Guys, either
my idea* is so wild for y'all or my English has finally become really bad. Anyways, sorey
Sometimes doing new things with your hands helps you understand it better than a thousand theoretical lessons.
So, no one will die of fatigue having done a penny laboratory work step by step:
1. thoroughly soak your chips/sticks in strong distillate or strong neutral alco (or fish out already used ones from future whiskey)
2. instead of drying them on a plate until next time, place them in a mason jar with a tightly ground lid
3. there should be no distillate at the bottom of the jar, but the chips should not be dry either: keep them moist, moist, moist
4. check every day how the smell in that mason jar changes
5. when after a couple of weeks the smell becomes great, simply "wash off" the resulting extract in your target distillate (this will require immersing the sticks or chips in the distillate for only half an hour)
consequence-1: even 20 grams per quarter (of chips treadted in this way) is not too much, if you remove them after half an hour!
consequence-2: toasted chips will give you more yummies (and faster!) / feel free to char if ya wish but toast before
consequence-3: the extract (that you need to wash off) matures faster with a higher strength of distillate (say, 70% AbV / 140 proof)
consequence-4: if you did not catch the sticks from the distillate in time then be offended at yourself for catching an oak tea again
* THE IDEA: Initially, there is no vanilla, brandy, whiskey, other magic in toasted oak. All this is formed over time on the surface in the presence of alcohol and oxygen. If the stick lies at the bottom of a jug with distillate all the time then there is a dramatic lack of oxygen! Charring of the stick is more about pyrolysis than about oxidation.
