Just Post a Pick of your Rig
Coors Knight
Re: Just Post a Pick of your Rig
Post by Coors Knight »
Received a Boswell 13.2Gal / 50L still for my birthday in August. Swapped the supplied stainless lines with 3/4" copper, added a 4 gallon "milk jug" thumper, and used an old stainless pot for a little bit larger condenser. Using city water for cooling so I used an old 6" inline fan and adapted the biggest(and nicest looking) motorcycle radiator off Amazon to help cool the water. My last run was multiple stripping runs and a spirit run- took all day and water didn't get above 80 degrees in the 50 gal rain barrel. (Outside temps at mid 70's). Regrets: my union's off the thumper- should have reversed one so I can easily eliminate the thumper if needed will address. Mods coming up next: bigger condenser with 1/2 instead of 3/8 line.... Let me know your thoughts and questions - the radiator mod was something I found a lot of people talking about but hadn't seen it done yet!! Any feedback good bad or otherwise I'll take!!!
Always under construction!!
MooseMan
Post by MooseMan »
Good mods CK.
Since you already have a big fan and you're running outside, you could try your hand at an air cooled condenser instead of the worm?
When stripping, you don't want the thumper inline, so yeah you need to change that fitting to suit but that's an easy fix.
higgins
Post by higgins »
I would definitely get rid of that silicone hose off of the parrot.
Higgins
Flute build
Steamer build
4 methods experiment
Aging proof experiment
Next batch: Peated Bourbon (75% Corn, 25% peated malt)
SW_Shiner
Post by SW_Shiner »
3” Boka
3” Boka
My 3 inch boka set up for a neutral run.
AusAsh
Post by AusAsh »
Only the water barrels stay outside. The rig is sanitised before each run and after its dried it's locked back up :lol:
jackfire57
Post by jackfire57 »
Jackfire
Stump Lake
Post by Stump Lake »
Rusty Ole Bucket
Post by Rusty Ole Bucket »
Stump Lake wrote: Mon Jan 06, 2025 10:55 am Image
I love the little mini jack for the jar stand! (Your rig is pretty killer too. :thumbup: )
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Stump Lake
Ah thanks. I found that on Amazon. Stainless
Steel Lab Jack Scissor Stand Platform (4" x 4") it was $13.54. I had been putting anything I could find to jack up my catch jars. Not a problem any more.
CO_Matt
Post by CO_Matt »
My little thing on stripping duty.
Copperhead road
Post by Copperhead road »
5 plate column bubbler
Copperhead road
Brandy still
Tex1320
Post by Tex1320 »
Here she is 10gal
