No Mash No sugar ( YLAY)
zach
Re: No Mash No sugar
Thanks, I do plan on doing the next batch with of corn meal with the YLAY since I have a 500 gram bag ordered.
- SaltyStaves
Had the last 65g of my long opened 500g block and had some leftover kibbled rye to use up. The best before date on the yeast was Aug 2022...
Safe to say that this stuff doesn't depreciate all that easily.
My primary fermenter was in use, so I thought I could get away with next largest option. Nope! What you can't see from the pic, is that this is my waterbath setup. Its a drum within a drum with a heated water jacket. The neoprene skirt I use on the top was the only thing preventing the grains from falling into the outer-drum (where the aquarium heater is located).
Fortunately, the wash in my primary fermenter was ready to be run, so I quickly racked it off and transferred the YLAY wash over to it (along with some extra Rye to makeup for the loss). I did not have time to wash the old trub out, so the lacto and beer yeast in there have now joined the party. Not sure what the long term affects of that will be, but at least I won't have to mop the floor again.
So how are you finding the spirt that is made with this yeast SaltyStaves?
All results I've had to date have ranged from good to excellent.......one bourbon grain bill once oaked was extra good in my opinion.
- SaltyStaves
I can't get past the 'Soju' character that this yeast seems to give everything I've fermented with it (Rye seems to be the most forgiving/complimentary). Having said that, I like it more than some sugar wash bourbon attempts I've made in the past.
Northsouth
An idea put into motion today.
So I got a 4+ gallon (4.5 l) barrel of Spanish Oak, many would argue the best in the world, for my birthday. To not dry it out, I filled ir with some Vodka laying around at 45-50 abv. That is too intense on oak taste, when trying it out now.
Today, I did 5 mashes of malted barley with the intension of filling that barrel with a single malt scotch. But my main grinder failed, and I had to use the silly one.(the one with a hopper and ran by a drill, but impossible to dial in) That gave a gravity of a lousy 1.04, with a lot of expensive malted barley sitting there without giving me my sugar.
Then I got the idea. What if I put all the "spent", or in this case "not so spent" grain in a separate fermenter, add just enough water to top off, and add YLAY.
We shall see. So far, it is alive.
- Dancing4dan
Northsouth wrote: ↑Sun Jan 21, 2024 5:07 pm An idea put into motion today.
Should work fine. I have been doing malted barley or corn using YLY for all batches.
Marcus Aurelius
Marcus Aurelius
- higgins
I jumped on the YLAY bandwagon with my last bourbon batch 13 days ago. It is a duplicate of my previous batch, but using YLAY instead of enzymes and bourbon yeast. It will be interesting to compare the result with the previous batch.
36 lbs/16.3 kg grain was ground to a meal and power mixed with 9 gal/34 L 145F/63C water in the fermenter. I then mixed in 9 gal/34 L 55F/13C water (settled at 93F/33C), oxygenated, and used 2 gm YLAY per pound of grain (4.4 gm per kg). I mixed twice a day for 3 days, keeping the temp about 92F just with insulation and the fermentations' natural heat. On day 4 the temp started dropping, and after a week it was down to about 75F/24C.
I looked at it today - the cap has fallen, a few grains floating on the top, and occasional bubbles breaking the surface. The SG is sitting right at 1.000 and it smells and tastes alcoholic and slightly sour. I'm going to let it set for a week or 2 longer before stripping it.
tjsc5f
As always, can't wait to hear about your results!higgins wrote: ↑Thu Feb 22, 2024 9:05 am I jumped on the YLAY bandwagon with my last bourbon batch 13 days ago. It is a duplicate of my previous batch, but using YLAY instead of enzymes and bourbon yeast. It will be interesting to compare the result with the previous batch.
OnceAlive
Copy/pasted from the Angel Yeast website : "control the temperature to be 82°F-97 °F(28-36℃), the optimal fermentation temperature to be about 90°F(32℃), in the short period, the highest fermentation temperature shall not be over 100°F(38℃), and the heat insulation measure shall be taken when the temperature is below 79°F(26℃)."
After a week, it's possible that the ferment was done... if not, the yeasty bunch might have fallen asleep because it's cold in there (at least for them).
Chill'n Still'n ~ Distilling is a hobby where you don't want to blow off steam.
Useful links:
Don't forget the parent site... full of organized good info there
Newbie kickstart & Novice bump
Words words words
Help to pay the bills
Useful links:
Words words words
- higgins
I am aware of YLAY's optimal temperature, and I did maintain it for nearly a week. In that time it was very actively fermenting, and started slowing down well before it dropped below 80F.
It is continuing to work now (bubbles breaking surface - it may just be off-gassing dissolved CO2) even though it is now down to about 68F after 17 days. It does smell tart and alcoholic, so I know that it is 'mostly' done. I'm going to stir it up to degas it, then let it set for a few more days to see if any more bubbling happens.
