filtering rum
Anything to do with rum
partybus
filtering rum
Post by partybus »
Has anyone got any tried and tested ways of clearing a rum batch after oaking and flavouring/
so far used coffee filter on mine and boy is it slow and after its first run through dont seem to have done much... repeat again or ??
cheers steve
thepatchworkdoll
Re: filtering rum
Post by thepatchworkdoll »
Hi Steve (another UK stiller, great) have you tried the Harris Vinbrite Filter. Its relatively cheap and it does a great job with wine. Have'nt made rum so can't realy tell. It is a great little filter though. You can get it at most homebrew shops. Try The Homebrew Shop homebrewshop@btconnect(dot)com in Aldershot.
Regards
thepatchworkdoll
rubber duck
Re: filtering rum
Post by rubber duck »
Milk filters work well. You can get them at a feed store hear in the states. You might be able to get them online they look like a white disk about 5 or 6 in diameter.
Tater
Re: filtering rum
Post by Tater »
I filter the charred rum through a few coffee filters before adding rest ingredients.
HookLine
Re: filtering rum
Post by HookLine »
Another one here who uses coffee filters (unbleached). Does take a bit of time for the first pass. Might need to change the filters once or twice during the first pass. Second pass is very quick.
Be safe.
Be discreet.
And have fun.
partybus
Re: filtering rum
Post by partybus »
cheers. will try the wine filter, as may be doing some wine in the summer anyway so will need one(thanks patchwork) dont see many from blighty here.!!
had one through a coffee filter all last night and still not through yet, when you say second pass Hookline is that through the same filter??
will set another up now , gota go to work now so will see later.
smell and tastes wonderfull by the way
steve
HookLine
Re: filtering rum
Post by HookLine »
partybus wrote:had one through a coffee filter all last night and still not through yet,
That is taking way too long. I usually filter 5 litres (bit over a gallon) in about an hour. You might need to run it through some coarser filters first, like some fine stainless mesh, or a couple of layers of plain cotton cloth.
partybus wrote:when you say second pass Hookline is that through the same filter??
No, I use a new filter for the second pass.
Be safe.
Be discreet.
And have fun.
Dnderhead
Re: filtering rum
Post by Dnderhead »
""fine stainless mesh, or a couple of layers of plain cotton cloth.""
what? a good pair of used pantie hose is much better! :twisted:
:lol: :lol: :lol:
Ya Iv had some leprecon gold
partybus
Re: filtering rum
Post by partybus »
ok , home from work and done another run through coffee filter, much better 2nd time round.
still abit hazy or is this as clear as home run stuff goes.
Re: filtering rum
Do you have enough space in the freezer?
Put it in there and let the jellyfish settle on the bottom. Then re- rack (with filter) to another vessel.
rubber duck
Re: filtering rum
Dnderhead wrote:""fine stainless mesh, or a couple of layers of plain cotton cloth.""
:lol: :lol: :lol:
Hmmmmm I'll bet that would work well. :shock: :idea: :idea:
