First of all, my main interest is in essential oils but that should not be germane to this situation, since I am guessing the underlying design flaws will be the same.
I just purchased at auction for a whopping $2 a lovely SS 4 qt Revereware pressure cooker. This will be my boiler. I am not concerned about the size since I am not trying to distill 5 gallons of mash, but rather a couple pounds of botanical material. But I digress. So I went to the local home center and purchased some copper. I got a threaded 1/2 adapter male and female. I plan on removing the tiny valve from the center of the lid and re-drilling it to fit this pair of adaptors, hoping that if I screw them together tight enough I will not need additional gasketting, after all there is none in use with the SS valve that is there right now. Once I have them in place I will be able to either solder or dry fit a 1/2 copper pipe on to it. I plan on doing 2 corners on that so that it is a very simple still head with no additional column and after the 2 corners connecting it to the condenser.
Here is were I am expecting the problem. I have only seen one still for sale that used a design like this, as all the ones I have seen here use running water so bear with me and help me to understand where my thinking is flawed.
I got 20' of soft coiled 1/4" L copper tubing. I also picked up an igloo cooler (the round ones that you fill with drinks and dispense with a push button spigot on the bottom. I drilled a hole in the bottom, and one in the top (side) and placed the coil in there with one end sticking out the bottom and one sticking out the top. My plan is to connect the output of the still head with a reducer to the top of the coil, fill the cooler with ice and water, and perhaps a little salt, (or even who knows, maybe dry ice ) and simply use the bottom of the coil as a drip spout. To me, 20' of 1/4" tubing seems like a lot of surface area, and what I am guessing to be 5 or so gallons of ice water would be a pretty good heat sink.
Once I get some silicone sealant around the drilled holes I will try a run with water to see if I have simply designed a steam jetty or a still.
I am not looking for spoon feeding, or specific EO info, as I know this is a forum for beverage based distilling. I do feel that there is enough in common that there should be some transferable concepts. And to me it seems odd that if everyone is using running water, I can't be the only person to think of chilling a long coil in a bucket of non running water so I am seeking the counsel of the wise.
I assume, that with this as a simple design, I could expand later by making a proper column and even a proper water jacket condenser but I just want to see somethign work
