Overheated stainless steel
Forum for the discussion of any material/synthetics.Only posts with info /or links to research info allowed . Any posts recommend the use of any material without copy's or links to show proven research will be deleted
robbieinc
Post by robbieinc »
I recently had a 10 gallon Firestone stainless steel milk can welded because it had a hole in the bottom. The result was an overheated mess, turning the area black. After running a water wash, the area seemed to have turned a rusty color and there was a brown residue in the boiler. Is it safe to say I need a new boiler?
This topic has 6 more replies
Register Login
