1/2 gallon or 1 gallon glass
planohog
Post by planohog »
Where is the best place to find such items. Looks like 1/2 gallon running about 10 dollars at the WAL. I suppose I could check dollar general.
AMzn has a few things. I like the large mouth so to allow adding oak, squares.
Corn Cracker
Re: 1/2 gallon or 1 gallon glass
Post by Corn Cracker »
It never hurts to have a few 1g on hand, i need a couple of more myself.
I get em at walyworld
Sailman
Post by Sailman »
Yard sale flip top cannister
I have recycled all of the large mouthed glassware that I was encouraged to collect by enthusiastic newbies a few years ago. Now, I don't buy, (or accept), any glassware that does not accept easily acquired natural cork bungs.
Salt Must Flow
Post by Salt Must Flow »
I bought more than several 1 gal glass jugs from local junk shops, second hand stores or whatever you call them. They're usually 1 gal glass wine jugs. I then bought corks from WIDGETCO. I've heard people getting empty 1 gal glass jugs them from local bars, restaurants and recycling centers too.
For me, 1/2 gal wide mouth jars are useful, but no so much for storing product.
For years I kept my eyes & ears out for good deal on kegs. I've found them for free and some real cheap. Kegs are really handy for collecting Feints. I find 7.5 gal kegs really handy for holding product after making cuts and I use a bottom drain to spigot it out into my glass jugs.
jonnys_spirit
Post by jonnys_spirit »
I've ordered all of my 1g jugs, 1/2g jugs, and 1g wide-mouth along with appropriate widgetco corks from amazon. They come in nice cardboard boxes which helps me keep my paws off the product when I box em up and also protects the glass full of barrel proof from breakage with the heavy duty insert dividers..
jonny
planohog
Post by planohog »
Ohhh I might hate this but here it goes: Why use cork and not the cap on the bottle ? ( trying to learn ) . Granny Clampet has corks on her xxx jug
but since I only have XX on mine , trying to figure out the cork usage.
:crazy: :?:
I suppose this could be along the lines of a bottle of Mad-Dog vrs a bottle of Mateus , one has a screw top and one has a cork.
I found some interesting answers over at bourbonbanter dot com.
MooseMan
Post by MooseMan »
The caps will have liners of plastic, or be made of plastic.
If you're short of corks, a tight wad of cotton rag plugged into the top works fine.
subbrew
Post by subbrew »
I use the half gallon wide mouth canning jars for any product I put in glass. They are about $16 per 6 at Wallys. I like them as they easily allow you to put your oak fingers in for aging and will still come out even after they swell a bit. And the fact that I have a hundred or so as I use them for honey storage as well.
As for why cork, if you put the canning lid on your jar you will soon find out as the alcohol vapors cause it to corrode. They are not made for that environment.
Note, people above say natural cork. There are two types. The cheaper type is corks made from small pieces compressed and held together with a glue of some sort. (be aware they may also call themselves natural cork as the cork part is still real cork) These corks will eventually start to crumble as the alcohol dissolves the glue holding the pieces together. The other corks are more expensive but are cut from one sheet of cork. It may have more than one sheet glued together but the bottom surface facing the product will be one sheet.
Steve Broady
Post by Steve Broady »
On the subject of sealing mason jars, I've tried the large corks from Widgetco. They work, but they're still composite. I'm not sure if they're glued together, or lignin bonded, and I don't really know how to test that. What I've done is to buy a box of PTFE square sheets. They're sold for the "herbalists" though I have no idea what the actual purpose is. For me, they're the perfect size to fit over a mason jar, and thin enough to be held down tight with the standard metal ring. While most of my products are either in bottles, carboys, or BadMos, jars are definitely handy for smaller quantities and for the ease of access to wood, as mentioned.
Salt Must Flow
I saved this link from a previous topic about PTFE Disks/Cap Liners for jars.
3.5"(89mm) PTFE Disc - Wide Mouth
2.725"(70mm) PTFE Disc - Narrow Mouth
If you can find sheet material and cut your own disks for less, that would be a good alternative.
subbrew
Post by subbrew »
Steve Broady wrote: ↑Wed Sep 03, 2025 9:40 am On the subject of sealing mason jars, I've tried the large corks from Widgetco. They work, but they're still composite.
These are the natural ones. You can see it is three layers but the layer facing the product is one piece of cork. https://www.widgetco.com/collections/natural-jar-corks
jonnys_spirit
I've used these gallon jars:
https://a.co/d/cPKrwDt
With these Widgetco #44 size corks:
https://www.widgetco.com/products/size- ... -jar-corks
I appreciate being able to use larger pieces of oak and headspace in these jars and have had them sealed this way for a few years without issue.
jonny
BlackStrap
Post by BlackStrap »
When starting out... I had a buddy that would buy his Wine by the Gallon. He would get the wine and would give me the glass jug.