BlueJ
Anyone have feedback on using mini wheat breakfast cereal as the wheat component of a wheated bourbon recipe and YLAY? I have seen a few posts about angel’s ability to ferment cereal and had some success getting good flavor on sugarheads with cereals (DWWG, Odin’s All Bran) with DADY, but didn’t see taste results with using cereal with angel yeast. I just started a batch of 78%corn/14% wheat/8%oats using mini wheat and wheat germ instead of actual grain. Curious if anyone has had good results. I figured at worst I’ll have a corn mash with some wheat flavor carrying over.
Reefer1
My last vodka run i made, i used weatabix, porridge oats, sultanas, white sugar in the wash,/mash it defo improved the sugar wash, loads of flavour, no stripping, just run it through my extended column T500 reflux, at 90+abv it retained loads of fruity, pleasant nose and various other taste components i couldnt identify, my pallate is not too sophisicated so i do struggle with identifying but ye i use weatabix a lot.
MooseMan
I'm pretty sure all "Breakfast cereal" has been pre-gelatinised BlueJ, so the YLAY should actually have an easier time converting it that it would wholegrain. The grains selected for breakfast cereals should I guess be "Better" than animal feed grade too.BlueJ wrote: ↑Sun Apr 14, 2024 1:41 pm Anyone have feedback on using mini wheat breakfast cereal as the wheat component of a wheated bourbon recipe and YLAY? I have seen a few posts about angel’s ability to ferment cereal and had some success getting good flavor on sugarheads with cereals (DWWG, Odin’s All Bran) with DADY, but didn’t see taste results with using cereal with angel yeast. I just started a batch of 78%corn/14% wheat/8%oats using mini wheat and wheat germ instead of actual grain. Curious if anyone has had good results. I figured at worst I’ll have a corn mash with some wheat flavor carrying over.
I often throw in any unwanted cereal, biscuits, cake, flour, bread etc. into my mash and it all gets chewed up nicely!
Oat flakes is something I always add, just the cheapest supermarket brand, and it definitely adds a smoothness.
- rubberduck71
Haven't done it myself, or remember reading about anyone doing it, but it should work.BlueJ wrote: ↑Sun Apr 14, 2024 1:41 pm Anyone have feedback on using mini wheat breakfast cereal as the wheat component of a wheated bourbon recipe and YLAY? I have seen a few posts about angel’s ability to ferment cereal and had some success getting good flavor on sugarheads with cereals (DWWG, Odin’s All Bran) with DADY, but didn’t see taste results with using cereal with angel yeast. I just started a batch of 78%corn/14% wheat/8%oats using mini wheat and wheat germ instead of actual grain. Curious if anyone has had good results. I figured at worst I’ll have a corn mash with some wheat flavor carrying over.
Cereal is most certainly not as cost effective vs 50# grain bag, but if you found it on the cheap, good on ya.
I've been using YLAY for 3+ years. Honey Bourbon, CROW, Irish Style, etc... all came out great.
BlueJ
Thanks for the replies. Yes rubberduck - I found a close out deal on the cereal and was just about to lay down an all corn mash, so thought I’d give it a try. I’ll post how it turns out. I just did a stripping run of a batch of all corn/angel, so I should be able to compare side by side.
- rubberduck71
I did one of those also. It was super cheap coarse corn meal from Restaurant Store. Also did a sugarhead with it.
Be patient! (unlike me...) It really turns the corner & gets good after 9-12 months on oak.
BlueJ
Good to know. I should have plenty to put some away for that long. Hard to stay out of it sometimes… but I am starting to build enough stock to save some back for longer time.rubberduck71 wrote: ↑Mon Apr 15, 2024 3:34 pmBe patient! (unlike me...) It really turns the corner & gets good after 9-12 months on oak.
- rubberduck71
Yeah, I'm with ya. It's been said many times on this site: patience is the hardest thing to put into a bottle...
But that's what sugarheads are for! Helps keep your paws off the A/G while it ages.
- venkman
I also finally joined the YLAY club, Higgins!
On the last Jimbo's Wheated Bourbon batch I did, I decided to do a sugarhead on the leavings. That sugarhead was ready to strip so I thought I'd experiment. While I was stripping that (2 strips), I used 6gal of backset from the first strip and dumped it on top of 25lb of new cornmeal. While I was running the second sugarhead strip, I used the hot water from my product condenser to add to the new batch and put another 25lb of corn meal in it. I just kept that stirred up and cleared the doughballs from it while I was stripping the other run. I did put a splash of HT Alpha Amylase in there to keep it a little thinner.
Once I finished stripping the sugarhead, I turned attention to the new batch. It was sitting around 145f, so at that point I added 17lb of malted red wheat, figuring the enzymes could get a head start on the wheat itself, even if the corn wasn't all cooked. I let this sit for an hour, then topped it up to 30gal total with cool water. I got it to about 90f and pitched about 100g of YLAY.
