A chunk of maple wood
PalCabral
Post by PalCabral »
Now what do I do?
A tree fell in my neighborhood and I got help to determine it was maple. I went by and picked up a chunk of it. In fact, another feller joined me and picked an even bigger piece.
So here it is, but I’m not sure what to do with it. I was thinking of making sticks or cubes of it for aging in jars. What should I do now?
I realize the wood should be seasoned but should I cut it up first, or leave it as is? Appreciate a butt kick in the right direction.
subbrew
Re: A chunk of maple wood
Post by subbrew »
I think it will age faster if cut in to plank like pieces first, then stacked so there is airflow between the planks. Of course I can't talk. I have had a block, a tree section about 12 inches diameter, sitting on my deck for three years now. I am hoping it is aging OK as a block. Perhaps I will cut out some fingers this winter and try it. I would really like to try oak vs maple in a whiskey and perhaps an apple brandy.
PalCabral
Post by PalCabral »
Thanks subbrew. I need a decent saw to cut the wood up in planks as you suggest. I’ll check the mighty internet for some how to tutorials.
NormandieStill
Post by NormandieStill »
If you have access to a bandsaw, rig up a jig that will hold it straight and slice off a little from the outside. Use this flat edge as a reference against the fence to cut the remainder into slices (watch your fingers!). Stack the slices with little sticks between them, somewhere outside where they'll get full weather exposure and wait a year.
But it's a small branch you've got there. I don't know if heartwood vs sapwood is an issue for maple. You might have to try some experiments. There's a lot less tannin to get rid of, so mostly I think it just needs drying out.
You can cut one piece into staves and try drying them in the oven. Keep the heat relatively low (<100°C) and run it for a long time. If you've got some accurate scales, you can keep a record of the weight and see when the drying process tails off. Couple this with a quick boil in water and you should be able to get a test piece fairly rapidly (at the cost of a few kWhs and some of your time.
Edit to add: You can do without the bandsaw and cut it by hand, but get a rip saw for doing it. A normal crosscut saw (any standard job site saw) will foul up and make fine powder when doing rip cuts and you'll run out of energy before you've got much done.
PalCabral
Post by PalCabral »
Thanks Norm. Heartwood is from the core stem, right? Sapwood would be from all branches? Thanks for the handy tips! Appreciate it.
jonnys_spirit
Post by jonnys_spirit »
I've used either a handsaw or a chop-saw to cut pieces down into 4-5" lengths then a chisel and hammer to split into more finger diameter sized lengths so they'll fit through a bottle neck. They don't need to be all straight and pretty..
Heartwood section is preferred over sapwood.
-jonny
NormandieStill
PalCabral wrote: ↑Wed Sep 17, 2025 12:13 pm Thanks Norm. Heartwood is from the core stem, right? Sapwood would be from all branches? Thanks for the handy tips! Appreciate it.
You can get heartwood in branches but they need to be big (in oak anyway). Sapwood is where the growing happens, it's the living part of the tree. Heartwood is basically dead wood and acts as a support structure. In the case of certain species (oak, Douglas fir) it's also packed with chemicals that make it resistant to fungi and to insects. Some of these make some of the flavours we look for in our oaked spirits.
In oak and Douglas fir, the difference between them is striking. In apple wood it's visible but more subtle. I don't know how obvious it will be in maple.
Splitting is a really good idea but I don't know how well maple splits.
Blocks of maple from the trunk splits easy, but the piece pictured is going to be harder to split due to knots and twisted grain.
A hatchet and hammer can getter done. The strips split from it won't be strait or consistent like it would be from a bigger piece
PalCabral
Post by PalCabral »
My initial research shows, and if there are members here with more experience with maple wood than internet searches please chime in and correct me, that sapwood from maple is not as bad as sapwood from oak, but still not preferred. It seems like if I just season the wood long enough in the open, my biggest worry should be that the maple sapwood would add no flavor contribution at all. That's a risk I can take, the question if it's worth the hazzle is a different question.
The gentleman that was next to me by the fallen maple yesterday was definitely more experienced and prepared than me. He came with a wagon and a small hoist to lift a piece of the stem onto the back of his vehicle. His wife had a wood carving hobby he said. I told him my wife likes homemade Whiskey. :lolno: No I didn't tell him that and it's not even true. She doesn't drink at all, in fact. The only Portuguese I've ever met who isn't a drinker.
Powder Monkey
Post by Powder Monkey »
I’d see if you can narrow down the maple species, at least for any replication in the future. I’ve done limited experiments with Sugar Maple sticks and I would assume that is the main maple species people are experimenting with with.
I don’t know, but would assume that the different maple species would have different characteristics. Maybe not as much as oak, but it’d be worth looking into.
jonnys_spirit
Hey Pal,
I blew up the end view of your cut from the maple. Looks like you can see the heartwood section in the middle compared to the sap wood towards the outside. You can probably split the heartwood out for best use and compare them if desired.
-jonny
PalCabral
Post by PalCabral »
jonnys_spirit wrote: ↑Thu Sep 18, 2025 7:38 am Hey Pal,
-jonny
Thanks Jonny. That was encouraging. Much appreciated!