Here's something to think about. When making small batches of wine\mead, I'll use an Imperial Gallon jug, after the must has settled and allowing for headspace... I'll end up with just shy of a US gallon.
Stay Safe & Have Fun
BlackStrap
During spirit runs, there's no substitute for a shit load of small jars changed often.
After the run, cover the jars with a sheet of cotton cloth and wait till sober before blending.
Seal the individual jars that don't make the initial cut and wait before putting them into the feints jug.
Keep them separate because after time they might be good.
After blending, I like 1 gallon jugs tightly stoppered with white cotton cloth during the initial ageing.
planohog
Post by planohog »
I like pints,
Salt Must Flow
If you start doing the same recipe over and over again, you'll realize that your heads cut is always within a certain range of jars, like jar 8 for instance. After jar 10 I switch to much larger containers to collect hearts. You'll also learn approx what your total collected volume will be as well as where your tails cut usually is. Knowing that, it will determine when to start switching back to smaller jars to catch that tails cut and NOT taint the larger containers you were previously collecting in.
subbrew
Post by subbrew »
Salt Must Flow wrote: ↑Thu Sep 04, 2025 7:01 pm If you start doing the same recipe over and over again, you'll realize that your heads cut is always within a certain range of jars, like jar 8 for instance. After jar 10 I switch to much larger containers to collect hearts. You'll also learn approx what your total collected volume will be as well as where your tails cut usually is. Knowing that, it will determine when to start switching back to smaller jars to catch that tails cut and NOT taint the larger containers you were previously collecting in.
Or you may be like me who always has to tweak something just to see what happens and then you still need all the jars. :cry: Just make sure they are still there before you start your run. My wife has been known to "borrow" mine to can something.
jonnys_spirit
They do seem to go missing sometimes from run to run and every so often I need to purchase another case of mason jars....
On the small copper I use the ~250ml (?) jars and the ~800ml jars for the big copper :) - Probably about 20 jars total for me but I should bounce to 36 and make better cuts..
I also prefer to mix it up from run to run and do my cuts differently so I can have more diversity and ultimately blend or solera if possible into a final house-product for that style of likker... Maybe with single batch top shelf finishes for the ones that stand out :)
jonny
dieselduo
Post by dieselduo »
planohog wrote: ↑Mon Sep 01, 2025 10:36 am Where is the best place to find such items. Looks like 1/2 gallon running about 10 dollars at the WAL. I suppose I could check dollar general.
Check your lhbs. Mine has a case of 4 gals for $29
planohog
Post by planohog »
$34 Fastrack 4-Pack 1 Gallon Glass Jug Set (128 oz) with Polyseal Caps about 8 ish buck a pop, and I bough corks extra
Homebrewer11777
Post by Homebrewer11777 »
I've bought the 1 gallon glass jugs from Amazon. Currently about $8.50/each in the 8-pack. Number 14 natural cork I bought from Home Depot online and MoreBeer.
The narrow opening does mean I need to be careful with sizing my oak pieces for aging. I stopper the jugs loosely to allow some air exchange.
N00b
Post by N00b »
For 1/2 gallons I use milk jugs from the supermarket. I keep a bunch of them around and cal always return them to get the deposit back. So they’re free.
PalCabral
Post by PalCabral »
For those in Europe, german producer and onlineshop flaschenland de sells jars, demijohns and bottles for good prices. I get all my 4 and 5 liter jars from them.
Alzahra888
Post by Alzahra888 »
PalCabral wrote: ↑Sat Jan 24, 2026 9:35 pm For those in Europe, german producer and onlineshop flaschenland de sells jars, demijohns and bottles for good prices. I get all my 4 and 5 liter jars from them.
Much appreciate the info Pal. Good luck today with your running.
Somewhere between hurry up and time is irrelevant.
Knowledge might be expensive or cheap, but information is always costly.
PalCabral
Post by PalCabral »
Alzahra888 wrote: ↑Sat Jan 24, 2026 11:51 pm Much appreciate the info Pal. Good luck today with your running.
Thanks, Alzahra! In the 4th hour of running now. Just passed 5 liters produced. All well so far, knock on wood (madeira madeira madeira).
greggn
Post by greggn »
N00b wrote: ↑Sat Jan 24, 2026 8:32 pm For 1/2 gallons I use milk jugs from the supermarket.
Your supermarket sells milk in glass ? I haven't seen that in years (though I am on the opposite coast and you're in a much hipper area).
________________
N00b
Post by N00b »
Yeah. We get Straus and Alexander Valley farms in milk jugs in the run of the mill supermarkets. Whole Foods has more options.
They’re really nice jugs, I use them all the time.
planohog
Post by planohog »
thank you
