I am building a box that is 30"x36"x18" with
I'm having some issues with the time of year too and not wanting to keep my house at anyhting above 68 or 70. What I have for now that is working until I go the next step is a seedling mat wrapped around one 6 gallon carboy. It is holding fine at 82 to 84f on a DWG wash. Next to it I have a plastic 6 gallon pail with birdwatchers econo wash and a borrowed heating pad from a friend.
The pad does not wrap very far and probably won't get used again but will work for this one wash. Next I plan to make a small insulated room such as wineo is talking about. Something that will hold 2 carboys and maybe the 20 gallon trash can fermenter. I figure some stiff foam/plastic walls and a light bulb on a dimmer should do the trick. I've dried wood-turned items in old fridges by using a light and dimmer and it works well. Once you get the environment stable, everything in that space should achieve room temp or slightly higher in the case of highly active yeast.
I do have a submersible fish tank heater but I don't think they heat in the range that we want. It might be good for some, but I think the shutoff or limit is 76 or 78f.
~ After all these years, a drop in time helps soothe my mind ~
punkin wrote:Been using an electric blanket for 15 years for my kit beers. Just can't afford to run enough of em to wrap up all my different fermenters now. So an insulated fermenting room it is for me in the new shed.new_moonshiner wrote:a elec blanket on low works nicely.
3 door nonfunctional glass door drink fridge should hold heaps of em. Some kind of heat controller and thats it.
I've got a couple of things in the garage now that should work if space inside will allow. I used to do a lot of wood turning and after roughing out a wet bowl or other, I'd place them in an old fridge that had been converted to a warm or hot box. I use a regular incandescent bulb and light dimmer. Worked great for drying wood, should work great for controlling fermentation environments.
Now, all I have to do is clean some in the garage so I can get to them, and move one into the house.
This may save me building a 3 foot or 4 foot box from insulating foam.
As-Ol-Joe wrote:I am building a box that is 30"x36"x18" with 2 light bulbs on a dimmer switch. Should be able to control the temperature with ease. A friend mentioned using an old water bed heater, not sure how well that will work.
I have a tea chest with polystyrene insulation and a 15 watt pilot light in the side - at the bottom.
It works a treat in all weather needing extra heat.
blanik
Cumudgeon and loving it.
I to use an old frig. and tried just hanging a light bulb in there but with the temp. swings out side, there were some major swings in the frig. I dropped by homedepot and picked up a line voltage thermostat and now use a regular heat lamp bulb. Everything will usually stay +/- 5 degrees f. Works well for me.
Make a box out of two inch styrofoam insulation with a lid but bottomless so you can slip it over your fermenter. The size depending on the size of your fermenter(s). Put it all together with duct tape
I dangle a bulb through the lid. I don't use a line thermostat, but I will damn well look into it. At the moment I simply vary the bulb size depending on room temperature.
G
G
My sugar wash for ethanol is under the Tried and true recipes forum.
This is what I am using on my box
http://cgi.ebay.com/Universal-Digital-P ... dZViewItem" onclick="window.open(this.href);return false;" rel="nofollow
and this
http://cgi.ebay.com/SSR-Solid-State-Rel ... dZViewItem" onclick="window.open(this.href);return false;" rel="nofollow
That enough even to control a house furnace. It will work with two lights easily.
and this
[quote="arkansas"]Shadylane, how do you get the home furnace thermostat to work with line voltage? or do you have a transformer in there somewhere? I tried to make one of them work but with out success. :cry: although the line voltage one cost me about the same.[/quote]
They are just a coiled up bimetal strip with a mercury switch, it dosn't care what voltage as long as you dont pull too much current.
A few ideas that require no energy: Put yer fermenters in yer hotwater heater cabinet... put a fermenter or two on top of yer refridgerater or a high sturdy shelf ( a room at 60 deg might be near 70 deg near the celing)... If ya have no trouble gettin' healthy vigourous fermentations then simply usin' larger fermenters and insulatin' em well will do the trick (I've have fermenters maintain 70 deg F by themselves in a 49 deg cellar).
I wish ya luck.
I wish ya luck.
I see lots of great ideas here. I checked the garage and without moving a couple of motorcylces out and some other stuff, there's no way to get one of the old fridges into the house right now. We are into a deep freeze here with the latest ice storms etc. so I don't care to drag stuff out of the garage.
So
This past weekend I made a nice foam box. It's 36 x 36 x 30 tall, using 1" thick stiff foam. The two end pieces have a 1" x 1/2" deep slot so the sides interlock more or less. I use no tape. For now I'm just testing it and monitoring the temperature with a 60W bulb near the floor. I do have the light on a green air products cyclic timer so it's not on all the time. Temp so far has been fairly steady at 84F so I'll probably lower it just a bit. I'll use it for the next ferments.
A very small fan to recirculate and even out the air may be a good idea if your box or 'area' is very large. Temps near the floor vs the top will be different.
So
Still_Crazy wrote:I see lots of great ideas here. I checked the garage and without moving a couple of motorcylces out and some other stuff, there's no way to get one of the old fridges into the house right now. We are into a deep freeze here with the latest ice storms etc. so I don't care to drag stuff out of the garage.
So
You might want to place your box over your fermenter filled with water for testing. The temperature of the air around the fermenter will be higher than your wash.
G
Re: I am building a box that is 30"x36"x18" w
Good point, thanksbirdwatcher wrote: You might want to place your box over your fermenter filled with water for testing. The temperature of the air around the fermenter will be higher than your wash.
G
On another note... there won't be any heat or lights at all today in my house of any kind. We are right in the middle of a ice storm (middle of the country, USA). I stayed the night with a lady friend last night, I arrived home this am to find no power. Two ferments are going to slow or stop
I did bring my latest gallon of oak in and started filtering it here in the office.
Missus ordered this for me the other day for xmas...
http://mashmaster.com.au/p/365439/fridg ... r-kit.html" onclick="window.open(this.href);return false;" rel="nofollow
Thanks Hookline for the suggestion and the link
thought about building a box then i thought about some aquarium heater i had, cuted the wire passed it trough a drilled hole in the airlock rubber, those have thermostat.
you can get aquarium submersible heater cheap on ebay.
cheap ones are a pain to adjust but once there set it keeps you mash at a minimum temperature.
just dont forget to unplug before taking it out.
its a bit more messy then using a belt but they work great and have adjustable thermostat.
The more you read the more you learn.
The more you learn the more you realize you don't know shit
Pikluk, I had the same thought. I tossed it out here for the forums thought and here are the results.
http://homedistiller.org/forum/viewtopi ... 52&start=0
You WILL get addicted to this forum.
The Parent site is REQUIRED READING!!!
well i have 3 heater going on for 1month and a half now "still new to the game" no problem yet, knock on wood.
only doing 10-12% wash.
those heater most of the time are like test tube with a heater inside with a cork on top.
maybe that africaunite guy just had bad luck and the glue from the "cork" got dissolve in the 15%+ wash
and there ricky that used one for over a year...
about a aquarium heater starting a fire i really doubt it, even 20% wash dont burn.at least not easily.
and a personal thought if its rated form salted water, salt is a really vicious, will make stainless steel rust, i know corrosive is not the same as a solvent...
keep you posted if i get any problem.
