Advice for my first still setup
Posted: Tue Jan 02, 2024 12:41 pm
by Steelers_Stiller
I am interested in putting together my first still. I've got the means to do some fabrication. No tig welder but I can cut, drill, solder, etc..... Been looking around at a bunch of options to build vs. buy. I get a bit overwhelmed with all the info here an options.
I'm interested in making basic whiskey, someday maybe being able to hit the targets of an actual bourbon. I'd also like to make some clear spirit that I could do some simple infusions with.
Been really leaning toward getting a 1/2 Barrell Keg and modifying it. Or maybe just buying this one because I can't seem to find any cheap ones locally. https://www.gwkent.com/15-gallon-semi-keg.html
Seems like a decent deal. Thoughts?
I am considering building a 2" stainless steel column to come up off the keg. I see there are a bunch of companies on Amazon that sell sanitary pipe. One that I am looking at is called Dernord. Reviews look pretty good and pricing is reasonable. Anyone here have experience with this company, or other competiors on Amazon? I was thinking of 18" riser, then (2) 90 degree fittings, into a reducer that goes down to 3/4" NPT. All these pieces would have 2" T.C connections. Buying all this would be cheaper that 10' of 2" copper pipe.
I would then build a copper Liebig, 1" over 3/4", overall length between 4 and 5' long to connect to the stainless steel. See attachment for details on the build. One question I have on the liebig is would your recommend a 90 or 45 at the connection to the column?
Thoughts on this setup for my intended purpose?
Another option I see is this premade "Reflux Column" found on Amazon. Anyone have experience with these. Current price on this is just over $100. There are many other options that all appear to be the same. I'm sure all of this is made in China, not the best quality but, wondering if its useable.
Thoughts on this setup for my intended purpose vs. making the column and Liebig as noted above?
