Having a ball
- Steve Broady
Having a ball
I probably should have, but I did..
This came up on eBay, and I had to buy it. Total impulse purchase. I’m thinking of trying to desolder the two halves, reshape one into a cone, add 2” TC ferrules, and then solder them back together. Sure would be pretty if I can pull it off.
Or maybe just leave it a sphere. I don’t know enough about how things like copper onions work to know if the conical shape is important for flow reasons, or a byproduct of the way they’re made.
Re: Having a ball
You probably should pull it apart and remove and replace the Solder anyway Steve . It’s bound to be 50:50 Tin Lead
Nice score .
Nice score .
Re: Having a ball
That looks like Mr Bubble cap platey out of Southpark Shady
I like it
Re: Having a ball
That's what I'd do with the copper ball.
There's enough room for a shit load of caps and a dimroth defleg inside of the ball.
8" of bubble caps sounds kinda big for a keg sized still, but it would have a wide range of operation.
I figure it could work with anything between 1.5 and 5.5kw or more.
I haven't found the post yet, but somebody in the past did a "fu-manchu" that looks similar.
- Deplorable
Re: Having a ball
Things like that are why I avoid ebay.
Also, things like that make me mad I don't spend time on ebay.
Personally I'd run a lead test swab over it before I did anything else. Then being the lazy bastard I am, if there was no lead in the solder, I'd probably just slap a couple ferrules on it and run it as an onion. Otherwise if you have to take it apart, you might as well make it a fat plate section as suggested above.
- Oldvine Zin
Re: Having a ball
Here is what I made with a 8" copper ball
Oh and lead free-
Re: Having a ball
Whoarr!Oldvine Zin wrote: ↑Tue Dec 12, 2023 6:15 pm Here is what I made with a 8" copper ballcopperball.jpgOh and lead free
- Steve Broady
Re: Having a ball
Is there any functional difference between a copper sphere and a copper onion, assuming the same surface area and same inlet and outlet diameters?
Regardless of what happens, I’ll take it apart and clean the old solder off. I’m trying to decide if there’s a good reason to go to the trouble of trying to reshape it, or just leave it a sphere.
Re: Having a ball
It's funny how ebay caters to our creative impulses in this hobby.Steve Broady wrote: ↑Sat Dec 09, 2023 10:48 pm I probably should have, but I did..
I found a roll of 16 oz copper ( 24 sq feet) and ended up getting it for $20 this last summer. Recently I found an old stainless can used for milking for $20 also. Every time I browse I see something that looks like I could use. I was looking at a copper bird bath to use as lid for a still.
- Oldvine Zin
Re: Having a ball
It's basically an expansion chamber, I've had no problem with the sphere.Steve Broady wrote: ↑Wed Dec 13, 2023 6:42 am Is there any functional difference between a copper sphere and a copper onion, assuming the same surface area and same inlet and outlet diameters?
Stay safe
OVZ
- Steve Broady
Re: Having a ball
Thanks, OVZ. That saves me from putting myself through a lot of needless work. I’ve got plenty of other things to do!
- Oldvine Zin
Re: Having a ball
And for anyone who is considering a copper ball ... here is where I got mine https://www.necopperworks.com/ I asked them about the use of lead solder and they said no. I ordered and then tested and found that they were honest about lead.
Stay safe
Ovz
Stay safe
Ovz
- Steve Broady
Re: Having a ball
I keep having this crazy idea of using some copper welding studs and adding spikes to the inside and outside of the ball. The theory is that it would add surface area, and therefore increase passive reflux. It would also look a bit like a copper Sputnik, which would either be cool or a bit freakish. Or both. Any thoughts? Any benefit, aside from looks?
Re: Having a ball
Forget passive reflux. 90% of the time it works against what's needed.
On the hobby scale, the only time reflux is good is when it's raining down on plates or packing.
- NZChris
Re: Having a ball.
Vanes in the ball to start some rotation, then a cone on top so that the rotational speed increases as the vapor rises and the cross section decreases, causing centrifugal force to throw any entrained droplets to the walls to run back down into the pot.
Re: Having a ball.
Ok, now I'm seeing a glass coned section, with a vaned copper spinner mounted in it, so you could see the swirling. That would be some cool, (but likely utterly pointless) shit to have in the riser.
Re: Having a ball
I've played with glass columns, balls and seen what happens.
There's nothing fancy, everything plays by the rules.
Ya don't have to be able to see what's happening, just run it slow, easy and conservatively.
- LWTCS
Re: Having a ball
That was PP's build.shadylane wrote: ↑Sun Dec 10, 2023 6:29 am That's what I'd do with the copper ball.
And before that was the "BubbleBall".
Re: Having a ball
An under-appreciated application for a large plate is under a column.
