I am building a box that is 30"x36"x18" with
tracker0945
Post by tracker0945 »
I have used one for brewing for years. I drilled a hole in the lid to accept a rubber grommet that the aquarium heater will slide neatly into. This leaves the controls and wireing outside and the glass tube inside the fermenter. Never heard of or seen a problem with this type of fix. As long as a sufficient length of the heater is submerged otherwise it can overheat.
2"x38" Bok mini and
Pikluk
Post by Pikluk »
i had good result with 3 carboy 2 with heaters and one in the middle,
all 3 wrapped together with thick towels even when room temp is about 17celcius .
gets really cold here during winter :/
have to had that i was only doing wine from kits before, but for keeping temp its pretty much the same thing, maybe even easyer with fast ferminting mash since they produce some heat.
The more you read the more you learn.
The more you learn the more you realize you don't know shit :)
