adding a 10psi pop valve to keg setup
planohog
Post by planohog »
Recently driving my keg pretty hard on a distilled water run. I decided that I might want a saftey valve in the unlikely event that something clogged up. I found on AM Mini 1/4" NPT Male Safety Pressure Relief Valve with Lock SS304 Stainless Steel Pop Off valve that looks promising. I figured I could mount it on the center of my 3" lid DERNORD Stainless Steel 304 Sanitary Fitting Clamp End Cap fits Tri-Clamp Ferrule Flange 3" .
I suppose the other option would be to allow that 3" lid to sit there on its own weight or very losely clamp it down. I was cruising at 1qt per ten minutes with 17amps at 220. or 3700 watts. I dont want unexpected pressure issues, that would manifest quickly into danger. your thoughts ?
acfixer69
Re: adding a 10psi pop valve to keg setup
Post by acfixer69 »
1/4" would not relief volume very fast, but maybe fast enough with the whistle as the alert. I'd go bigger.
Tammuz
Post by Tammuz »
On eBay you can find Apollo prv's at a discounted price at times. Make sure they are for steam.
planohog
Post by planohog »
yes if it popped i would be on my power button right away.
OFF OFF OFF
Is a steam rig being used or a pot with mash in it?
I'm guessing it's a steam set up since your asking about a 10psi prv.
planohog
Post by planohog »
its to keep the pressure inside a keg down under 10psi, its connected to a PC.
Salt Must Flow
Post by Salt Must Flow »
planohog, what is the smallest orifice in this still? Like what is the smallest restriction?
planohog wrote: ↑Wed Apr 08, 2026 1:11 pm its to keep the pressure inside a keg down under 10psi, its connected to a PC.
What's going to be in the boiler, water or mash?
It makes a difference because mash can easily plug up a small hole or gum up a small prv.
The majority of the cheap PRV's are rated at 15psi and above, there's not many options for a 10psi.
Here's one I found that has a 10psi set point. Amerec 2120-02 Pressure Relief Valve, 10 psi
https://www.walmart.com/ip/VALVE-PRESSU ... 261df032d2
planohog
Post by planohog »
Salt Must Flow wrote: ↑Wed Apr 08, 2026 1:32 pm planohog, what is the smallest orifice in this still? Like what is the smallest restriction?
TOP I have a 3" and a 6" , botton drain is 1" and heater port is 2"
planohog
Post by planohog »
shadylane wrote: ↑Wed Apr 08, 2026 1:52 pm
My apologies, beer, from a paint strainer, trying to be deceptive on porpoise.
planohog
Post by planohog »
shadylane wrote: ↑Wed Apr 08, 2026 2:14 pm The majority of the cheap PRV's are rated at 15psi and above, there's not many options for a 10psi.
Thank you 10 is not manitory , I do not fully understand what a liebig backpressure might be like under normal operation.I suspect that
just like a water hose, the longer it is the more pressure you lose along the way. In this configuration it is 4 feet of PC.
Windy City
Post by Windy City »
planohog wrote: ↑Thu Apr 09, 2026 4:14 am
What diameter is the liebig? That is probably the smallest orifice in the vapor path.
planohog
Post by planohog »
im going to say its a 1/2" starting at the top of the riser.
BlackStrap
Post by BlackStrap »
This is what I run planohog.
Mines rated at 5psi
Stay Safe & Have Fun
BlackStrap
Tammuz
Post by Tammuz »
If you look at what Shady suggested ( I bought 2 Apollos for around 60 bucks) and then compare that to small ones that can clog, or worse yet fire off with no direction known. I think most people have no clue how much pain a burn causes. You get a lot of safety,and piece of mind for 30 bucks.
Windy City
If you are worried about a 1/2" outlet getting plugged causing an overpressure situation, what makes you think that dinky relief will not get plugged.
I have the true pressure relief valves like the Apollo listed above on all my stills
Also as stated relief valves of that design can be dangerous when they blow due to not being able to pipe/direct the discharge to a safe location.
planohog wrote: ↑Thu Apr 09, 2026 4:18 am
Just guessing, for a keg sized pot and 1/2" liebig figure on around 0.1 psi = 2.8 inches of water
Another option is to use a manometer to measure boiler pressure and also act as a relief valve.
