I need advice for the first fermentation.
subbrew
Re: I need advice for the first fermentation.
Post by subbrew »
Your gravity could be a little higher but it depends on the type of grain, the grind (how fine), the mash temperature? There are many factors to mashing grain. This site has some good info but a good beer brewing site will have much more if you really want to learn the science and the details.
Roger1
Post by Roger1 »
SW_Shiner wrote: Wed Feb 26, 2025 3:17 pm Sounds pretty good for a first go. Depending on starch content (not gelatin) and efficiency you may be able to get a higher gravity. One way to know if you have gotten full conversion is to do a starch test with iodine.
Since I had read in forums that iodine doesn't differentiate between fermentable and non-fermentable sugars, I wasn't very attracted to this method. But now that I think about it, it seems like a good method for me as a beginner working with grains. I will definitely get some iodine today.
Roger1
Post by Roger1 »
shadylane wrote: Wed Feb 26, 2025 3:27 pm 1.050 would yield 6.5% if the final gravity gets down to 1.000
I'd do a test ferment to see how low the final gravity drops.
This is great, I will definitely do the fermentation test.
SW_Shiner
Post by SW_Shiner »
Roger1 wrote: Thu Feb 27, 2025 12:04 am
You're not looking for sugar with iodine. It tells your if you have starch or not. If you do a starch test and see no signs or starch, then you know you have gotten all you can out of the grain. Whether it is fermentable sugars or not is up to the enzymes, i have no knowledge of a way to measure how much of a particular sugar there is.
OtisT
Post by OtisT »
Roger1 wrote: Wed Feb 26, 2025 8:09 am [I bought new enzymes from a reliable seller and tested 2 pounds of grains with 1 gallon of water last night and reached an SG (Specific Gravity) of 1.050.
It seems to me that the mashing was complete as there were no signs of gelatin. Do you think this number is good, or should I increase the amount of grains or decrease the amount of water?"
Hi Roger. I see you are learning how to get your grains to convert into sugar and you are comparing your results with other recipes and anecdotes, like the one about using 2 pounds/gallon to reach a specific SG. I believe that most of the recipes/anecdotes on HD referring to pounds per gallon are based on the final volume of your wash. So to get the expected results you would need to mash 2 pounds of grains with enough water to make a ferment totaling one gallon. (Water +grains = one gallon)
Adding one gallon of water to two pounds of grains will result in a ferment that is more than one gallon in volume and your SG after a full conversion will be lower than expected.
Roger1
Post by Roger1 »
SW_Shiner wrote: Thu Feb 27, 2025 10:30 am
I must admit, I didn’t know this either!
Roger1
Post by Roger1 »
OtisT wrote: Thu Feb 27, 2025 2:05 pm
"Hello Otis, oh, that's such a subtle point👌
Actually, I’m currently doing my fourth mashing test and decided to mash 1 kilogram grain, which is a bit more than 2 pounds, with 3.5 liters of water. This is very close to your formula. I’m sure it will give a better result than the previous test. In a few hours, I'll check the specific gravity and then use this small sample for a trial fermentation. I'll share the results here."
SW_Shiner
Post by SW_Shiner »
Ive never considered that. But the way i do it works out that i do do it that way. I have a 60L fermenter, and i use YLAY, so my "mashing" is, add 15kg grain to fermenter, then top up to 60L with water, pitch YLAY. Prior to using YLAY, I used SCDs Easy Large Batch Mashing method.
subbrew
Post by subbrew »
Doing test mashes as you are is a great idea. After a few you will determine what works for you based on the grain mix, grind of your grain, your mash protocol and any enzymes you are using. I know with my set up I put 10 gallons of water in my pot then add 25 lb of grain give or take the accuracy of my 3 dollar luggage scale and I consistently get 1.063 to 1.068 starting gravity for a 70 to 75% corn mash. Once you have your base it is easy to adjust if you think your grain is old and might not mash as well, or if using a grain mix with lower potential gravity grains.
