fermentation done?
Posted: Mon Oct 12, 2009 11:20 am
by fryguy17601
I have a sugar wash of 17.5 lbs of sugar and turbo yeast. It has been sitting for 8 days now. It is showing as 20 proof and the hygrometer is showing at the very top above the 999 which is above the 1.0 mark. It has gotten colder and the bucket temp is down to 63 which I know is to cold but if it is ready I would like to run it through my reflux still.
Re: fermentation done?
Posted: Mon Oct 12, 2009 11:44 am
by rad14701
If the SG is at 1.000 or lower, which yours is, and the bubbling has all but stopped, and the yeast is dropping, then the fermentation should be complete...
Posted: Mon Oct 12, 2009 11:50 am
by fryguy17601
it is still very cloudy, does this matter or can I run it cloudy? Will that make the end result cloudy? What do you use to empty the bucket into a keg? I have not seen any metal funnels anywhere locally just plastic. Would they work for this?
Posted: Mon Oct 12, 2009 2:50 pm
by rad14701
fryguy17601 wrote:it is still very cloudy, does this matter or can I run it cloudy?
The wash won't "clear" as much as it will "settle"... Once the solids have dropped it's a matter of choice as to how "clear" you wait for it to get... When in doubt, wait a bit longer... You'll know when it isn't getting any "clearer"...
fryguy17601 wrote:Will that make the end result cloudy? What do you use to empty the bucket into a keg?
Cloudiness in wash should not carry over into your spirits under normal circumstances, but off tastes and smell might... Simply siphon (rack) the fluids off the yeast/trub on the bottom of the fermenter...
fryguy17601 wrote:I have not seen any metal funnels anywhere locally just plastic. Would they work for this?
Plastic funnels are just fine for fermented wash due to the low alcohol content... Distilled spirits at high ABV should only contact glass, copper, or stainless steel, however...
Posted: Sat Oct 17, 2009 6:20 am
by CletusDwight
fryguy17601 wrote: I have not seen any metal funnels anywhere locally just plastic.
Maybe y'cn make a copper funnel. I guess tin(plate) would be OK too?
Posted: Sat Oct 17, 2009 7:00 am
by Dnderhead
just make one out of a bole, a stanless bole and a piece of copper pipe as a spout.
Posted: Sun Nov 01, 2009 5:35 am
by jahsin
easier & cheap funnel can be made by chopping the bottom off a glass bottle!!chea
