Welding Copper To Stainless
Salt Must Flow
Post by Salt Must Flow »
I'm considering building a ridiculous size 3" Shotgun Condenser 4' long for stripping. I have a bunch of 3" stainless pipe I got for free. Would just need a couple of 3" ferrules and some copper pipe. I'm guessing the TIG welding would cost me $30.
I found some 3" copper disks - 0.08" 12 Gauge. I'm thinking it would be really simple to just sandwich the copper disk between the ferrule and the stainless pipe then having it TIG welded. Anyone see any issue with welding it like this? When in use, the shotgun condenser would be used at an angle and the end would be suspended/supported/hung by paracord so there shouldn't be any EXTREME forces applied to the welds.
I initially planned on buying 3" stainless steel disks, but copper is MUCH easier to solder the pipes to.
Deplorable
Re: Welding Copper To Stainless
Post by Deplorable »
How much power do you have available?
With enough cooing water flow, I can't overpower my 2"×20" all copper shotty.
Or are you doing this "just because"?
Salt Must Flow
Deplorable wrote: ↑Mon Nov 11, 2024 7:22 pm How much power do you have available?
I'm mostly concerned with the integrity of the weld.
I strip at 11000W. With a 2" x 24" copper shotgun condenser, the low wines exited at 101F-107F at 252-307 LPH. I then joined two 2" x 24" copper shotgun condensers together and my low wines exited at 95F at 245 LPH. A 3" shotgun has approx 50% more surface area so it's just an idea I've been considering.
Deplorable
Ahh. I see.
That would be my concern as well, but I suppose it would be fine, them Chinese manufacturers are welding SS ferrules to Copper pipe, and I've yet to hear of anyone saying their equipment from Oak Stills has bad welds.
MooseMan
Post by MooseMan »
I can't see an accomplished welder having an issue with what you propose SMF, especially since it's very thin so they will be bridging the weld over the two stainless faces anyhow
Maybe ask before you buy the copper if that's possible, but the guy who's welded for me would not hesitate to weld copper tubing to stainless when I mentioned it, so I don't think this would be a problem at all.
Thumperbunny
Post by Thumperbunny »
Prolly best to silphos it. Hi silver an it sticks well.
Salt Must Flow
The wife's sick, got bored and started cutting some 1" copper pipe to make 10 baffles for a ridiculous 3" x 50" shotgun condenser. So far I've cut the disks, center punched each spot and ground the disks to fit. Just need to drill the baffles out on a wood jig. These are just the internal baffles. This thing is going to be crazy. 14 x 3/8" (1/2" OD) copper pipes.
I have everything to complete this other then 2 ferrules, two 3" copper end plates and the copper pipe. Once I get the rest in, I'll post a complete build thread.
MooseMan
Post by MooseMan »
Holy shit that's going to be a monster!
NorthWoodsAb
Post by NorthWoodsAb »
A 3"x50" shotgun will definitly have a cool factor. Looking forward to seeing it completed.
Filled with water it is going to be heavy. Going to have to be self supported or suspended.
Edit on the weight.
Uisge beatha
Salt Must Flow
MooseMan wrote: ↑Wed Nov 27, 2024 11:13 pm Holy shit that's going to be a monster!
Oh yeah. I figure since I strip at 11000W, my last stripping run was with two 2"x24" shotgun condensers and the product was exiting at 95F, I might as well make a shotgun that's just as long, but twice the internal surface area, see if that drops the product temp and/or reduces water consumption. The length is convenient for me.
I searched this site and I recall only finding one other guy who built a 3" shotgun, but it was 18" long. I don't know when I'll complete the build, but I suspect it will be around Spring. Being bored, I stayed up and completed all 10 baffles :lol:
Salt Must Flow
NorthWoodsAb wrote: ↑Wed Nov 27, 2024 11:33 pm A 3"x50" shotgun will definitly have a cool factor. Looking forward to seeing it completed.
Edit on the weight.
Yeah I calculated what the weight would be and it should be around 19 lbs dry and if my calculations are accurate, it should be approx 26.5 lbs filled with water. If you look close at the pic in my previous post, the end of the shotgun condensers are suspended by paracord from a 2x4 above.
MooseMan
Post by MooseMan »
Yeah 11000 is gonna need a fair bit of knockdown!
Forgot to say, I hope Mrs SMF gets well soon.
Oldvine Zin
Post by Oldvine Zin »
Salt Must Flow wrote: ↑Wed Nov 27, 2024 11:40 pm
here is my 3x24" shoty build
viewtopic.php?p=7380509#p7380509