Roger1
Post by Roger1 »
subbrew wrote: Mon Mar 03, 2025 9:41 pm Doing test mashes as you are is a great idea. After a few you will determine what works for you based on the grain mix, grind of your grain, your mash protocol and any enzymes you are using. I know with my set up I put 10 gallons of water in my pot then add 25 lb of grain give or take the accuracy of my 3 dollar luggage scale and I consistently get 1.063 to 1.068 starting gravity for a 70 to 75% corn mash. Once you have your base it is easy to adjust if you think your grain is old and might not mash as well, or if using a grain mix with lower potential gravity grains.
Hi subbrew,
Thank you for your attention. In the latest small mashing sample, I reached an SG of 1055 and added yeast for fermentation. If it reaches 1000, that would be great, and I'll start working on making vodka. Gradually, as I gain more practical experience, higher numbers and more sugar won't be so far out of reach.
I am also in a bit of a hurry to make the vodka so that I can free up my fermentation &distillation equipment and start making raisin brandy. I want to be able to write the recipe with precise information and some photos for friends in the forum, because it has a long process that takes about 2 to 3 months.
Roger1 wrote: Tue Mar 04, 2025 12:59 am
I'm looking forward to hear how the test ferment finished.
A low final gravity is a measurement of success for mashing.
Starting with 1.055
1.010 = 5.2%
1.005 = 5.8%
1.000 = 6.5%
0.995 = 7.1%
0.990 = 7.7%
0.980 = 9%
subbrew
Post by subbrew »
Here is a chart that will help you determine what you might get out of grain. https://homebrewacademy.com/grains-and-adjuncts-chart/ I assume about 85% conversion rate given my grind and process. So if a grain promises 1.034 potential I use 1.029 as my expected gravity per lb. I usually do slightly better but I would rather be pleasantly surprised than disappointed.
Roger1
Post by Roger1 »
subbrew wrote: Tue Mar 04, 2025 9:10 pm Here is a chart that will help you determine what you might get out of grain. https://homebrewacademy.com/grains-and-adjuncts-chart/ I assume about 85% conversion rate given my grind and process. So if a grain promises 1.034 potential I use 1.029 as my expected gravity per lb. I usually do slightly better but I would rather be pleasantly surprised than disappointed.
It's such a great website, thanks.
Just one question: if the weight is measured in pounds, what is the unit of measurement for water?
Roger1
Post by Roger1 »
shadylane wrote: Tue Mar 04, 2025 2:24 pm
Starting with 1.055
1.010 = 5.2%
1.005 = 5.8%
1.000 = 6.5%
0.995 = 7.1%
0.990 = 7.7%
0.980 = 9%
Honestly, I'm really excited. I just took a look at the fermentation vessel, and it's bubbling wonderfully.
What's the temperature?
Roger1
Post by Roger1 »
shadylane wrote: Wed Mar 05, 2025 12:33 pm What's the temperature?
76° F
Rusty Ole Bucket
Post by Rusty Ole Bucket »
Roger1 wrote: Wed Mar 05, 2025 12:05 pm Honestly, I'm really excited. I just took a look at the fermentation vessel, and it's bubbling wonderfully.
I love to put my ear to the side of the fermenter and listen to the "sizzle", that never gets old! :thumbup:
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Roger1 wrote: Wed Mar 05, 2025 12:39 pm
76° F
:thumbup:
It's going to ferment fast and then the cap will fall.
Roger1
Post by Roger1 »
Rusty Ole Bucket wrote: Wed Mar 05, 2025 1:07 pm
Rusty
Fermenting black plums with a touch of peach :wink:
subbrew
Post by subbrew »
Roger1 wrote: Wed Mar 05, 2025 11:00 am
Water in gallons. Americans refuse to use a measurement system that makes sense, we would rather measure things in football fields length or elephants for weight.
Roger1
Post by Roger1 »
Starting with 1.055
1.010 = 5.2%
1.005 = 5.8%
1.000 = 6.5%
0.995 = 7.1%
0.990 = 7.7%
0.980 = 9%
hi shadylane
The test fermentation is complete.
