The way I see it, if you're applying direct heat to a fermenter and using a temp controller, you want the temp probe inside the fermenter. This method is likely to be the most accurate & consistent.rgreen2002 wrote: ↑Mon Sep 26, 2022 11:14 am Hey...
For you guys using a seedling heating pad... what are you doing with the thermo? It is not supposed to be immersed so are you just capping the mash and following air temp?
I have used a few aquarium heaters in my time and have 2 500W heaters I just bought to get a jump start this mash season. I like the idea of the mat so let's give that a try!
You can heat the air inside of a fermentation chamber using a space heater & a temp controller and keep the temp probe in the air, but that doesn't control the temp inside the fermenter exactly. This method works fine for me. I monitor the temp within the fermenter separately and once fermentation starts really taking off it will generate some heat of its own (inside the fermenter) so I know what to set the air temp for. After a few days I'll bump up the air temp a few degrees (as fermentation starts slowing down) so the fermenter's internal temp stays more consistent. I've never tried heating the air while keeping the temp probe inside of a fermenter so I couldn't say whether that would be more beneficial. I felt it could be problematic.
