cracked hydrometer
planohog
cracked hydrometer
Post by planohog »
I was working with a gumball type mash, and thought I had the correct measurement with added sugars.
Well after that mash got stuck and I could not get it going. I discovered a hair line crack and some moisture inside
my hydrometer. I tossed the entire gumball out.
Lesson learned these are not tempered glass, do not expose them to crazy ranges of water temp trying to clean them up.
Maybe before you start on your data taking , check it with plain water. sg=1.0
I believe the hydrometer gave me bad information after I added the sugar ( it probably was way to high , maybe north of 1.07 )
and the yeast could not deal with it. it never took off, i added new yeast, never took off. tried to get ph closer to 4.0 from 3.5
nothing worked.
pumped it down the drain.
Calibrate everything, and watch out the hyrdrometer glass is sensitive .
:crazy:
PalCabral
Re: cracked hydrometer
Post by PalCabral »
Usually hydrometers are calibrated for temps at 20C and although there are conversion tables to help calculate the real gravity/ABV at other temoeratures the further away from 20C you get the less accurate they hydrometers are. I always cool a sample from the mash in the fridge down to 30-40C before using the hydrometer.
BlackStrap
Post by BlackStrap »
Sorry to hear this planohog
I have a mead going that I was a bit tipsy (not recommended) when putting the actual recipe together the yeast I had was 15-18% abv tolerant. But I suspect my starting gravity was to high to start. Anyways...below are the changes I've made because of the lessons learned.
My shed my rules right? Here's a few that I've incorporated into my guideline booklet
Do not do anything that you value tipsy...
first I never throw anything out, unless I've exhausted all possible fixes... Even then go over the process again to see what didn't work.
Second always get 2-3 hydrometers (I like starting out with a Brix Refractometer) for an initial reading.
Is your yeast good... I've learned to hydrate the yeast before pitching...If it's not foamed up in an hour... possibly your yeast is dead and makes for good yeast nutrient.
If you believe you gravity is to high to begin with split your batch and add water (bring down the gravity)
Lately in all my brew I will add a tablespoon of oyster shells for natural PH adjustments...(I have chickens and quail so they are readily available here)
Stay Safe & Have Fun
BlackStrap
Corn Cracker
Post by Corn Cracker »
Man, they are fragile, i flicked my wrist to sling the water off after rinsing it, the bottom went across the kitchen, the skinny part still in my hand. i've been through several over the years, i treat em like the last egg in the basket now, use, rinse, spray, wipe and back in the plastic container
SW_Shiner
Post by SW_Shiner »
planohog wrote: ↑Tue Mar 24, 2026 8:17 am pumped it down the drain.
Why not pull some out and dilute to the correct SG with water?
Are you sure it never took off?
planohog
Post by planohog »
those are some great ideas, that entire batch was a problem, I was not detailed on my numbers at all. i was running on muscle memory I think, and because it was a gumball I thought how could it not work. Well , next time I will be careful as if it were my first time. Checking PH and Checking gravity and temperature. It has become very clear to me that if your having issues with your AG , you will continue to have them with a gumball from the same bucket.
Corn Cracker
Yup, sometimes ya just gotta scrap it, ive done it,,,,,a bunch :crazy: :oops:
