Type of still has zip zilch nadda to do with makin cuts. Gotta use senses to tell what is keep n what is shyteStillerBoy wrote: ↑Sat May 30, 2020 2:32 pmBefore this can be answered, this has to be answered..Afshin_sam89 wrote: ↑Sat May 30, 2020 1:19 pm I want to know this jars are tails or this jars is head, you know,I want to know how can I understand that our heads is finish and then hearts is start.
What style or column design do you have to work with..
Mars
Cuts by colour
- jedneck
Re: Cuts by colour
big help
Dunder
big help
Dunder
Re: Cuts by colour
I will disagree on that one for sure..
Pot still cuts are much different than on a reflux column..
Mars
– Albert Einstein
– Albert Einstein
- jedneck
Re: Cuts by colour
But still need to use senses to make them.
big help
Dunder
big help
Dunder
Re: Cuts by colour
In agreement there.. smell and taste are still require to blend the finish product..
I should of clarified my statement on cut.. cuts are still a requirement to be done.. it's the amount collected per jar that is different ..
For a pot still collection, one is pretty well limited to collecting the same amount per jar, unless one has some means of identifying where the run is at.. whereas with a reflux column, since a reflux column allows one to compress, amount collect per jar will different, again providing on has some means of identifying where the run is at..
Mars
– Albert Einstein
– Albert Einstein
Re: Cuts by colour
It's what has been outlined in my previous post.. and you have a pot still setup..Afshin_sam89 wrote: ↑Sat May 30, 2020 1:19 pm I want to follow any mathematical method as I wrote for amount spirit run.
So determine the potental amount of alcohol extractable from the run (boiler load), then select the amount per jar you want to collect in each.. then once the run is done, let it air for a day or so.. then start in the middle and work back one jar at a time.. reduce a small sample, smell taste.. then do a blend of the ones you think are good based on your taste..
Research making cuts, as there are many thread on the subject..
Mars
– Albert Einstein
– Albert Einstein
Re: Cuts by colour
Heres what it looks like in reality . viewtopic.php?f=15&t=68702#p7500094
Re: Cuts by colour
Thanks Yummyrum..
Had those thread listed in my files, but a few months back, lose the data on my hd as it died on me.. in the process of rebuilding the data, but lots still missing and a pain to rebuild..
Mars
Mars
– Albert Einstein
– Albert Einstein
Re: Cuts by colour
Hi dear MarsStillerBoy wrote: ↑Sun May 31, 2020 8:50 amIt's what has been outlined in my previous post.. and you have a pot still setup..Afshin_sam89 wrote: ↑Sat May 30, 2020 1:19 pm I want to follow any mathematical method as I wrote for amount spirit run.
Mars
Thank you Thank you so much.
Re: Cuts by colour
Hi dear YummyrumYummyrum wrote: ↑Sun May 31, 2020 1:16 pm Heres what it looks like in reality . viewtopic.php?f=15&t=68702#p7500094
thank you for information
