Page 33 of 43
Posted: Sun Jan 01, 2023 12:17 pm
by icrazy
It didnt work before because thingiverse doesnt suport 3mf files so ive put up a stl file and its working now
Posted: Sun Jan 01, 2023 12:26 pm
by icrazy
Found these jars on ebay there 8 ltrs so i cut ptfe inserts for them and im using them to hold my rum and whiskey and when one gets full i make a bad motervator barrel and fill the barrel then repeat.
https://www.ebay.co.uk/itm/274931118480 ... media=COPY
https://www.amazon.co.uk/gp/aw/d/B076BS ... asin_title
Put in a link to the jar and the ptfe in case anyone wants to use them.
Posted: Tue Jan 03, 2023 8:15 am
by 6 Row Joe
I looked through a few pages of this thread and didn't find a answer. How do you remove a stuck stopper. I got after mine with some 12" pliers and it won't budge. Any tips?
Posted: Tue Jan 03, 2023 8:17 am
by Ben
Run a screw in and use a slide hammer. If you don't have a slide hammer you can use a standard claw hammer and a block of wood to pull it like a nail.
Posted: Tue Jan 03, 2023 8:36 am
by 6 Row Joe
Ben wrote: ↑Tue Jan 03, 2023 8:17 am
Thanks. I had that thought. I don't know if I still have a small slide hammer. I will have to dig around. I remember getting a extra plug. I will have to look for that one as well. I wonder if dipping the plug into hot wax before inserting would help. It would seal it for sure and may make pulling it easier. Teflon tape might work as well.
Posted: Tue Jan 03, 2023 8:40 am
by jonnys_spirit
I tap mine with a hammer on alternating sides of the bung until it comes loose - gently. Reseat it the same way except tapping it into the hole. Mine came with an extra bung which is in the ziplock with all my carboy corks
Posted: Tue Jan 03, 2023 9:34 am
by 6 Row Joe
jonnys_spirit wrote: ↑Tue Jan 03, 2023 8:40 am
That worked, thanks.
Posted: Tue Jan 03, 2023 6:08 pm
by Dougmatt
This is what I do as well.
Posted: Sun Jan 08, 2023 9:21 am
by OtisT
6 Row Joe wrote: ↑Tue Jan 03, 2023 8:15 am
It the tapping of a hammer side to side as described above does not do the trick, like you I resort to channel locks (big pliers). I secure the barrel with the face up, put a very strong squeeze on the tool holding the bung and at the same time tap the end of the tool hard to twist the bung loose. The bung gets a little chewed up but nothing that makes them unusable. If you don’t grip firmly you can strip wood off, so squeeze well before twisting to minimize damage to the bung.
Posted: Sun Jan 08, 2023 7:22 pm
by The Baker
Suppose you smear the bung lightly with beeswax before you fit it.
That should help it go in, help it seal, and help it come out.
Posted: Tue Jan 10, 2023 12:44 pm
by welly
On the opposite side, how hard/deep should I hammer the bung in? I've just received my BadMo barrel today, have filled it with water (as I don't have a spirit to put into it) up to the bung hole and I stick the bung in. Have put it on its side and it's definitely leaking from the bung. So obviously not in far enough. I don't want to knacker this thing so any tips on securing the bung?
thanks!
Posted: Tue Jan 10, 2023 7:28 pm
by Dougmatt
welly wrote: ↑Tue Jan 10, 2023 12:44 pm
thanks!
I knock all the bungs in until any leakage stops. The bung will get stuck as swelling occurs so you don’t have to really bang it in. I give it a solid hit, then leak check. Stop hitting it in once it’s not leaking anymore. Usually only takes a few solid taps for my 4 Badmo’s.
Posted: Wed Jan 11, 2023 12:41 am
by welly
Cheers Dougmatt! I'll give it a bit more of a knock.
Posted: Wed Jan 11, 2023 5:24 am
by quadra
Thanks, those look great!
Posted: Sun Jan 15, 2023 9:01 pm
by Badmotivator
Hey, this should be fun! 160 used bourbon barrel heads arrived a few days ago. I'm still playing around with an efficient and successful workflow, but initial tests have been promising. I'll try to make a video dealing with the different challenges of using this wood source in the coming weeks.
Posted: Sun Jan 15, 2023 9:06 pm
by Badmotivator
I have a question for all of you!
What is the specific, technical name of the set of tongue and groove shaper bits which cut this profile, used often by cooperages for joining head staves?
