Just Post a Pick of your Rig
Bobbydigital84
Re: Just Post a Pick of your Rig
Post by Bobbydigital84 »
It does great, i couldn’t make it huff even trying. Super happy with the tri clamps and still head for the keg, it’s a winner
Stump Lake
Post by Stump Lake »
This is a Vevor Air Still. I'm making OEG gin. I do my main distilling in a 15gal beer keg. I do my finish gin in this air still. I love it. It's just so damn easy.
adamf
Post by adamf »
Stripping rig for clear beer/wine.
Steam stripping rig for mash slurry
The 8" ferrule/top on the steam stripper allows for ease of filling/and cleaning out stripped mash and mash slurry. I'm really happy with that size. Sanitary TIG makes it rock solid. Many thanks to the craftsmanship of Twisted Brick. He made the shotgun condenser used in both rigs. :thumbup: :D
"...and I wound up spendin the night in a corrugated conduit with a cat." Suttree, Cormac McCarthy
MooseMan
Post by MooseMan »
Nice view from the still house!
jonnys_spirit
Post by jonnys_spirit »
Added a second helmet for infusion and stuff :)
It’s a little shiny for me.
Cheers,
Jonny
Copperhead road
Post by Copperhead road »
Very cool looking set-up jonny, whiskey helmets are pure copper porn!
What is your column diameter?
jonnys_spirit
Copperhead road wrote: Wed Oct 01, 2025 6:03 pm Very cool looking set-up jonny, whiskey helmets are pure copper porn!
Hey thanks Copperhead! The boiler port riser is a 4” TC so the first helmet is 4” with a reducer to 3” to the second helmet which then hits the 3” riser with a 3” sight glass at the top. After the elbow at the top it reduces to 2” for the shotgun. Straight up pot still. New parts for me are the 4” boiler port and 4” helmet. Plan this season is to use the dual helmets in addition to a boiler false bottom to cook/vapor infuse grape pomace brandy/grappa. Pomace loosely filled up to around the sight glass which is two helmets and 12” length of 3” diameter riser. I have a 36x3” riser section as well but the ceiling starts to get in the way. At the moment I could rise it up about 16” more and might get a 4” spool to do that before it’s time to start stripping in a month or so.
Cheers,
jonny
PalCabral
Post by PalCabral »
It's a beauty, Jonny. I am getting a heck of passive reflux from my copper helmet, I can't imagine the kind of reflux you'll get from two if them. Have you put your sight glass under the lowest helmet just to see the reflux you're getting?
Ongoing projects: Yellow Diamond Oated Bourbon v2; A Neutral spirit based on whiskey feints.
Stonecutter
Post by Stonecutter »
jonnys_spirit wrote: Wed Oct 01, 2025 4:38 pm IMG_5827.jpeg
Cheers,
Jonny
Way too shiny! You better send it over to my shed and I’ll get a nice patina put on that for you :wink:
Awesome Rig Jonny’s!
-Thomas Paine
jonnys_spirit
PalCabral wrote: Thu Oct 02, 2025 9:22 am It's a beauty, Jonny. I am getting a heck of passive reflux from my copper helmet, I can't imagine the kind of reflux you'll get from two if them. Have you put your sight glass under the lowest helmet just to see the reflux you're getting?
The passive reflux isn't as much as with the alembic with the wide column... I usually keep it up top to catch foaming before a puke. That allows me to run it with as much power as possible with it bubbling up into the sight glass and pull the power back if it surges... I should try sight glass underneath the gauge any passive reflux..
Thanks for the tip!
Cheers,
jonny
Homebrewer11777
Post by Homebrewer11777 »
NormandieStill
Post by NormandieStill »
jonnys_spirit wrote: Thu Oct 02, 2025 3:02 am IMG_5834.jpeg
Venue? Recording studio? Nicely coiled sets of tails in the background! :-)
jonnys_spirit
NormandieStill wrote: Sat Oct 04, 2025 8:53 am
Lol yes I have an “audio problem” too ;) ^^ DIY M49 style tube mics
Cheers,
Jonny
SteadyStills
Post by SteadyStills »
Is 50 posts a minimum for posting pics?
