Hello Hook, there is no copper in the vapor path, not sure how I could introduce some? Not sure what type of reflux still it is but all I know is that there is no heating control on the boiler and that the cooling water inside the column follows a double helix run, goes in from the top down and back up the top and out.
Thanks again.
Edit - here is a cut and paste of the manufacturers selling points from the Ebay posting.
" The All-Aussie Still "
MADE FROM BRAND NEW 100% PURE CLEAN 3:16 STAINLESS STEEL
UPGRADED TO DIGITAL THERMOMETER
This New Australian made High output internal condensing reflux still. Made from 100% 3:16 grade Stainless Steel
This sturdy design easy to operate Spirit Still will produce 95% Ethanol alcohol or can be used for the extraction of essential oils or distilled water.
The still head stands 600mm high by 50mm diameter and has been polished to a high finish. Comes with it's own boiler fitted with an electric heating element. Comes with digital thermometer and all hoses needed for operation. This still has been designed with Australian conditions in mind and runs on a minimal amount of water.
The still heads have been Tig Welded with 316 grade filler wire by a tradesman of 25 years experience, the welds are clean and neat.
Our internal condensing still head has been designed and made by us to run on and up to a 25 ltr boiler with a minimal amount of cooling water producing a high quality and percentage spirit.
All our Stills are tested to the Highest Quality standards. To guarantee, Workmanship and Performance.
You can buy our product with confidence.
Our Still Head stands 600mm high x 50mm diameter, This is a professional unit. We make our Still heads from Brand New 100% 3:16 Marine, food grade Stainless Steel, The best you can get.
" Contents "
1.. 600 mm Internal Condensing Reflux Still Head
2.. Stainless Steel Boiler, with heating element fitted (message me for boiler size)
3.. 2 metres of 8mm clear nylon hose.
4.. Rubber seal and clamp
5.. Full easy to understand instructions
6.. Reflux Packing ( installed and Ready )
7.. 12mm Clear nylon hose for distilling outlet
8.. Digital Thermometer.
Some home truths & Questions to ask before .buying a still
What is the height & diameter of the still head? Is there enough area for the reflux action to work to produce a clean pure product? The more reflux area the better
What is the still head made from.
What was the still head welded or soldered with? Some solder contains high levels of Lead.
How much water will the still head run on? A smaller still head fitted to a larger boiler than it was designed for will need more water to keep it cool, with some you wont be able to.
Is the heating element to large? This will only force you to use more water to keep the unit cool, you also risk exploding the yeast cells causing a foul smell in your spirit. We use a 1380 watt element to reduce water usage and because it produces a pure clean product.
SOLD! I brought one
The beginning of wisdom is to say "I don't know".