Posted: Mon Jan 16, 2023 7:33 am
by Ben
(Double) cope tongue and groove. AKA shaker rail and stile.
Search for infinity 83-034, should give you the pattern numbers so you can talk to someone about the double sided version.
Posted: Mon Jan 16, 2023 9:35 am
by Badmotivator
Ben wrote: ↑Mon Jan 16, 2023 7:33 am
That's getting close! Thanks for your suggestion.
I'll probably have to just work the phones and emails with the shaper bit companies. I need the set of shaper bits to do the jointing as well as the shaping (cutter elements all the way up, no bearings or spacers) in order to skip a jointing step in my process.
Posted: Mon Jan 16, 2023 6:58 pm
by TwoSheds
If you're not married to that exact profile, there is a large selection of 'glue joint' router or shaper bits to choose from. With consistent wood thickness and careful adjustment any of them should yield something tight enough to be waterproof once slapped together, crammed into a bain-marie, and swelled with the liquid of choice.
e.g.
https://www.toolstoday.com/v-6171-55388 ... AjEALw_wcB
How do you plan to accomplish both jointing and shaping with the same bits? It's certainly possible with the right fence setup, but I would tend to joint with a jointer with comparably cheap cutters, then shape the joint with the more expensive and precise glue joint bit.
Regardless, I'm looking forward to seeing what you're cooking up this time!
Posted: Tue Jan 17, 2023 7:34 am
by Ben
I really like the shaker joint geometry... it's enough to hold it together for light machining without glue, self centering, and should exert pressure out across the face as it swells. I don't know why it couldn't be your planing and jointing step in one, offset the outfeed fence from the infeed and go to town, thats exactly what a jointer does, jointer just has different cutter shape. If you have autofeed on your shaper this would be a beast of a way to save some time/labor.
Posted: Sat Jan 21, 2023 1:20 am
by User12345
Badmotivator wrote: ↑Sun Jan 15, 2023 9:01 pm
Wow! Definitely want to use some old barrels to try finishing.
Looking forward to the vids.
Up to barrels 3 & 4 here. Mucked up and drilled the wrong face and tap hole on one but nothing goes to waste!
Posted: Sat Jan 21, 2023 8:00 pm
by CoogeeBoy
I would think one of the first challenges would be finding bain-marie big enough to fit those!
![Angel :angel:](./images/smilies/icon_angel.gif)
Posted: Sun Jan 22, 2023 7:56 am
by icrazy
Im using old barrel lids and find they are working realy well. I have found that if i put them in backwards i get more flavour as the outside wood of a barrel hasnt been used.
One problem i have found is that some barrel lids are verry spent on the inside part and have shrunk a lot so they dont like to stay straight when there put into the bain marie. But with a little persaverance i got there.
Posted: Thu Jan 26, 2023 7:01 pm
by User12345
The collection grows!
Shot of the vevor CNC too if anyone curious:
Posted: Fri Jan 27, 2023 7:53 am
by Badmotivator
jonlah wrote: ↑Thu Jan 26, 2023 7:01 pm
That’s the stuff! It’s a fine start. I can’t wait to see your collection grow!
I’m curious! How long does it take for it to etch one of those blocks of text? My Laserpecker is OK but I wouldn’t mind a speed boost if the price is reasonable.
Posted: Fri Jan 27, 2023 12:27 pm
by User12345
Badmotivator wrote: ↑Fri Jan 27, 2023 7:53 am
Too long! Prob 30 mins for each. I bought the 0.5w model not knowing the speed to burn. I think the 5w one was less than AUD $100 more...not sure if that means 10x faster though.
Posted: Fri Jan 27, 2023 4:16 pm
by LordL
Bad motivator, where could I get hold of the steel buckets? Are they on Amazon or something similar?
I'm on your mailing list, but I guess there might be a couple before me in line for a complete barrel... :/
Posted: Fri Jan 27, 2023 5:16 pm
by bcook608
LordL wrote: ↑Fri Jan 27, 2023 4:16 pm
https://www.webstaurantstore.com/choice ... BMS12.html
Posted: Fri Jan 27, 2023 6:20 pm
by LordL
Thanks!
Posted: Fri Jan 27, 2023 6:24 pm
by bcook608
LordL wrote: ↑Fri Jan 27, 2023 6:20 pm
Thanks!
No problem! If that isn't the size you want, just do a search for "Bain Marie Inserts" and you should see a plethora of different sizes.