Demy
Post by Demy »
I cut a piece of oak with an ax ... rudimentary but function
PalCabral
Post by PalCabral »
jonnys_spirit wrote: ↑Thu Sep 18, 2025 7:38 am IMG_5717.jpeg
Hey Pal,
-jonny
Hey, Jonny. What do you make of this ruptured branch? Do you see heartwood in it too?
NormandieStill
I'm not certain that that's heartwood. Having built things from maple, I don't recall seeing anything other than white wood. I think that's more likely to be inclusions in the wood, or fungal colouring (Google spalted maple).
PalCabral
Post by PalCabral »
NormandieStill wrote: ↑Fri Sep 19, 2025 8:10 am I'm not certain that that's heartwood. Having built things from maple, I don't recall seeing anything other than white wood. I think that's more likely to be inclusions in the wood, or fungal colouring (Google spalted maple).
Discouraged again... ;) Maybe you're right. I take it you know wood more than the next guy, Norm? Carpenter? You do seem to know wood.
NormandieStill
PalCabral wrote: ↑Fri Sep 19, 2025 10:16 am Discouraged again... ;) Maybe you're right. I take it you know wood more than the next guy, Norm? Carpenter? You do seem to know wood.
Good guess. Roof carpenter by trade and I dabble in joinery and furniture making according to demand. I couldn't tell apart different species of oak, but I can distinguish most of the wood that grows around here (once it's cut, dried and planed. Don't ask me to identify the trees when they're standing! :wink:).
jonnys_spirit
https://www.woodworkerssource.com/blog/ ... BHL5R2QY3C
It looks to me like the dark part in the middle of those pieces is the heartwood..
-jonny
NormandieStill
jonnys_spirit wrote: ↑Fri Sep 19, 2025 1:02 pm https://www.woodworkerssource.com/blog/ ... BHL5R2QY3C
-jonny
I stand corrected. I've not come across maple heartwood before even in the full boards at the sawmill (essentially lengthwise slices of tree trunk).
PalCabral: if you can get enough heartwood out of it, it'd be interestingly to do some side by side ageing tests. Same spirit, same size stick.
higgins
Post by higgins »
I spent several years making furniture back in the 80's/90's, specifically making copies of antiques, including the joinery but using modern methods. I also spent about 15 years heating with wood, so I've cut down many trees for firewood. I've worked with many species (Southern Appalachia US), and most trees do have a color distinction between sap and heart wood.
Even with trees that don't show much of a color difference (maple, poplar, basswood, etc) the sapwood is generally only a few inches thick, so there might not be a clear delineation between the sapwood and heartwood.
https://cdnsciencepub.com/doi/10.1139/x94-133
The relationships of sapwood radial width and transverse area to tree diameter, age, and growth rate were investigated in Piceaabies (L.) Karst. A total of 125 trees growing with (suppressed trees) and without (dominant trees) competition for light were sampled. Both sapwood and heartwood amounts showed an increase with diameter at the stem base, with the heartwood portion increasing more rapidly. In young trees sapwood prevails both in terms of diameter and transverse area. After trees have reached a certain age, the width of the sapwood band remains more or less constant (on average 7.8 cm for dominant and 2.0 cm for suppressed trees), and the heartwood amount exceeds that of sapwood. The percentage of heartwood in suppressed trees is substantially greater than in dominant trees of the same age. Sapwood amount is closely correlated with the tree diameter, but not with age. Tree age controls the number of rings in sapwood, while the sapwood width depends on the tree's radial growth rate as well.
I think I'd do a side by side with 1 jar having a heartwood stick, and the other having a sapwood stick. That would tell you if the difference is as striking as it is with White Oak.
dieselduo
Post by dieselduo »
I often use the Lincoln County process where you filter the spirits through sugar maple to make Tennessee whiskey
PalCabral
Post by PalCabral »
Sounds like I have test in front of me. I like the challenge. But I guess I still need to season the wood for a good 6 months before it's ready for a test? Or is there a faster way to compare the two?
Copperhead road
Post by Copperhead road »
PalCabral wrote: ↑Sat Sep 20, 2025 1:32 pmBut I guess I still need to season the wood for a good 6 months before it's ready for a test?
I thought you would need a lot longer than 6 months for Seasoning…
NormandieStill
.If you can cut up or split the wood now then it'll dry faster and weather better. I'm not sure that maple is tannin-rich like oak so it might not require as much weathering as oak does. 6 months in the low humidity climate of Sweden (as I understand it) should dry it out nicely.
PalCabral
Post by PalCabral »
NormandieStill wrote: ↑Sat Sep 20, 2025 7:04 pm .If you can cut up or split the wood now then it'll dry faster and weather better. I'm not sure that maple is tannin-rich like oak so it might not require as much weathering as oak does. 6 months in the low humidity climate of Sweden (as I understand it) should dry it out nicely.
The average humidity in Stockholm is around 80%, and definitely getting higher in the winter that we're entering soon. We have a mix of snow and rain during the shit months. All in all, probably a good climate for weathering wood. 8) I'l get the axe out to split the ruptured branch to see if I can season smaller sticks of wood.