It's been going for 4 days, and I've been stirring the settled corn off the bottom a few times a day, and knocking down the cap. Excited to see what it makes. It looks and smells fine so far.
This is the same grain bill I've used in my previous Jimbo's batches. I'm excited to compare the AG, sugarhead, and YLAY variants. I'll post back here with more when the time comes.
Time, patience, and perseverance will accomplish all things.
MooseMan
I for one will look forward to your comparisons Venkman.
Welcome to YLAY club, first rule is - Tell everyone about YLAY club! Haha
- venkman
Is that the same as the second rule?
I'm excited for the tasting comparisons. I saved back a bit of whitedog before I put the AG Jimbo's on oak. I'm planning to spirit run that sugarhead this weekend and hold back some of that too. I want to compare them white. Might be a month honestly before the YLAY is ready to run. Stay tuned.
BlueJ
Follow up - I just finished stripping the corn+breakfast cereal mash and compared it with the all corn and there is a distinct difference. For reference, this was about 78%corn/14% wheat/8%oat by weight. There is clearly more cereal on the nose and a softer taste. If anyone has made Deathwish’s Wheatgerm - this tastes like YLAY all- corn with about 10% of that mixed in. Very happy with this outcome.BlueJ wrote: ↑Mon Apr 15, 2024 2:25 pm Thanks for the replies. Yes rubberduck - I found a close out deal on the cereal and was just about to lay down an all corn mash, so thought I’d give it a try. I’ll post how it turns out. I just did a stripping run of a batch of all corn/angel, so I should be able to compare side by side.
Dougmatt
I see several posts now about people (many who were at the southeast meetupvenkman wrote: ↑Thu Apr 18, 2024 9:46 amIs that the same as the second rule?![]()
I’m planning to do CROW. I just finished a 20G mash, and intend to do a 20G YLAY in the same fermenters once that is done and racked out. Then I plan to take one jar of each finished product after cuts and age on the same piece of toasted, charred oak cut in half.
Hoping to have this ready for next years meetup, but very interested in hearing if anyone else has done side by sides and what your experience was. I’m interested in whiskey (to avoid the mashing) but want to hear really about anything as some people have reported “off flavors” that aren’t representative of the style.
That’s it. No more reading!
MooseMan
I've always made sure to use approx. 10% backset, as I read it's important with YLAY to get the pH down at the start of the ferment to avoid off flavours.
So far I've had no issues of any kind.
I never added backset to any of the yellow lables I did , all fermented out well, with no off flavours.
Dougmatt
Perhaps “off flavors” isn’t the best description, rather flavors that don’t necessarily belong in the recipe. I’ve heard there’s a “wine like” or “sake like” flavor in a bourbon recipe for example. Could just be people expecting something different, and making the mental leap to taste it, but having not yet used YLAY I don’t know. Looking forward to experiencing it myself now that I finally have some, but interested in other’s experiences.Saltbush Bill wrote: ↑Sun May 12, 2024 12:51 pm I never added backset to any of the yellow lables I did , all fermented out well, with no off flavours.
- Dancing4dan
Never heard of this before.
Marcus Aurelius
Marcus Aurelius
MooseMan
It was on this forum I read about it I'm sure D4D, someone did experiments and found that at low pH it fermented cleaner, and no infections took hold.
Someone called "Enzyme King" on another forum also alludes to it, I've boldened the key bit of what he said below.
"Let the mash cool to 30-35C, ensure that the PH is below 5 and then add 50-80g of Angel Yeast, stir through well. Mix twice every day in the first three days ensuring the cap on top and trub at the bottom is well stirred in. Control the temperature to be in the 28-36C range, the optimal fermentation temperature is 32C, the maximum you should let it get to is 38C (the yeast portion of the enzyme mix will denature above this), If the mash gets below 26C consider adding insulation or heating the fermenting vessel.
8-15 day ferments are normal with shorter and longer times possible due to local water supply, the grain used, temperature control and so on. SG readings are of no use due to the co-operative way the yeast works with the enzymes over the full time of the ferment. It is finished when there is no activity for 2-3 days, looks yellow and there is no evidence of white starch remaining. A sour smell is quite normal and won’t affect flavor after distillation if you have followed the PH recommendation"
howie
AFAIK that is part of enzyme kings general instructions for the use of YA, not from any particular "enquiry".MooseMan wrote: ↑Sun May 12, 2024 9:57 pmIt was on this forum I read about it I'm sure D4D, someone did experiments and found that at low pH it fermented cleaner, and no infections took hold.
I'm like D4D , never heard of this theory before , and I don't remember seeing it here anywhere, not that , that makes it right or wrong.
Ok ,,,,,I had to google Enzyme King..... big name for someone who only sells one product. Yellow Lable, from what I see.