This one is filled with dyed water.
Salt Must Flow
Are you talking about just the boiler?
I was asking what the smallest orifice in the still is. What size is the smallest part vapor passes through that you are concerned could potentially get plugged?
Secale
Post by Secale »
What about putting a "T joint" with a valve in the distillation column that You can open at will?
Then again, maybe don't turn up the heat so high and slow down the distillation.
Dancing4dan
Post by Dancing4dan »
On the steam stripping still there is this PRV (as pictured) AND a manometer between the boiler and the thumper. both will release if a over pressure occurs.
The PRV is a steel ball sitting on a 3/4 inch opening. The copper ring and the spring just sit on the ball to ensure the ball does not fall off if pressure lifts the ball off the 3/4 copper. The spring IS NOT APPLYING PRESSURE.
Marcus Aurelius
Corn Cracker
Post by Corn Cracker »
If your not running solids in the boiler it shouldn't ever be an issue, i know you squeeze and strain your mash so, stay with the clear beer and your golden. It would take grains in the boiler and a heavy puke to get them to the ½ inch part of your riser/liebig transition and for a ½ wad to form and make it that far is unlikely, not saying it couldn't happen, like a perfect storm, I reckon the possibilities are there
planohog
Post by planohog »
Thanks CC, you know me and murphy's law and my spills and other issues that manifest themselves unexpectedly.
fzbwfk9r
Location: Smack Dab in the Middle of God's country. Saskatchewan!
Post by fzbwfk9r »
Dancing4dan wrote: ↑Thu Apr 09, 2026 3:51 pm On the steam stripping still there is this PRV (as pictured) AND a manometer between the boiler and the thumper. both will release if a over pressure occurs.
I think I'll replicate your PRV/SRV... what ever you want to call it with a manometer in parallel
my question, how many inches of water does it hold back? my calculations say about 10 inches
I want to incorporate this ball/socket into a Vacuum Safety Valve, so it will release vacuum before liquid is sucked up and over out of a thumper/s
if my thumper injection pipe is longer than 10", I should be GTG.
my question relates to how deep can the thumper liquid be before your PRV ball starts to let pressure out?
Dancing4dan
fzbwfk9r wrote: ↑Thu Apr 23, 2026 3:41 pm
The depth of the thumper is variable depending on what was fermented. I steam strip the stuff left over after cold crashing and siphoning off the cleared liquid. Corn and YLY leave only about 20% in my 20 gallon thumper/ fermenter after cold crashing. Barley leaves more slop and all you need to do is add some additional weight to the top of PRV set up. Stack of Canadian toonies seems to work for me. It releases real slow with lots of warning in my experience. If it starts to make a little steam leak, I add some weight and watch the manometer. Never blown the manometer.
Calculations on how much it holds back... I can't really talk to that. Not good at the maths. Certainly will run more than 10 inches. :wink:
The last steam strip the manometer lifted a 1/2 inch column of water 3 1/4 of an inch.
My experience says the PVR and the manometer fluid height are more dependant on the thickness of the material in the thumper than the overall depth. I understand that goes against scientific calculations... but it just is.
I have uploaded some pics and video a while ago specific to this topic. Have a look.
Marcus Aurelius
My 2 cents worth.
If it's predominately liquid, the thickness of the thumper charge doesn't make much difference in how much pressure is needed to blow bubbles.
What matters is the specific gravity of what's in the thumper.
The percentage of alcohol in the thumper can also make a small difference due to alcohol having a lower specific gravity than water.
With 50%abv in the thumper it will take around 10% less pressure to blow vapor up through the thumper.
Here's an example on how a thumper effects boiler pressure.
Let's say with only a pot and condenser, the boiler pressure runs around 2" of water pressure.
If a thumper is added with 8" of liquid, then the boiler pressure will increase to 10" WP
10" WP = 0.36 psi.
Dancing4dan
I’m using the steam setup to strip the solids left over from after racking off the cold crash “clear” liquid after fermentation is complete.
Marcus Aurelius