SteadyStills
MOD Edit : please don’t use imjur for hosting pics . I have attached this to the forum fir you this time
greggn
Post by greggn »
SteadyStills wrote: Tue Oct 07, 2025 12:09 pm
I'm really nervous that you're collecting onto a heat source. Surely you can move the collection point further away.
________________
SteadyStills
It’s been corrected since then
adamf
Post by adamf »
Updated the still head config for stripping and steam- stripping. Used two 90 degree stainless elbows and threw in a sight glass--I was able to use it immediatly and avoided a puke. Steam-stripping 7 gallons of mash slurry. 10 gallons of water in the boiler. The chickens get the cooked slurry. :D
NinetyFive
Post by NinetyFive »
I was asked for some pics of my setup so here goes.
This is what I started with last fall and ran it till the beginning of this summer.
I wanted to improve the final product so I went ahead and made two sieve plates.
Next came the reflux condensator
I ran this for few months and was able to get 85% ABV but that was not good enough. I also built a new cooler for condensation as you can see.
I decided to go for packed column and went from 3,5 inch to 3 inch column. I added tri-clamps as well so everything would be easier to disassemble
This is what I run now and it gives me 95%ABV. I would have wanted to do a bit longer column but I ran out of space!
I pack the column with stainless scrubbers. I tried lava rock as well but it did not perform as well and crumbled a lot.
I also have few upgrades in my mind I want to do:
  • Insulate the column
  • Add temperature gauge to boiler
  • Add valve to the bottom of boiler for easier emptying
  • Change to electric heating from gas
  • Bigger boiler
Alzahra888
Post by Alzahra888 »
NinetyFive wrote: Wed Nov 05, 2025 2:10 pm I was asked for some pics of my setup so here goes.
Very cool, looks like some very skillful work went into it. how many liters or gallons is the boiler?
Somewhere between hurry up and time is irrelevant.
Knowledge might be expensive or cheap, but information is always costly.
NinetyFive wrote: Wed Nov 05, 2025 2:10 pm I pack the column with stainless scrubbers. I
Is there any copper in that still at all? All that I see is stainless steel.
Twisted Brick
Post by Twisted Brick »
Saltbush Bill wrote: Wed Nov 05, 2025 11:02 pm
It looks like the vapor tubes in the ‘reflux condensator’ might be copper, Bill.
Salt Must Flow
Post by Salt Must Flow »
Twisted Brick wrote: Wed Nov 05, 2025 11:35 pm
What gives you that idea? The thickness alone makes me doubt they're copper. Even IF they were it would benefit with at least a few rolls of copper mesh at the base of the column.
Twisted Brick wrote: Wed Nov 05, 2025 11:35 pm It looks like the vapor tubes in the ‘reflux condensator’ might be copper, Bill.
Your right, I thought the same to begin with, but then decided that they look more like stainless.
Im sure the owner will be along soon to let us know.
Twisted Brick
Saltbush Bill wrote: Thu Nov 06, 2025 12:21 am
Ya, I was fooled by the color, but it (and the welds) sure look like stainless now. I was looking to give him the benefit of the doubt.😁
Colour got me to.......could still be wrong though.
Alzahra888
Dismantlable
NinetyFive
Alzahra888 wrote: Wed Nov 05, 2025 10:27 pm Very cool, looks like some very skillful work went into it. how many liters or gallons is the boiler?
Thanks, I always make 25 liter batch and that is pretty much the maximum I can fit into the boiler
Saltbush Bill wrote: Wed Nov 05, 2025 11:02 pm Is there any copper in that still at all? All that I see is stainless steel.
The still is completely stainless, but there is some room under the reflux condenser, so I put few pieces of copper tubing under there and add one stainless scrubber to keep them in place when I assemble it
More copper wouldnt hurt.
PalCabral
Post by PalCabral »
Cheers,
jonny
Jonny, I really dig your boiler, man! Did you build the boiler yourself or is it bought somewhere? Me want!