It reached a reading of 998 SG. I believe with a bit more precision and some slight adjustments to the ratio of water and grains during the mashing process, I can achieve better results.
I’ll begin the main part of the mashing process and will share the results here once it’s completed.
A final gravity of .998 is good.
To get it lower pay closer attention to cooking the grain to get better starch gelatinization and pH that the alpha enzymes need to convert starch into dextrin.
Roger1
Post by Roger1 »
shadylane wrote: Sun Mar 16, 2025 2:39 pm A final gravity of .998 is good.
Thanks shadylane
I have a question.
In the mashing process, should I wait for the grains to gelatinize first and then add the alpha-amylase enzyme, or should I add it as soon as the temperature reaches the enzyme's activation point? During my test, I added the alpha-amylase enzyme as soon as the pot reached the enzyme's activation temperature.
I'd mix the alpha enzymes with the water at the beginning.
This way you get a homogeneous mixture and then stir in the crushed grain while heating the mash. By having the water, grain and enzymes together, it doesn't get thick and hard to stir as it heats up.
Roger1
Post by Roger1 »
Hi shadylane
I've started the main mashing process. By adjusting the ratio of water and grains, I easily reached an SG of 1070. It seems the sugar level is sufficient.
Roger1
Post by Roger1 »
Hi friends, I’ve completed the mashing process with the following mixture:
- 118 pounds of wheat
- 39 pounds of barley
- 8 pounds of wheat bran
- and 65 gallons of water
I used a gluten-free bread yeast from Dr. Oetker. The fermentation is going very well. I use this yeast when I don’t have Lalvin EC-1118 available for fermenting raisins, as it doesn’t have the sour bread aroma.
The specific gravity (SG) fluctuated between 1065 and 1070. I couldn’t figure out why, despite maintaining consistent temperatures and timing for each cooking pot.
Ultimately, I think this will turn out to be a great product. I’m grateful for everyone’s help, and once the fermentation is complete, I’ll share the post-fermentation gravity reading and the clarified wash amount for distillation here.
Roger1
Post by Roger1 »
Well, friends, my fermentation has encountered an issue 😂.
The first barrel, which has been fermenting for four days, smells like sour yogurt. I checked it, and the SG has dropped from 1070 to 1030, yet fermentation signs are still visible. The second barrel, which has been fermenting for two days, smells like vomit. Since yesterday, I've spent a lot of time searching forums and reading articles. In the end, I’ve decided to leave it to continue and see what happens—it seems there’s not much I can do. I’d really appreciate any guidance or suggestions if you have them. 🙏
Roger1
Post by Roger1 »
shadylane wrote: Mon Mar 17, 2025 11:54 am I'd mix the alpha enzymes with the water at the beginning.
Hi shadylane
I would appreciate it if you could review the content above and share your thoughts. I also have a few questions to ask:
1. Based on what I’ve read in forums, if I raise the temperature to 175°F after mashing and then cool it down with a chiller, will that prevent bad odors and the growth of undesirable elements?
2. Would it be better if I don’t ferment on the grain, or would that result in a drop in the quality of the final product?
3. Do you have any better suggestions to avoid this issue in the future?
Thank you in advance for your help.
SW_Shiner
Post by SW_Shiner »
Sour yogurt is about right, well that's how i would describe it anyway. There's probably still fermentation signs because its still fermenting.
The vomit smell could be fine, what was the gravity of second barrel?
Roger1
Post by Roger1 »
SW_Shiner wrote: Mon Mar 24, 2025 10:30 am Sour yogurt is about right, well that's how i would describe it anyway. There's probably still fermentation signs because its still fermenting.
Hi
Yes, the first barrel is fermenting. The cap has fallen, but bubbles are still coming from underneath. As for the second barrel, it had a thick cap before, but now I checked and noticed that its thickness has reduced, and the SG has dropped to 1050. I just took a photo of the second barrel.
