cook it. I'll put a heater around it to warm t
It up a bit.
Hmmm … perhaps moving your cot/bed to the basement would help. SWMBO isn’t happy —> nobody’s happy.
Seriously, closing a fermenter and venting it outside might help your status with the wife. Tread lightly.
Moonshine31
Lol I still have a few more days until she turns up the heat I believe. Should I close it? Won't that kill the yeast?
Moonshine31
Is it supposed to smell like shit while fermenting? It started off great but now smells sour.
Moonshine31
It seems to be bubbling more now that I pushed it down.
subbrew
Post by subbrew »
Moonshine31 wrote: Mon Dec 04, 2023 7:26 am You think I should seal it up? Like put my airlock lid on top? Doesn't the yeast need to breath? My wife is complaining about the smell so I really hope it keeps fermenting and finished soon so I can get it out of the basement and cook it. I'll put a heater around it to warm t
It up a bit.
yeast only needs O2 for the first 24 to 36 hrs. After that it goes an anaerobic metabolism which is when it makes alcohol. Having it open just lets in bacteria and molds. So yes, put a lid and airlock on as should have been done right after you aerated and pitched yeast.
Moonshine31
subbrew wrote: Mon Dec 04, 2023 2:28 pm
It up a bit.
Thank you, I'll cover it tonight and open it in a few days to check the sg.
Moonshine31
So it seems like it went from 1.04 to 1.02 it's been 3 days since my last check. Should I keep waiting until it hits 1? I'm in no rush
Moonshine31
Or It might of finished fermenting because they're really close so it's kinda hard to tell the sg. What happens if it stops fermenting but still above 1? Is it ok to cook?
Moonshine31
I'll leave it and check it in another 3 days, no more smell or mold happening so I can wait.
Moonshine31
Just realized I pitched the yeast on the 26th so now I'm nervous.
subbrew
Post by subbrew »
Moonshine31 wrote: Fri Dec 08, 2023 9:05 am I'll leave it and check it in another 3 days, no more smell or mold happening so I can wait.
That would be my move. And for me, even after I get it off the grain and into carboys to clear it may be a month before I actually put it in a still. but during that time it will continue to clean up.
So just an idea to keep in mind if you are ever in a hurry to get a fermenter freed up. If you have storage like carboys you can rack off a bit early and let the ferment finish in the carboy while starting a new ferment in your fermenter.
Moonshine31
subbrew wrote: Fri Dec 08, 2023 10:55 am
So you rack it into carboys and leave it alone for a month to settle more. I assume it's better to cook when it's cleared up and not just filtered? You must siphon it from the top and keep racking? I know with wine I racked 3 times then filtered.
I have 2 ss tanks 150l each, so I'll probably rack this in a few days and start another ferment In the other one.
Moonshine31
I'm not sure if you whiskey guys use the term racking.
Dougmatt
Post by Dougmatt »
Racking is fine as a term. Most will understand it. You will not be “filtering” unless you just mean limiting solids in the boiler which you will do the avoid a scorch.
There’s no rush here other than you probably are just excited to get it “cooked” or run through the still. You want to let things finish so there isn’t a bunch of residual sugar which A) could result in a scorch, b) reduce your net alcohol and c) would mean that the yeast aren’t “finished” which they need to do to clean up after themselves and give you the best flavor profile.
Just put the top back on and leave it for a few days. It’s done when the SG stops going down and not before. :).
That’s it. No more reading!
subbrew
Post by subbrew »
Moonshine31 wrote: Fri Dec 08, 2023 12:08 pm
Yes, I rack into carboys, then squeeze the grain, if a whiskey, and put the squeezed liquid in carboys as well. I ferment about 36 gal batches so I have enough for three stripping runs in my keg still it can sometimes be a month or more before I get the stripping runs completed. I don't filter, I just want most of the solids to settle so there is less chance of a scorch.
Moonshine31
How the f did this happen? The fermenting can go backwards????? I was close to 1 a few days ago and now look at this.
Moonshine31
This was about 3 days ago.
Moonshine, your photos always make me spill my drink!
NormandieStill
Post by NormandieStill »
Bubbles in the wash from the CO2 clinging to the hydrometer? Different temperature? The fact that you're measuring horizontally? :wink:
